Car & Driver Tests 11 Performance Tires December 2005
In the Car and Driver December 2005 issue 11 high-performance street tires, labeled "max performance" were tested along with help and support of the Tire Rack. All season tires were not included however all tires were tested in 3 dry and 3 wet tests.
The tests were conducted on-site at the Tire Racks facility and included Braking tests in the dry and wet, Autocross in the dry and wet and Skidpad in the dry and wet.
This is not intended to start any arguments or flame wars it's just here for anyone who is interested in the results.
The Yokohama tested best in the dry, and the Goodyear in the wet with the overall combined results of as follows from first (best) to last.
1. Goodyear Eagle F1 GS-D3
2. Continental ContiSpotContact 2
3. Yokohama Adfvan Neova AD07
4. Michelin Pilot Sport PS2
5. Hankook Ventus R-S2 Z212
6. Dunlop Sport SP Sport Maxx
7. Pirelli P Zero Rossa Asimmetrico
8. Toyo Proxes T1R
9. Bridgestone Potenza RE050A
10. BFGoodrich g-Force T/A KD
11. Kumho Ecsta MX
The tires were all tested on a BMW 325i. I would consider many of the characteristics of the car similar to the C-Class.
I found the entire article to be very informative, evidently this is the first tire test conducted by C&D since 1989.
8. Toyo Proxes T1R
11. Kumho Ecsta MX
8. Toyo Proxes T1R
11. Kumho Ecsta MX
having had the Michelin PS on my car and then driving the loaners with the Conti's, the Conti's suck ***!
and I'm really liking my Toyo T-1S. Plus, no way the Hankook's can be ranked that "high"...
Pics from tire rack.
if you go into a 70-90degree corner at 45mph you either A) kiss goodbye under-steer into the curb or B) rear's gonna get lose depending on how fast you take the turn and how fast you turn the steering wheel. Law's of physics or driver error cannot be blamed on the tires.
I run on GS-D3 btw. I have used pilotsport, contisport1 and 2 and the rosso.
Dry Traction 9.5/9.2, Wet Traction 8.7/9.1, Hydro Resistance 8.5/9.0, Conrering Stability 9.2/8.9, Steering Response 9.1/8.8, Ride Comfort 8.5/8.6, Noise Comfort 8.5/8.5 and Tread Wear 7.4/8.0.
AND
Tiretracks tests gave the following rankings(Michelin/Goodyear):
(STREET)Ride Comfort 6.39/6.48, Noise Comfort 6.35/6.41, Handling 7.48/7.45, OVerall Road 6.74/6.78
(TRACK-DRY) Cornering Stability 8.55/8.38, Steering Response 8.56/8.26, Braking Modulation 8.26/8.11, Handling Predictability 8.35/8.17, Overall Track 8.43/8.23
(TRACK-Wet) Cornering Stability 8.12/8.19, Steering Response 8.25/7.96, Braking Modulation 8.18/8.03, Handling Predictability 8.08/8.18, Overall Track 8.16/8.09
Slalom: Dry 4.13/4.20 Wet 4.42/4.39
Lap Time: Dry 29.75/29.98 Wet 30.78/30.69
Braking 50-0: 84.6/84.7
Cornering G's: Dry .95/.94 Wet .91/.92
So, what does all this indicate? Both the owners reviews and the tests indicate for a pure extreme performance dry tire the Michelin is better...for an all around performer or if you live in a rainy are, the goodyears are the bestg bet!!!
Given that i live in SoCal i will be getting the Michelins when the OE are worn out(i give them <7K miles since i have a problem not laying rubber stips 40ft long every chance i get!!).
a couple tires came up in my mind,
conti sport 2, yokohama AVS sport, michelin PS2, good year eagle F1.. and after reading this maybe thinking of yokohama AD07, and BFgoodrich Gforce AT/KD
so basically im just pick form either "1,outstanding dry traction, or 2,better looking patterns, or maybe 3 treadlife" noise doesnt really bother me...
