oil change for 05 c55
Old Nov 13, 2005 | 09:42 AM
cap55's Avatar
c55
Can somone help me w/ changing my oil in 05 c55? I'm confused is the RED cap in the back of the motor left side if in front of motor the oil tube? If it is that answers my question and I will extract from there. But if as all say you only get 7.5qt from there how do you get the remaining 1.5qt if you can't get it from oil filter housing.... can someone please help me it would be much appreciate
Old Nov 19, 2005 | 08:48 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Hello Cap-
Yes - the red cap is the oil tube. Get a dipstick (see my other post for the part number) and the correct fill is to 160mm on the stick. 9qts should get you right to that reading.
You can't get the remaining approx. 1.5qts out. Best way for C55s is to drain the oil. Remove the underpan - drain oil from BOTH drain plugs. Remove filter assembly and replace filter with FLEECE filter only. MB OEM and Bosch 72204 are both the OEM Mann fleece filter. Also replace all o-rings and coat with motor oil before re-fitting the assembly.
Take your time - it's pretty straight forward.
Old May 30, 2006 | 06:18 AM
chucknorris's Avatar
AMG
Originally Posted by kjb55
Hello Cap-
Where can you buy the o-rings, filter and dipstick? Are they available online? Thanks.
Old May 30, 2006 | 10:50 AM
kjb55's Avatar
Besides the dealer, Bosch part number 72204 will provide the OEM fleece filter element, and all orings. The dipstick I purchased was from Baum tools.
Old Jun 8, 2006 | 09:45 AM
Brabus C55's Avatar
2005 Brabus C55
sorry to jump the thread ...
I'm having tough time finding the "European Spec" Mobil1 Supersyn (for 2005+ AMG engines) ... even the dealer does not have it in quarts ... where are you getting your oil?
TIA, Peter
Since I'm at it ... ever do the tranny fluid?
Old Jun 8, 2006 | 12:11 PM
kjb55's Avatar
Mobil 1 dropped the 'European Spec' wording from the bottle, but the container will state that it meets MB spec 229.5.
HOWEVER, MB changed their spec to MB229.51; Mobil 1 ESP Formula M; 5W-40.
This oil was suppose to become available May 15, 2006.
Old Jun 8, 2006 | 12:15 PM
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
I would use a oil extractor pump and just pump out the oil. its how the dealer changes oil in our cars and its very easy to do.
Old Jun 8, 2006 | 01:49 PM
Brabus C55's Avatar
2005 Brabus C55
Talking hahahaha ... f@!%$^%&^* guys
Thanks kjb55!
it'z zee MB229.51 ... not zee MB229.5 spec!
I'm assuming the +.01 version (Mobil1-ESP Formula M ), you're referring to, is specifically for the 2005+ AMG motors ... ?
I'm wondering what the difference is ... probably an additive package.
Old Jun 11, 2006 | 09:31 PM
kjb55's Avatar
The bulletin put out by MB listed models 171, 203, 209, 211, 215, 219, 220, 221 and 230. It was a mix of AMG and non-AMG models.
MB gave no explanation as to the difference in formula, but I'm with you that in addition to the 0W going to 5W (very minor cold weather weight rating), that it's most likely an additive package.
