picture of my stoptech BBK
Old Nov 14, 2005 | 12:01 AM
psk145's Avatar
2006 E55
Finally got my kit from Neal at Euroteck, and got them installed. Had some issues here and there, but Neal was on top of them right away calling StopTech, even though it was like 7 or 8pm his time. Thanks again to Neal for the excellent post sale customer service.
just some really quick pics since I wanted to post something up.
rear
front
Old Nov 14, 2005 | 09:31 AM
jtc55's Avatar
08 E63
looks awesome!!!! besides the great look, have you notice a big difference in braking power?
Old Nov 14, 2005 | 11:57 AM
psk145's Avatar
2006 E55
actually less at the moment, I think there's some air trapped in the lines. There's a lot more pedal travel than stock. Im off to go get them rebled in a few minutes.
Old Nov 14, 2005 | 12:41 PM
dragonAMG's Avatar
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
Looks awesome. I'm thinking about getting a BBK. My only concern is clearance with my 441r HRE's. You don't have issue with that?
Old Nov 14, 2005 | 02:06 PM
psk145's Avatar
2006 E55
the front seems to have more clearance than stock, and the rears have enough room as well. They have that template you can download and put on your rims to see if they'll fit. They'll most likely clear your HREs. A set would look awesome on your car!
just got back from having them rebled, and the pedal now feels as good as stock. Braking seems to have more bite as well, but that could be a mental thing too.
Old Nov 14, 2005 | 03:34 PM
BenzoAMGpower's Avatar
Cars and boats!
look great.... enjoy yours as im enjoying mine!!!!
Old Nov 14, 2005 | 03:39 PM
Bif powell's Avatar
2002 c32
Did you get the braided metal brake-lines and does that make a difference?
I've really been considering that because, as much as you can get on it in the C32 and it will stop fast, I would like much more 'touchiness' and no squishy at all if I can and the braided metal lines seem to be the clear dope - I just don't know if that's one of those mods that you would really barely notice and would only make a difference if you're trying to squeeze out that extra .3 secs on a road track, or if it's something you would feel all the time and really make the brakes feel harder?
Old Nov 14, 2005 | 04:30 PM
Cars and boats!
slotted vs crossdrilled
..... anyways... neal is da man!!!
Old Nov 14, 2005 | 04:35 PM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
Charles,
That looks absolutely awesome! makes the car look so much better, the better braking is just an added plus! :p
I'm glad we got everything taken care of for you.
Your ride height is perfect, and the brakes really compliment the wheels!
Thanks again!
Old Nov 14, 2005 | 10:48 PM
BenzoBoi's Avatar
Super Moderator
W221
Perfect...great setup mang
Old Nov 14, 2005 | 11:57 PM
OJwerks's Avatar
not stock.
Wink
so stoptech or brembo???
Old Nov 15, 2005 | 12:25 AM
Scoop55's Avatar
'05 C55 AMG '15 Jeep SRT '11 G37S
Brakes look awesome!
What size are they?
Old Nov 15, 2005 | 04:22 PM
psk145's Avatar
2006 E55
What size are they?
355mm front, 328mm rear
The kit came with stainless lines, but its impossible to tell how much the lines contributed separate from the larger brakes. I do know that on my R6, when I switched to stainless lines, the feel was significantly improved. Apples to Oranges, but still a comparison I suppose.
Old Nov 16, 2005 | 01:38 AM
rbaker's Avatar
Z06, M3, Mini Cooper S. Sold: C55
Not to throw a monkey wrench in the works, but are you sure the rotors aren't installed on the wrong sides of the car? Normally, rotors are installed so the internal cooling vanes are oriented to match the rotation of the wheel, in effect creating a little air pump as the wheel turns. These look reversed if the cross-drilled holes follow the normal pattern of the vanes.
Old Nov 16, 2005 | 01:47 AM
CDP's Avatar
CDP
W124's
Nice Job!
The BBK from Stoptech and the HRE's finish the car off perfectly in my opinion.
how much does a set like this set oneself back?
Old Nov 16, 2005 | 02:50 AM
Fast Cars!
Those are definitely installed correctly. Here is a link to stoptechs FAQ's. http://www.stoptech.com/tech_info/faqs.shtml#16 Scroll down to "How do I tell what direction the rotors go on the car?" You cannot tell from looking at the cross drilled pattern which way the vanes are facing.
Old Nov 16, 2005 | 03:10 PM
cliverman's Avatar
2002 C32 AMG
psk145,
You officially get my award as the best looking C32 on the board. Dragon's C55 is the best in that class.
Old Nov 16, 2005 | 04:39 PM
psk145's Avatar
2006 E55
Originally Posted by cliverman
psk145,
You officially get my award as the best looking C32 on the board. Dragon is the best looking C55.
thanks for the compliment, but my car is really small potatoes compared to some of the other C32's out there.
Old Nov 16, 2005 | 08:00 PM
cliverman's Avatar
2002 C32 AMG
Small 'taters or not. I like the wheels and brakes. If you ever want to part with them - send me a PM. They'd look good on my 32.
Old Nov 17, 2005 | 03:11 AM
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
Like mine,,sheeshhh..
Anyway I saw them in person and it does look super hot.
Old Nov 17, 2005 | 03:22 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
stoptechs are nice. very solid brakes
Originally Posted by BlackC230Coupe
Those are definitely installed correctly. ... You cannot tell from looking at the cross drilled pattern which way the vanes are facing.
the pattern visiually (cross-drilled holes) does not matter. what matters is the internal vanes. if u look at some of the stock ventilated (not drilled) rotors, the vanes don't have a direction. in many aftermarket bbk, such as those from brembo and probably these stoptech, the rotors have vanes that are direction and u need to have those internal ones match the rotation. the pattern may just look backwards because each hole is separated and drilled at a particular point such that they create a visual pattern, but are in reality aligned with the internal vanes
Old Nov 18, 2005 | 02:23 AM
rbaker's Avatar
Of course it's not the direction of the cross drilled pattern that matters, but I'm used to seeing the cross drilled holes on many rotors being in line with the internal vanes. Apparently Stop-Tech uses a reverse pattern for drilling.
Old Nov 18, 2005 | 02:53 AM
Fast Cars!
I would not say its only stoptech. A lot of BBKs i have seen are that way. Of course it depends on the brand and application though.
Old Nov 18, 2005 | 03:01 AM
BenzoBoi's Avatar
Super Moderator
W221
Hey Neal...doesn't that second BMW belong to a guy named Nick?
Old Nov 18, 2005 | 04:42 AM
Fast Cars!
Yeah, i believe it does, its supercharged also i think.
