Any Tein or H&R folks with problems or squeaks?
Old Nov 16, 2005 | 08:38 AM
jhw's Avatar
jhw
I'm interested in Tein's Basic Damper (not the SS) and also H&R coils. Does anyone have any clearance issues with the H&R solution (with stock C32 rims)? What about Tein problems? I've heard they squeak or something.
My alternative is KW Variant 1's but I'm open to other ideas!
Old Nov 17, 2005 | 06:21 PM
C32Andy's Avatar
2016 C300
I have H&R coilover installed since 2003......not problem at all.....very satisfied
Old Nov 21, 2005 | 01:36 PM
jhw's Avatar
jhw
Thanks for the info. One more Q: on the H&R website under their W203 application they have this footnote:
Footnote
13 Wheel offset critical; Spacers may be required when the standard wheel / tire combination is used.
I know it was a long time ago but do you remember if you needed any spacers?
Old Nov 22, 2005 | 12:41 AM
KompressorKev's Avatar
'14 428i M-Sport, '02 C32 AMG
i have H&R coilovers. ran a long time with them on stock wheels, no problems. car could go very low, no squeaks so far (knock on wood). the only thing squeaky is my driver's seat... . but for the purposes of the c32, the H&R coilovers are pretty good. there are better options like Carlsson RS, but for the price and intentions of the c32, you probably won't regret going with H&R's. btw, i ran fine without spacers.
Old Nov 22, 2005 | 01:20 AM
sdsilverm3's Avatar
Do you have a picture of how low the car was with the stock wheels?
Old Nov 22, 2005 | 01:52 AM
yea it was really low on stock rims. now the drop is still pretty low on my 19's but ground clearance isn't quite as bad. on stock 17's w/ H&R coilovers:
Attached Thumbnails Any Tein or H&R folks with problems or squeaks?-mbworld-pic.jpg
Old Apr 4, 2007 | 01:20 AM
Rareamg's Avatar
E55 AMG Black on Carlsson 1/6 EVO
Funny, mine just recently started to squeek a bit.
Old Apr 4, 2007 | 02:25 AM
sdsilverm3's Avatar
Let me guess, the rear springs?
Old Apr 4, 2007 | 02:36 AM
Clk&Slk's Avatar
06' Clk 500 Cabriolet, 01' CL 55, 00' Clk 430
I have a used (less then 500 miles) KW V2 coil over kit for sale. Drop me an e-mail for me info.
Old Apr 4, 2007 | 02:57 AM
Rareamg's Avatar
Man, How'd you know?
Old Apr 4, 2007 | 02:59 AM
Rareamg's Avatar
Anything I can do to get rid of the Squeekness?
Old Apr 4, 2007 | 09:21 AM
sdsilverm3's Avatar
I had this same conversation with my tech yesterday. The one's that he's had problems with in the past were resolved by putting lithium grease on the spring pad and spring. The KW's are installed a little differently than your Tein's being that your adjuster is on the bottom versus mine, which is on top, but it's worth a shot.
I've done it once already but unforunately used WD40. That worked for a while until it rained and washed it away. Needless to say I'm going to try the grease sometime in the near future because it's not getting any better.
Old Apr 4, 2007 | 01:00 PM
Rareamg's Avatar
Cool man.. Thanks for the info. I will have Carlabs take a look at it since they installed it.
