to upgrade plug wires, or not??
02 C32R
OK, I have been thinking of upgrading the plugs and wires. I know I will want the denso iridium IK16's, but what plug wires do I go with?? I know there are magnacore wires, but what does everyone recomend??
02 C32R
Originally Posted by dinko
Any performance increase?
Dinko
Dinko
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
Evosport sells this stuff.
Vadim - what plugs and wires do you guys carry? What type of performance gains can we expect from this upgrade if any at all?
Where can we get them for $10 a plug?
02 C32R
oops well $10.75 Denso IK plugs and again I havent even started searching the internet for these plugs, I accidentally found them on this site...
Cars and boats!
Originally Posted by Dead Ringer
yes, but they charge over $500 for 12 plugs and wires (I think it was like $530).. A little too rich for me.
Originally Posted by BenzoAMGpower
i think magnecore (sp?) makes sparkplug wire set for our cars
well I am not 100% sure, but I have a feeling it should add a little hp/tq. I think by adding a cooler plug, and when you can get a better "spark" via wires then it certainly cant hurt...
2002 SLK 32 AMG
02 C32R
Originally Posted by amgstyle
don't you want the IK20's. on the denso application guide it says our cars need the IK20's ??
then as to the question in regards to a "colder plug?" yes you need when there is extra boost... here I pulled this from Car Craft, its just a small portion about plugs and why you need a colder plug when turning up the wick on your engine:
Heat Range
Controlling the operating temperature of the plug’s firing tip is the single most important factor in spark plug design. “Heat range” is the relative temperature of the spark plug’s core nose, and it is determined by the length and diameter of the insulator tip, as well as the ability of the plug to transfer heat into the cooling system. A “cold” plug transfers heat rapidly from its firing end into the cooling system and is used to avoid core nose heat saturation where combustion-chamber or cylinder-head temperatures are relatively high. A “hot” plug has a slower heat transfer rate and is used to avoid fouling under relatively low chamber or head temperatures. What’s confusing is that a “hotter” (higher performance level) engine requires a colder plug because more power equals higher cylinder temperatures.
Regardless as to whether a spark plug is considered hot or cold, the ideal temperature for the center electrode of a spark plug is between 930 and 1560 degrees Fahrenheit. In that range, the insulator is burned clean and the electrodes don't melt. If the electrode temperature falls and stays below 930 degrees F, combustion by-products build up on the insulator. This causes misfires, lower spark energy, and fouled plugs. The solution to that problem is to use a hotter plug. If the plug is too hot, the electrode can burn away and pre-ignition can occur. This results in holed pistons. Given a choice, you always want to err on the cold side with spark plugs, but this isn’t voodoo. Even with unleaded gas you can read a plug to see if it’s overheated. Using an EGT probe is another option. I think the best option is to put the car on a dyno and use the combination of an EGT probe and checking the HC and NOx levels. This will tell you exactly how the ignition system is doing on a moded car.
02 C32R
OK, well I was going to go with them since that is what a few others have switched to, plus I live in Phoenix Az and the temps here during the summer are, well kinda hot, and I was figuring that with the increased pressures I am running, I should probably look into getting a cooler plug. I should probably stop by DynoComp and have them plop my car onto their dyno to see how its running and if I would benefit from doing this.... Again I am trying to get info on whether this is a good mod. It looks like I can grab the wires for just under $100, and the plugs for $130, this is do-able, which is better than $500+ .
I can understand how a colder plug may seem to make sense. This is a common mod for turbo owners who crank up the boost. Unfortunately, many of these same boost-a-holics find that they have low speed drivability problems due to fouled plugs. I put about 70,000 miles on an Rx7 in a single year, mostly in AZ, and mostly in the summer, so I know it gets blisteringly hot out there. I also found out something else; Bosch FI systems have an intake air thermosensor. When the intake temps exceed a predetermined level, the FI logic will make the car run rich. Rich AF levels and cold plugs are a bad combination.
Having said that, cooler plugs may be an improvement. I can’t honestly say that I know one way or the other. If it were me, I'd pull a couple of plugs and have a look. If the porcelain is ultra white, or cracked (gulp), the insultator is melted, or there are metallic specs in the porcelain, then the plugs are way too hot. A little tan is what you hope to see.
