E55 engine into a C32
You aint gonna get a v8 into a 32, thats why the c55 has had a whole new front to accomodate there 5.5ltr v8.
P.s. if i start with a new C55 i am lookig at 50kor more sticker price+15 to 20K or more (to get it Kleemanized)= 540 HP and 70 to 80K in total $
if i start with my C32 I owe alomst anything on it+ E55 engine (15k if i could find one for that price)= 20k or more plus some labor= 500+ HP
I think i will stick with the C32.
You could also sell your C32 for low30's, buy a used C55 for the low 40's, and start with that instead. If you want a AMG 55k motor you could sell your C55 motor and then but a used E55k motor and install that. Something about having all the mounting points for the motor and trans matching up would be a real stress reducer when it came to the mods. Youl also just strap on a RENNtech or Kleemann blower to the stock C55 and go with that.
Putting a V8 into a C32 is really a real stressful idea. Starting with a C55 would be much more simplistic.
But yes a V8 can be put into a C32. It just takes a TON of work.
I could take this 2 ways
1. Sell my C32 and get an E55 and do some minor upgrades
-or-
2. Sell my C32 and get a C55 for low 40's and then Kleemanize it.
and the crowd says....
Kenzmbz: for the right price my engine will be available. I saw the German potomac store and they are selling a C32 engine for like 7,995.00, if i let my engine go it would be around 6K.
There's no way the transmission on a C32 is exactly the same as an E55K. The V8 tranmission is built to withstand much higher HP and torque. Even if you got the motor to fit on your transmission, there's a risk of the transmission failing since it's not built to withstand 500HP.
Well there are many things you can do. I went from a C32 to an E55 and well it really is a huge car. I now a good friend with who I go to track events. We take his C32 and a BMW race car and we dont even bother with the E55 because it is just so huge and heavy.
But remember the added mass from a blower on a W203 (C55k) will make the car about 150 lbs heavier and that is a good chunk of mass. With that you are pushing 4k lbs. For a little more mass you can have an E55 with the added space etc.
a $56K E55 sounds like a great deal and if you could get used to the bigger car you would love the power. A chip and pulley on a 55k is enough to make those Kleeman cars look a bit slower. The best part is that a 55k motor uses 9:1 compression and can run higher boost than say a 11:1 C55 motor. An E55k stock (with a good driver) is about equal to a supercharged C55. Add a few go fast parts to the E and those W203's are less interesting.
Good luck
