A 2000 Acura TL keeps up?????
I don't think so not a 2k but then again i don't know for sure.! But those cars do run pretty well upstairs.My dad had a 2k3 TL type S different than the reg 2k TL and it had nice TQ to boot I'd say.Pretty impressive ran pretty good off the line for an automatic.
Test drove a new '05 TL before buying a used C32. Even with its new "enthusiast focus," (they're all effectively Type S now, with about 270hp and 240 ft.lbs., manual available, etc.), the TL didn't hustle nearly as fast as the C32.
The bottom line is that, if your definition of a race is accelerating to a certain speed which almost any car on the market can attain, and then weaving through traffic, you are going to find that just about any car can keep up with your C32.
The TL didn't get 260hp until 2002 w/ the Type S model. The 2000 model has 225hp with no Type S available. The easiest way to tell is by the wheels.
up to 3rd gear they have good power...
3rd ends at about 110... therefore I would drive in 3rd all the time..
when 4th hits... ITS OVER for the Acura. The 4th and 5th gear are cruise gears.
Adding a simple intake headers will yield 30hp, around 290 at the crank.
Adding the blower will add another 75hp...
If you were not WOT and he was WOT, if you stay under 100 he would be able to keep 4 to 5 cars behind.
sounds about right... for a 260hp car.
If it was the regular 225hp version, it must of had atleast headers and intake atleast.
next time slow down... have him catch up and go at it again. you will see the difference in torque and gearing.
