throttle booster, highly recommand!
Rating: Thread Rating: 2 votes, 5.00 average.
Old Aug 28, 2006 | 06:31 PM
  #126
m3_eater's Avatar
Originally Posted by Zeppelin
You guys should get in on that. I got mine from the first Crossfire forum group buy - so as long as an honest soul is running it again, you will get your Sprint Booster!
Old Aug 28, 2006 | 07:16 PM
  #127
C32madness's Avatar
2006 E55
Thanks....I just signed up as #10
Old Aug 30, 2006 | 07:15 PM
  #128
Rudoubles's Avatar
03 C32
Crossfire group buy now at 20+
Hey anyone else interested should check out the Crossfire forum...we got over 20 people (and counting) signed up & we're lookin for another price break if we get 30 people willing to buy.
Old Aug 30, 2006 | 09:37 PM
  #129
straightSIX's Avatar
'03 E39 530I
say what?
Originally Posted by Whitey
I have known many guys with SLK350's removing their boosters becuz their GF's just couldnt take the excessive jerking.
Old Aug 31, 2006 | 12:51 AM
  #130
Whitey's Avatar
98 W210 Advantgarde
Originally Posted by straightSIX
say what?
]"extra sensitivity" causes the car to jump over bumps
Ok, I've clarified a number of conflicting info:
1. Two versions: auto/manual vs old and new.
Seems Sprint now calls their new version auto as it is a toned down version and works with all newer models of MB. The old/manual version causes newer MBs (06+) to kick in the check engine light or into limp mode as one member has said. I use a old/manual version with no problems and it is actually much more sensitive than the auto/new version but my car uses an older ECU setup (altho as said it is not an ECU mod, the speed of the fuel feed does affect the ECU's interpretation of the car's health, hence sends the newer ones into limp mode or the check engine light lights up) and has less CC's. There is actually a 3rd version specifically for the W221 S's as the ECU is different again.
2. booster's location
I have personally installed them on my buddies' R171s and and regular W203's and they are under the dash - I think also the same on a W211 E55 I saw being installed. On mine and a W210 E55, it is in the engine bay - 2 minute plug and play. I presume the C32/C55's might be a bit different but haven't checked - if you guys have confirmed it to be on the pedal, then it is.
My apologies for the confusion.
Old Aug 31, 2006 | 01:16 AM
  #131
amgstyle's Avatar
2002 SLK 32 AMG
hey guys i'm interested as well. will this work for a slk 32amg ???
Old Aug 31, 2006 | 01:50 AM
  #132
OJwerks's Avatar
not stock.
im in for this too....should work "nice" with my exhaust and nitrous coming up......
Old Aug 31, 2006 | 11:22 AM
  #133
pugguy2001's Avatar
2016 C63s AMG
I would also like to buy one. How many people do we have so far? How much are they now with the group buy. Who do I contact and send my money to?
Rick
Old Aug 31, 2006 | 04:45 PM
  #134
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Put me down also
Can someone go on the Crossfire forum and put AMGSC on the list? I am not a member. I WANT ONE !
Old Aug 31, 2006 | 05:07 PM
  #135
Capt Nemo o2's Avatar
'05 C230SS 6MT, 1966 Triumph TR4a IRS, Shelby Cobra 427 Supercharged
What is your email I can use so the GB organizer can reach you?
Old Aug 31, 2006 | 05:44 PM
  #136
AMGSC's Avatar
robert.chen@charter.net
Old Aug 31, 2006 | 05:58 PM
  #137
OK, posted over there to have you added to the list...
  #138
Old Aug 31, 2006 | 05:59 PM
  #139
  #140
Old Aug 31, 2006 | 06:03 PM
  #141
m3_eater's Avatar
Just following up again as promised.
I've used the thing for a few hundred miles now in mixed mode city/highway and in various driving styles. I'm still a big fan and I suggest it, that hasn't changed. However, I have decided that the reset trick still needs to be performed periodically to maintain sharp and consistent throttle response in our drive-by-wire cars. It took the car a lot longer to "learn" how to be slightly softer around the edges than before the Sprint Booster install, but I was able to discern a difference. I'd say that before it was necessary to perform a reset every few days of normal driving. Now I'd say the interval can be more than a week. Your experience will vary based upon how you use your car - I think I'm too gentle/non-aggressive in my normal driving, since I use it for my daily, mostly highway commute in the Summer months. This tends to give the computer a lot of "I want to take it easy" kind of information. If your drive to work is a blast through canyons daily, you might NEVER have to perform the reset again after you install one of these
Also, I can report that the car is not too touchy after performing a reset with the Sprint Booster installed. I guess there is only so much slack to be cut out of the DBW system.
One last thing I have noticed: If you go from light throttle to WOT at a speed that would require a two-gear downshift of the transmission, the pause until WOT is delivered is not shortened from stock. The ECU still has to decide how many gears down you want, etc. - Sprint Booster does not help there. too bad there's no GIAC-style chip for our transmissions, like in Audi S4's!
Old Aug 31, 2006 | 06:15 PM
  #142
jgsx's Avatar
04 C32
Wow, you took the words right out of my mouth. I was about to post something similar today.
Old Aug 31, 2006 | 06:33 PM
  #143
Tump43's Avatar
2014 E350 4Matic
Capt Nemo o2
I'm not a member either. Would you put me on this list for the boster. I have a 2005 C55 AMG and am at: mmclaw@optonline.net.
Thanks,
Marc aka Tump43
Old Aug 31, 2006 | 07:05 PM
  #144
Originally Posted by Tump43
Capt Nemo o2
Thanks,
Marc aka Tump43
OK, posted!
Old Aug 31, 2006 | 07:17 PM
  #145
gregr09's Avatar
non-MB
hey nemo,
can you add me as well? for a c240 automatic.
thanks bro.
schulmang1@citadel.edu
  #146
AMGSC and Tump43 (and I guess all others who want in on this group buy). To get more info, and to give him your info, he asked that you please email him at: mmz-timelord@sbcglobal.net
He said he will add you to the list, he's just waiting for you to drop him a line with your info. That is also his paypal email if thats how you wish to pay.
Old Sep 1, 2006 | 12:57 AM
  #147
pugguy2001's Avatar
2016 C63s AMG
Allright, try #2:
First off, I just want to chime in again in support of this mod. I do not have anything to do with the manufacturer or sellers of the Sprint Booster, and I don't get anything from talking them up - it's just a fun, cheap mod that should be tops on everyone's buy list here, no kidding. There is no snake-oil salesman lurking about here
Second, the install. It is exactly as jgsx said, and like the photos boohooramblers posted. Took all of 10 minutes, and I saw immediate improvement. The car really does behave much more like it has a mechanical linkage throttle now, though if you drive in many varied traffic types you will still be able to detect some non-linearity. It feels as if they wired a logarithmic-scale potentiometer in series between the pedal and ECU, such that the phase of the stock dampening effect and the phase of the fix cancel each other out. The result is a decidedly more linear feel. You could theoretically get similar effects by modifying how you use your gas pedal normally - but it would be bizzarre because you would have to stab at the throttle fast and to exactly the appropriate percentage of travel every time. Good luck developing that kind of precise leg and foot muscle control!
My favorite thing about this mod: the "D" (auto) mode of the transmission is finally usable! After a long tiring day at work, I can now leave the car in auto and use the gas pedal alone to call up throttle and downshifts exactly appropriate for the amount of pedal travel, instead of (1) guessing, (2) waiting, and/or (3) just using manual mode to ensure that it downshifted the right number of gears. How many times have you been cruising along in traffic at say 45-55 MPH, and needed a single downshift + some throttle to get into a briefly-open hole in traffic? Before, if your car was in "D", you would press the pedal and get almost nothing. Then, you'd press harder and even if you were smooth you were gambling that the car would not just go two gears down and give you more than you asked for. I'm not some kid in a Civic with a giant wing on the back - I want smoothness AND responsiveness, without getting all out of shape and embarrassing myself and/or scaring other motorists. The only reliable solution before was to call up a downshift manually via +/- mode, then press the gas at just the right moment to accellerate smoothly, then upshift to "D" again when the traffic move was complete. With the Sprint Booster installed, I just press the gas about as much as I THINK I should to go a little faster, and presto! The thing does as I ask instead of "Oh, you want to go faster? Umm.... how about NOW - ZOOOM!". Also, I don't get caught in auto mode with my pants down by quick cars who want to show me something. Nail it a little, nail it a lot - you get whatever you ask for.
Oh - and yeah, you can chirp the tires in 1st and second if you like
Finally, I deliberately did not perform the throttle/trans ECU reset trick when I installed the Sprint Booster. I want to know if it will provide most/all of the reset benefits, without requiring resets all of the time. I had been in the habit of doing resets almost daily before. So far, it is working great, and I'll wait for a while before trying a reset to see if it is good enough alone, or if the tranny will "learn it's way around it". I have a feeling it will be fine, because what the transmission is now learning is throttle inputs that more closely resemble those I actually desire! I also want to see if it becomes too touchy after a reset now. I'll follow up later as I learn more.
Sounds awesome I cant wait to get one. I have a 2005 C230 Mercredes. Just wonderingif yours looked like the first picture or the second picture?
Attached Thumbnails throttle booster, highly recommand!-sprint-booster-mercedes-small-.jpg   throttle booster, highly recommand!-sprintbooster-installation-small-.jpg
Old Sep 1, 2006 | 01:24 PM
  #148
m3_eater's Avatar
Both, actually The first pic is how it looks out of the box. The second (set of pics, actually) show the install as if the module did not have it's harness connected. That's just for clarity, I assume. Written another way, pic #2 shows how to install what is in pic #1.
Old Sep 1, 2006 | 04:18 PM
  #149
I was aksed to post this by the GB organizer over at the XF forum...
http://www.crossfireforum.org/forum/...&postcount=253
It's the status of those who paid and those who didnt.
Old Sep 2, 2006 | 02:15 AM
  #150
Whitey's Avatar
98 W210 Advantgarde
The second pic may be where you put it but that booster itself is an Audi one... The first pic is what an MB one looks like.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
