Resonator Removal
Between 2-4k rpm under hard acceleration it sounds (to me) exactly like a coffee can exhaust on a civic. It is a much higher pitch ricer sound vs. the deeper, throatier sound I was hoping for. All I had done was the resonator delete. Initially I canted the cats removed but the guy at the shop said they couldnt do anything with the cats or it would jack up the computer. Does anyone else notice the same sound or is everyone else getting a deeper exhaust note? To me my car sounds more like a crotch rocket than a muscle car. I'm thinking of taking it back to the shop and having the guy put it on the lift again so I can take a look for myself on whats what under there... BTW this thing does feel like it lost allot on the low end. I know several people say it does nothing to your bottom end, but I swear this thing is a pig now unless on the throttle hard in the higher rpm range.
Input appreciated!
Insert Key and turn to 'on' (not quite to start the car)
Floor the gas pedal as hard as you can for 5 seconds
With the pedal still floored, turn off the key
Wait 2 minutes (or don't, I've had mixed results with not waiting, so sometimes I do just to see if I can tell a difference - I can)
Start the car and see if the throttle is more responsive and if that doesn't fix the bogging we all get in this car after the goofy throttle has adapted.
Input appreciated!
I feel the resonator removal actually helps on top, but when the kompressor is disengaged under 3k, it actually hurts
Remember our cars have a split personality.
under 2900 its a C320
over 2900 its a C320 with ROIDS...
the theory that the resonator will gain Hp and torque is correct for turbo or kompressor, but that is IF the kompressor would "all the time"
With a NA engine, most of the time it would loose torque, but it will gain HP on top.
I'm thinking of putting it back.
<SNIP>
One thing that may be relevant, is that neither of you have software installed (i.e. Powerchip) that will take advantage of the slightly increased flow/reduced back-pressure. I say MAY be relevant, because I really don't know - but I am really interested in both of your experiences as I have the reso-delete pipe ready to go on myself.
Regardless, I'm taking the car back to the shop that did my work tomorrow on my lunch break and will see if they removed too much/not enough, etc. Am I crazy or did I read somewhere there was more than 1 resonator? I know there is more than 1 Cat, so I may be getting them confused...
Also, at lunch I kept it on "manual" shifting and it's night and day vs. full auto. Keeping the R's up this thing runs like a raped ape....but then again that was true before removing the resonator.
I still don't understand why my exhaust note is so high pitched and "rattly" sounding. Hopefully will know more tomorrow I guess.
