c32 transmision fluid check???
they want to charge me £185.00 for this because as they say it is a serviceable item and is not covered by the warranty (which has now run out), i am not too sure about having it done as i dont think this will fix my problem and i would be interested to know what service a transmission fluid change would normally be done at
that's a load of SHlT...don't do it...
the transmission problem is real and you need to find a stealership who will do the correct maintenaince...
, i've had the car in several times for the same problem which on my car is intermittant and they can't seem to find anything wrong
. the last time i had it in was just before the warranty ran out and after getting nowhere i made a point of getting the service manager to agree that this fault was reported under warranty and so should still be covered if and when a fix is found
