Pics after the drop (no 56K)
Subscribe
May 2, 2006 | 10:20 PM
By the way guys, the PSS9s were worth every single penny. The car is major tight in the twisties. I now have the biggest grin on when I'm going around corners
Pics after the drop (no 56K)-img_1075_1_1.jpg   Pics after the drop (no 56K)-img_1079_1_1.jpg   Pics after the drop (no 56K)-img_1084_1_1.jpg   Pics after the drop (no 56K)-img_1085_1_1.jpg
Reply 0
May 2, 2006 | 10:26 PM
1 more pic
Reply 0
May 2, 2006 | 10:52 PM
BBS rims rock so much!
Reply 0
May 2, 2006 | 11:37 PM
Those wheels are HOT!
Reply 0
May 2, 2006 | 11:46 PM
Bbs Ftmfw!
Reply 0
May 2, 2006 | 11:48 PM
bbs ch > all
Reply 0
May 2, 2006 | 11:57 PM
I love it, no one comments on his drop, but everyone loves his rims.
Reply 0
May 3, 2006 | 04:22 AM
awesome...glad you fix the problem with the front offset.
Reply 0
Explore
May 3, 2006 | 05:57 AM
drop and rims look clean
Reply 0
May 3, 2006 | 03:37 PM
Furious,
Do the BBS CH require spacers? How much do they weigh?
Reply 0
May 3, 2006 | 08:53 PM
i knew those rims would be sexy on our cars
Reply 0
May 3, 2006 | 08:55 PM
Quote: awesome...glad you fix the problem with the front offset.
Thx!
Reply 0
May 3, 2006 | 08:58 PM
35 Offset. I don't think they require a spacer for the front with stock suspension, but I there are spacers in the back. Spacers required with the drop. I believe that they are around 27 lbs. for the 19"
Reply 0
May 3, 2006 | 09:34 PM
It's sooooooooo good to see you have got the best drop with PSS9 by now!
BTW, PSS9 should allow a range of 30-50mm drop adjustable.
What is the setting of your car now?
Reply 0
May 3, 2006 | 10:38 PM
I'm at 5 all around. Haven't played around with the settings. 5 feels good to me, stiff but not too stiff and definately not harsh. Not bouncy whatsoever.
Reply 0
May 5, 2006 | 09:57 PM
Quote: I'm at 5 all around. Haven't played around with the settings. 5 feels good to me, stiff but not too stiff and definately not harsh. Not bouncy whatsoever.
On my E90, I have set to second most stiff currently and will set it one step softer today. I would still like to know in the range of 30mm-50mm drop, did you set it to max. drop or less drop? Your drop looks perfect to me now. I understand the effect will not be the same for E90.
Reply 0
May 6, 2006 | 02:07 AM
Furious
Today I also got the shop adjusted the PSS9 settings on the E90.
~15cm raised, and shocks soften one step from the previously 2nd highest stiffness setting.
http://www.e90post.com/forums/showth...442#post268442
Reply 0
May 9, 2006 | 09:48 PM
Quote: On my E90, I have set to second most stiff currently and will set it one step softer today. I would still like to know in the range of 30mm-50mm drop, did you set it to max. drop or less drop? Your drop looks perfect to me now. I understand the effect will not be the same for E90.
I think it's a 1 inch drop in the front and 1/2 inch drop in the back
Reply 0
Apr 20, 2007 | 01:23 AM
Quote: By the way guys, the PSS9s were worth every single penny. The car is major tight in the twisties. I now have the biggest grin on when I'm going around corners
ur car look amazing man, do u notice a big difference in performance with the PSS9's? are u able to corner better?
Reply 0
Apr 20, 2007 | 07:21 AM
The car looks amazing. Not my best choice in wheels but the suspension mated with those wheels make the car look very, very clean. That alone for me is a 2 's up for me.
Reply 0
Apr 20, 2007 | 08:50 PM
Quote: ur car look amazing man, do u notice a big difference in performance with the PSS9's? are u able to corner better?
Yes, really big difference in performance. I have zero regrets about getting the PSS9s
Reply 0
Subscribe
Currently Active Users (1)
