Makin sure the C55/32 Brothas are hooked up on the ECU Reset...IT SMOKES!!!!
Old May 22, 2006 | 10:36 PM
  #51
cntlaw's Avatar
C55AMG W203; 330i E90
Our city is very famous about its greasy roads because of density of trucks , disel vans, and double deck buses. Today, I was driving to work and there were pours of rains. Even I was driving slow in the jam , whenever I pushed the fuel pedal a little harder, the ESP light kept flashing!
There is no kidding man, after the reset, we really have to learn how to safely drive a AMG again.
Old May 24, 2006 | 02:29 PM
  #52
diamondblak05's Avatar
Too many to list
Is this ECU reset more noticable in AMG models?...because I swear after I reset mine, I can't feel any difference at all. Maybe my butt is too thick to feel anything......
Old May 24, 2006 | 03:24 PM
  #53
mk2tmr2's Avatar
C32
It will be much more noticeable on the AMG models.
Also, if your driving style is normaly very aggressive, you won't notice as much of a difference from this reset than someone who normally drives very mildly. I noticed a slight difference...not as dramatic as a lot of people here.
Old May 24, 2006 | 07:24 PM
  #54
Nickerz's Avatar
ML350 '06
I read every post here, thinking many of you were delirious (no offense) and after attempting this yesterday, I am now a believer! It worked for me! Or am I just delirious also? lol
I really did notice a difference and trust me...I'm about as skeptical as they come.
Nick
Old May 24, 2006 | 07:43 PM
  #55
Nickerz's Avatar
ML350 '06
Originally Posted by m3_eater
I've been doing this for weeks now, and I never leave the key in for the two minutes. I just perform the procedure, remove the key and walk away. works fine. Only problem is, you should NEVER run a car hard when cold - so if you did the reset and then waited hours before driving, it's learning the "slow"/"lazy" way while you are driving the easy warm-up miles before you lay into it.
I was thinking that the car wouldn't have enough time to learn the "slow/lazy" style of driving during just the warm up period. So I would think it would have the same positive effect, doing the procedure when the car has been sitting as attempting it after running the car and it's already warmed up. It would seem that the car would need much more time to discern if your driving style is aggressive or not. Just my 2 cents.
Nick
Old May 24, 2006 | 11:26 PM
  #56
Eurocharged Rick's Avatar
SPONSOR
one of the mods should just make this a sticky so it doesn't get buried again like the other thread...
Old May 24, 2006 | 11:27 PM
  #57
newton22's Avatar
BMW E39
I didn't feel too much of a difference. Then again, I drive it hard normally.
Old May 25, 2006 | 08:41 AM
  #58
cntlaw's Avatar
Originally Posted by Ultraman
Guys,
When you do step "One", do you turn the key to position 1 or 2? Do you need to floor the gas pedal until it hit the kicker switch?
Thanks.
an some kind gentleman answer above question again?
I did my 2nd reset yesterday and I turned the key at position '2'.
Is this correct?
tks
Old May 25, 2006 | 08:52 AM
  #59
SPONSOR
yup, if you drive hard normally, then you won't notice that much of a difference...
Old May 25, 2006 | 09:36 AM
  #60
Ultraman's Avatar
2019 E450 Coupe 4Matic; 2018 Audi Q5; 2019 Toyota Corolla Hatchback
Is this correct?
tks
Looks like the answer can be found in post#42.
Old May 25, 2006 | 01:18 PM
  #61
m3_eater's Avatar
Nick
Agreed. Since my prior post, my habit of doing the reset often when parking and then driving the car hours later has still worked well. It doesn't seem to get too sluggish from the warmup portion of my drive. However, the problem I have is that traffic on my drive requires a "Jeckyl and Hyde" style of driving - polite most of the time, then lay into it when the opportunity arises. I wish we could just defeat the system by way of a "sport mode" switch.
Old May 25, 2006 | 11:37 PM
  #62
cntlaw's Avatar
Thanks. I did my 2nd reset using the procedure just once and key was set at position '2'. The reason I asked was, the improvement was not as significant as the first time reset , guess mainly due to I had been used to with the fast response throttle for 2 weeks and that feel only died down for a day before the 2nd reset! So, it could mean, once we have started to do this procedure regularly, we will tend to feel the degradation easier than the improvement! I also found that for C55, Transmission 'C' mode is the best to test the throttle and gear change responsivenesses.
Old May 26, 2006 | 12:22 AM
  #63
Ultraman's Avatar
I am going to try this weekend since I drive this car weekends only. However, after reading all the posts, it seems it is better to warm up the engine before doing this.
Old May 28, 2006 | 12:38 PM
  #64
amgmark's Avatar
ML63
Ok.. i tried this a few times and nothing.. then I realized I wasn't turning the key far enough.. Before this my SC would come on like 50% of the time when I floored it.. realy annoying.. Just tried and now every time I hit the gas the SC kicks in.. I was pretty happy!
Old May 29, 2006 | 04:12 AM
  #65
Quad Pipe's Avatar
C55
Let me say that when I tried this, I took delivery of the car, drove home (car was nicely warmed up), did the reset and set out for a hoon.
OMG is all I have to say.
The traction light was going off like a Christmas tree!
Old Apr 25, 2008 | 01:38 AM
  #66
c32used's Avatar
LET C32 2002
Originally Posted by Jakpro1
Spread the word
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
https://mbworld.org/forums/showthread.php?t=148019
Old May 25, 2008 | 12:22 PM
  #67
pointman's Avatar
a car that can't do the throttle reset.
bump for others with sluggish performance like me.
Old May 25, 2008 | 03:28 PM
  #68
1qikctr's Avatar
Merc power
this post is so OLD.
Old May 25, 2008 | 04:55 PM
  #69
pointman's Avatar
Thank you Capt. Obvious. Old or not, helpful is helpful.
Old May 26, 2008 | 10:02 AM
  #70
Newzchspy's Avatar
PLAID
Spread the word
Does this work on all AMG's. Will it work on my 2001 ML 55???
Glenn
Old May 26, 2008 | 01:04 PM
  #71
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Guys, this DOES NOT reset your ECU. It resets your throttle sensor (or something of the sorts). My tech had a grand old time when I asked him if this was legit.
Old May 27, 2008 | 10:59 AM
  #72
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
I'm no expert but, as stated several times throughout this forum, it resets the computer adaptations learned during driver input at acceleration. It is wiping the board clean, to the original factory settings. The transmission settings seem to be cleared at the same time. It tends smooth out my tranny jerk for a few days. My tech loved this trick.
Old May 27, 2008 | 03:39 PM
  #73
1qikctr's Avatar
Merc power
agreed.
Old May 27, 2008 | 11:31 PM
  #74
OCKlasse's Avatar
MBworld Guru
It may reset those things, but the ECU, I don't believe so.
Old Jul 8, 2008 | 02:37 PM
  #75
mikekuriger's Avatar
2010 C63
when you reset the ecu, you also reset to the lousy default gas mileage!
