Makin sure the C55/32 Brothas are hooked up on the ECU Reset...IT SMOKES!!!!
Old Feb 8, 2010 | 11:31 AM
  #101
blackbenzz's Avatar
haters crazy
Anybody try this at the track? One pass no reset and then do the reset and run again? I've never tried the reset but one of these days I will get around to it
Old Feb 8, 2010 | 11:46 AM
  #102
ZAHANMA's Avatar
'13 Dodge Dart, '16 Audi Q5
You know, that is a good thought. I usually reset mine right as I get to the track while I'm letting her cool off. Never thought about if it made any difference w/ or w/o reset between passes.
Old Feb 8, 2010 | 03:50 PM
  #103
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
As I understand the reset, it takes about 40 accelerations (in S mode) from a complete stop, for the computer to adapt to your particular driving style. If you reset at the track, it will be capturing data from a VERY aggressive driving style and should not be negatively affecting your performance. Doing the reset after only a few complete stops is just a waste of time, in my opinion
Old Feb 9, 2010 | 01:29 PM
  #104
nathandimond's Avatar
2006 Volvo S40 T5 AWD 6spd
Something doesn't make sense here
Okay, it is my understanding that the W203 has an adaptive automatic transmission. I don't have a lead food but I do pull ahead of most cars when I accelerate from a light. I would say I have an eager foot. If this is how I drive from the moment I have the car, why would the throttle response become sluggish over time if the inputs from my food tell it to do otherwise?
Old Feb 9, 2010 | 01:54 PM
  #105
c32kompressor's Avatar
CLK55 AMG
so it takes roughly 40 times of hard acceleration to get a good throttle response??
im lost
Old Feb 9, 2010 | 04:28 PM
  #106
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
WOOOOOHOOOOOO!!!!!
Old Feb 9, 2010 | 04:38 PM
  #107
ScottW911's Avatar
im lost
You've got it backwards. It take roughly 40 accelerations to achieve ultimate sluggishness.
No matter how hard you feel you accelerate, the adatptions will always feel slower that the cleared memory in the computer.
The simplest thing to do is just clear the memory every week or two.
Old Feb 13, 2012 | 01:52 PM
  #108
Chip Shams's Avatar
2003 C32 AMG
OMW RIGHT NOW TO TRY THIS
Old Mar 2, 2012 | 11:43 PM
  #109
Ken311's Avatar
E55 AMG, Porsche 911 SC
just want to give some feedback on my experiences with this little trick.
ill first start by saying that the ECU reset does work! the throttle response, shift points, and low end power all seem to be improved. the car just seems to always pick the best gear for optimal acceleration when coming out of a corner, and the 1-2 shift chirps! Amazing.
another thing i noticed, was my gas mileage went to hell, and not just because of the way i was driving. i reset the ECU and tried driving normally for an entire tank of gas and managed 15.4MPG, while my normal driving on the "unmodified" ECU was almost always between 18-19MPG. i assume this is because the transmission holds the lower gears longer, letting the engine rev out each gear longer, consuming more fuel.
any other theories as to why this is? with gas prices on the rise, i will use the ECU reset for weekend canyon runs and track days. However, the boost it does give is not worth a 3mpg penalty for normal street driving IMO. I'll have to try to this reset for freeway cruising and compare the ECU's to see if there really is something else going on behind the scenes.
-Ken
Old Mar 4, 2012 | 06:58 AM
  #110
sjx's Avatar
sjx
Range Rover Autobiography, 04 Mercedes C32 AMG
Just tried this on my C32.. Definitely a massive difference. I've wondered for a while why it seems so laggy on occasion when IM the one who wants to play.. Thanks for the share
Old Mar 5, 2012 | 08:52 PM
  #111
AMG Sleeper's Avatar
2005 C55 AMG, 2010 VW GTI (Stage 1)
Originally Posted by ScottW911
Never had a single issue after MANY resets. You are just deleting the adaptions from the ECU memory. Worst case scenario=your car feels like it did the day it left the factory floor (also, that is the best case scenario).
same here!
Old Mar 27, 2012 | 09:24 PM
  #112
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
Just tried this for the first time and it works!! Thank you for sharing this with us!!
Old Mar 29, 2012 | 12:37 PM
  #113
Nachtsturm's Avatar
2015.5 Volvo V60 Polestar
Originally Posted by Newzchspy
Does this work on all AMG's. Will it work on my 2001 ML 55???
Glenn
Yes, it does.
Did it last night, and you could tell the difference.
Old Apr 15, 2012 | 02:45 AM
  #114
Acmar's Avatar
2004 E320
Does it work on a 2004 E320?
Hi! I'm new to this group and I've been learning a lot about my E320. Forgive me if this has been already answered but does this reset work on a 2004 E320?
Miguel
Old Jan 4, 2013 | 12:20 PM
  #115
rrohtake's Avatar
SOLD - 2005 C55
Awesome!!!
Since I adopted the baby, it's been little over month and I thought the car was supposed to be something like this. WHAT A DIFFERENCE!!! No more sluggish start.
Thanks!!!
Old Jan 20, 2013 | 04:09 PM
  #116
ssoutlaw74's Avatar
2003 c32 amg
Ok so i did the reset, it does work but now my check engine light is on? any one
else have this happin? any ideas the car is Not modded in any way
Old Jan 20, 2013 | 04:34 PM
  #117
ScottW911's Avatar
The reset and the light should not be related. The reset just overrides the user adaptions. It is probably just a coincidence.
Get the codes read and you will see it might be something so simple as a loose gas cap.
Old Jan 20, 2013 | 04:44 PM
  #118
ssoutlaw74's Avatar
2003 c32 amg
Thank you we did just put gas in it , and its only 10 deg out here in indiana
today lol. This is my first Benz and i love it so far .Just a obd2 right? nothing special? ill check it tomorrow and let you know. Thanks again this site really does help newbees have a good experience with these cars!
Old Jan 20, 2013 | 05:15 PM
  #119
ssoutlaw74's Avatar
2003 c32 amg
cyl 4 and 5 miss fire what now? coil packs plugs injector? car runs fine .i drive
a 200 mph race car i would think i would feel a miss fire?
Old Jan 20, 2013 | 05:21 PM
  #120
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
If it's running fine now just clear them. If they come back, you know you've got a problem.
Old Jan 23, 2013 | 08:21 PM
  #121
ssoutlaw74's Avatar
2003 c32 amg
Thanks to all that answered my call for help... I put new plugs and wires on it cleared codes car has 89k on it original plugs still(wow were they tight)so i figured if i was to pull them out to clean i should just change them.Car runs much better now.The bad thing is while in my shop i figured i should put wheels n tires on it and some carbon fiber to Wife didnt see it that way lol .Again Thanks to all and thanks for a great place to get info!!!!!
Old Apr 6, 2013 | 04:26 PM
  #122
pointman's Avatar
a car that can't do the throttle reset.
I feel no difference.
Old Apr 9, 2013 | 11:53 PM
  #123
pointman's Avatar
Help a noob out, cause I want this to work.. and I just don't feel it.
doors closed... turn key to where engine isn't running but all cluster is illuminated...
hold down throttle to the kick down for five seconds... turn key off... release throttle.. wait 3 minutes.
Am I missing something? Cause I read all the threads about this.. and I don't think I am.
Old Apr 10, 2013 | 12:17 AM
  #124
macbryanie's Avatar
Porsche 2004 911
Originally Posted by pointman
noob
lol.
Anyway: Is your comand off and the headlights switched off (not auto etc) ?
I only did the reset once so not much more input sorry.
Old Apr 10, 2013 | 12:42 AM
  #125
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
Mine seems to work fine, the only thing I have read that is different is some say 15 seconds throttle down. Be sure to leave the key in (but turned all the way anti-clockwise or OFF) for the 2-3 minutes of wait, then pull the key and 'exit the vehicle' is another one floating around
& i do always hear the ecu 'thinking' things through after this reset during the 2-3 min wait
then it usually tells me to kill john lennon
