Does the C32 have a bypass valve on the supercharger?
anyone know?
Thing is, you answered the question in that thread. Are you doubting yourself now?
Your C32 should not be sluggish under 3000 rpm. If it is, than you might have something wrong. Get a hold of OBDII scanner and look at data stream and error codes.
It goes through the bypass. Normally the bypass diaphram is driven from the manifold vacuum.
These C32 have positive displacement blowers, which always have a bypass. I suppose one could use a blowoff valve, if there is no MAF sensor.
why would the E55 have it and ours does not? is it not the same setup with just a smaller supercharger?
the E55 has a clutch for the supercharger and a bypass valve, fyi...
it would be nice if we could get a tuner to figure out a way to lock-in the supercharger sooner...
Even with a magnetic compressor clutch, at light throttle, deceleration, transmission shifting, damaging boost surge can happing causing damage to your engine. There must be some means of controlling over boosting.
Boost surge is when changed air is being forced into a closed throttle, until the pressure is higher than the amount of boost being created by the supercharger.
I can’t find any mention of a by pass valve in EPC and WIS programs, AMGs are consider euros in the USA and as such not be supported by theses USA programs.
According to MB a compressor squeaks is caused by “friction vibration on compressor coupling” meaning when the compressor clutch is engaging. Remedy “it is not allowed to replace the compressor when theses complains occur, this motor specific noise is state or the at, at best, replacement of these parts leads to a temporary solution of the problem and customer dissatisfaction will increase”
I wonder how many supercharger unrelated noises are being diagnosed as “compressor squeaks”, by MB techs, only time will tell.
C32AMG/02, save yourself some time and just please use search function. There are numerous pages on C32 tech and R&D on this forum going back to 2003.
It is correct. However, in most driving conditions you are rarely below 44% load.
Can it be changed? My guess yes. The problem is who is going to spend R&D time to locate the maps in the software and test them.
Vadim, do you need to hack the software or can you just create a "short circuit" on the solenoid that switches the clutch?
Downside, of course, would be that the engine could not protect itself if, for example, your intercooler pump died and intake air was too hot.
