2002 C32 Alldata subscription about to expire, anyone have questions?
My 2002 C32 Alldata subscription (sorry but it's limited to this car only) is about to expire, anyone have questions or need a copy of a TSR?
Hey Expat, I've noticed that, over on the C-class forum, someone listed all the TSB's for each model, with the exception of the C32. I do not know if your subscription will give you a list, but if we could see the TSB number with a brief description in a list format, that might be helpful by taking the number to the local dealership. Just a thought.
Vehicle Technical Service Bulletins
P-91_60-76C 060117 Restraints - SRS Lamp ON/DTC's 9103/9123 Set
P-82_30-366B 060110 Wipers - Chattering/Noisy After Blade Replacement
P-15_30-55A 051222 Starting System - Engine Will Not Start
P-09_41-22 051221 Engine - MIL ON/DTC's Set/Low Power Output
P-30_20-61A 051216 Engine - MIL ON/Limp Home Mode/DTC's Stored in Memory
P-54_21-119A 051213 Lighting - Tail Lamps Won't Turn OFF/Trunk Lamp Inop.
S-98_00-13L 051207 Body/Paint - Approved Refinishing Products
P-42_10-51D 051205 Brakes - Front Brake Squeal/Grind Applied or Not
P-80_57-38 051123 Interior - Memory Seat Moves to Incorrect Position
P-80_57-24A 051117 Antitheft System - DAS3 Diagnostic Procedures
P-82_70-475 051114 Cell Phone - Calls Cut Off/Dropped
P-77_10-24A 051014 Body - Sliding Roof Rattles/Water Leaks
2005030003 050501 Campaign - Lower Door Seal Modification
2005030005 050501 Campaign - Door Frame Corrosion
P-27_55-50A 050217 A/T - Harsh Engagement/Buzzing Noises
P-83_30-74A 050204 A/C - Musty/Moldy Odors
P-72_29-39A 050128 Body - Front Power Window Motor Locks Up When Closing
P-54_21-133 050126 Lighting - Trunk/Cargo Light Inoperative
P-82_10-398A 050126 Lighting - License Plate Bulbs Burned Out
P-27_60-43 050110 A/T - Rough Converter Engagement/Droning/Buzzing Noise
P-54_21-121 050110 Lighting - Brake/Park Lamps Flicker With Engine ON
P-32_25-19 041230 Suspension - Shock/Strut Replacement Guidelins
P-82_10-419 041230 Lighting - Condensation in Headlamps
P-30_30-61 041230 Cruise Control Inoperative
P-54_21-124 041230 Lighting - Headlamps/IP Lamps Flicker
P-54_21-126 041230 Power Locks - Central Locking System Inoperative
P-15_40-54 041101 Charging System - Insufficient Charging
P-27_00-47A 041011 A/T - 722.6 Oil Leaks From Electrical Connection
P-88_30-36 041008 Body - Scraping Noise From Transmission Tunnel Area
P-72_00-33 040917 Body - Front/Rear Window Knocking Noise When Operated
P-82_10-376 040917 Lighting - Xenon/Bi-Xenon Headlamps Not Functioning
P-82_20-370 040902 Lighting - Dome Lamp Won't Come On
P-33_15-15 040830 Steering/Suspension - Torque Strut Replacement Parts
P-82_00-260A 040825 Audio System - CD's Won't Play or Eject
P-42_45-23F 040819 Traction Control/ABS - Codes C1140/C1145 Set
P-68_20-29 040816 Interior - Console/Armrest Lid Rubbing Noise
P-83_00-70 040814 A/C - Inoperative/Codes Set/AC OFF Lamp Illuminated
P-91_60-65B 040722 SRS - Warning Lamp ON/DTC's B1035/B1037/B103B/B1039
P-77_20-26 040721 Body - Sliding Roof Excess Lift Control Feature
P-68_50-24 040601 Interior - Sunblind Chafe Guard/Loose
P-83_40-71 040412 Climate Control - Heating and Cooling Set-Points
P-46_20-16 040407 Steering - Leaks at Line/Rack Housing Connection
P-33_10-11 040407 Suspension - Rumbling Noise Driving Over Rough Roads
2003090005 040301 Recall - Excessive Emissions/ECM Re-Flash
P-00_45-77 040217 Interior - Squeaking/Creaking Noise Kit
P-82_95-305 040213 Emergency Contact/Alarm System - System 'Runaway'
P-07_00-28F 040204 Engine Controls - Lack of Power/Hesitation/MIL ON
P-33_15-10 040204 Steering/Suspension - Alignment Requirements
S-49_10-08 040201 Exhaust System - Rattling/Hissing/Humming Noises
S-01_30-15 040201 Engine - Cylinder Wall Damage Assesment
P-40_10-43 040116 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-47_10-27 040105 Fuel System - Fuel Filler Cap Hard to Remove/Install
S-18_00-16A 031201 Gasoline Engine - Oil Sludging
S-54_21-101 031001 Engine Controls - ECM Flash Process Change
P-82_60-292 030929 Audio System - Volume Knob Damaged
P-62_00-06 030922 Body - Water Leaks Into Front Footwells
P-82_85-288 030912 COMAND(R) System - Unable to Enter New Destination
P-32_20-17A 030729 Suspension - Front End Knock/Rumble on Rough Roads
P-27_19-35A 030724 A/T, Brakes, Traction Control - False DTC's Stored
P-42_45-19A 030724 A/T, Brakes, Traction Control - False DTCs Stored
P-82_85-264 030722 Navigation System - Inoperative/Erroneous Guidance
P-14_30-15 030702 Emissions - MIL ON/DTC P2003 Stored in Memory
P-82_10-195C 030701 Lighting - Front Turn Signals Inoperative
P-20_10-23 030507 Cooling System - Water Pump Leakage
P-47_10-26A 030402 Instruments - Incorrect Fuel Gauge Readings
P-82_70-222 030321 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-67_00-09 030307 Body - Windshield/Rear Glass Body Seam Corrosion
S-07_61-27A 030301 Engine Controls - ECM Reprogramming Procedure
P-80_57-20 030225 Audio System - RF Interference Explanation
P-46_20-10 030224 Steering Rack - Connector Leaks
P-32_25-13 030121 Suspension - Rumbling Noise From Rear Axle Area
P-82_10-217 030121 Lighting - Parking/Tail Lamp Bulbs Inoperative
P-83_55-65 021218 A/C - Compressor Cycles Frequently
P-82_85-210 021125 Navigation/GPS System - Various Malfunctions
P-77_20-18 021030 Body - Sliding Pop-Up Roof Reverses When Closing
P-82_62-169B 021028 Audio System - Various CD Player Malfunctions
S-82_70-135B 021001 Fiber Optics System - Configuration/Version Coding
S-82_85-205 020925 COMAND(R) System - Various Malfunctions
P-26_50-01 020903 M/T - Assembly Precautions/Recommendations
P-82_85-198 020725 COMAND(R) System - No Sound/Whistling
P-91_60-53 020719 SRS System - SRS Lamp ON/DTC's B1058/B2DB0
P-88_79-30A 020717 Body - Exterior Mirrors Move Slightly Over Time
P-18_40-18A 020716 Engine Controls - 'Engine Oil Level Above Max' Displayed
P-68_20-14 020516 Interior - Front Cup Holder Broken
P-32_20-10 020430 Suspension - Rear Axle Noise
P-80_35-16 020419 Interior - Seat Memory Key Assignment
P-47_10-25 020402 Instruments - Erratic Fuel Gauge Operation
2001100003 020301 Campaign - ESP Module Ground Connection Inspection
P-47_10-24 020226 Fuel System - Fuel Sender Identification
S-82_70-179A 020201 Cellular Phone - V60 Programming Instructions
P-07_60-16 020122 Engine Controls - Rough Idle/Hesitation/DTC's Set
P-83_30-58 020111 Automatic Temperature Control - Inoperative
P-82_85-181 011129 COMAND(R) System - Does Not Respond to Voice Controls
P-83_00-57 011115 A/C - Windshield Fogging in Center
P-47_20-20 011106 Fuel System - Replacement Fuel Pump Adapter Harness
P-80_30-13 011101 Smart Key(R) - Download Time
P-82_64-175 011011 Audio System - CD Changer Static/Interference
P-47_20-17 011010 Fuel System - Hard Start After Fuel Filter Replacement
P-40_10-33A 011001 Tires - Approved Winter/Summer Tires
P-27_60-34 011001 Brakes - Fault Code P2000 Explanation
P-82_62-168 010921 Audio System - Poor AM/FM Band Reception
P-82_85-171 010913 COMAND(R) System - Instrument Display Not Centered
P-82_85-170 010913 COMAND(R) System - Incorrect ETA Calculation Displayed
P-32_25-07 010901 Suspension - Front Axle Thumping Noise on Rough Roads
P-80_57-12 010830 Smart Key(R) - Intermittently Inoperative
P-80_57-11 010829 Ignition System - Electronic Ignition Switch Replacement
P-91_10-50A 010822 Interior - Noises From Front Seat Tilt Mechanism
P-91_10-51 010821 Interior - Front Seat Head Restraint Rattles
P-88_50-24 010816 Body - Trunk Lid Will Not Open
P-77_20-14 010816 Body - Panorama Roof Panel Won't Open or Move
P-91_60-48 010809 Air Bag System - Side Impact Sensor Replacement
P-62_10-02 010806 Body/Cooling System - Upper Radiator Mount Bolts Break
P-68_10-12 010806 Body - Noises From Right A-Pillar Area
P-72_10-21 010724 Body - Door Hinge Check Noise
