35mm Offset wheels don't fit c32 up front
Hey Guys, I just bought a set of 17x8 wheels all 4 have an offset of 35mm
I tried one on the front of my c32 and it hits the caliper, I believe the stock wheels have an offset of 37mm in the front, Does that mean I have to 2mm spacers? Or does it vary from wheel to wheel? Also where is the best place to purchase spacers?
Thanks Pete
Thanks Pete
'09 A4 S Line
Thanks Pete
Thanks Pete
Thanks Pete
Thanks Pete
Good luck
C55 ///AMG, 535xi
hey pete man! they dont clear the C32 brakes!?!?
I called tirerack and they said it fits the C32 too. sorry man.
try spacers. if not, I know another guy that want it and I can get u to sell it to him. let me know soon.
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Wheel off set
I think if you look in your owners manual. Purple section ,
tech data Tire & wheel. you will find the offset.
37mm Front ?
30 mm rear ?
37mm Front ?
30 mm rear ?
MBworld Guru
white and whiter
a simple clarification on offset for everyone that don't know.
If your wheels are et35 by adding spacers onto the wheels the offset decreases. I.E. et35 with a 5mm spacer makes the offset et30.
The smaller # the offset the more the wheel sticks out.
The right offset also doesn't mean that it would clear the larger calipers because there are many designs.
cheers
cheers
A 40mm or a 30mm offset could work if the relationship of the hub mounting surface on the wheel to the back side of the spokes was designed correctly. Many of the C Class wheels available do not fit the C32 due to the brake upgrade. Even if you got a 37mm offset wheel that matches factory spec offset, it may not fit due to this important measurement relationship. Time for some RENNtech's! And they even fit a monster BBK!!
MBworld Guru
white and whiter
name brands such as Brabus, Carlsson, Lorinser, RENNTech, Kleemann, AMG, all have their wheels designed to fit the BBK. Most of their closer copy replicas also can fit 80% of the time. You will want to start from there unless you are going with custom Forged wheels which they will make each wheel to your spec.
God damm, Iam being school with this old post again!
Looking for some Stocks or Aftermarket * cheap * clean looking wheels to sell my car. Thanks Fbones for the INFO !!!
