C55 Suspension Kit/Coilovers
Are Bilstein's the best or KWs and H&Rs? I was told by Evosport that H&R does not make a kit for the C55 and by Eurorev that KW doesn't either.
What's your custom suspension setup and are you satisfied?
He told me that if I don't do this the car's Geometry would be affected and the tires will Camber outwards.The Caster would also be affected negatively which woud prevent the wheels from automatically straightening out after a turn. Not even a $2,500 coilover kit would help handling, ride and performance without these other adjustments according to him.
Does anyone agree with him? If you had aftermarket suspension work on your AMG, did you REALLY feel an improvement in cornering, ride and performance? Or was it just comestic? Does your tires camber outwards? If it does then I think it would actually look worse than non-lowered stock.
alot of places do it for 150-200 at 75 to 100 dollars/hr
its roughly 2 hrs of labor with the proper equipment, not 5hrs. at most 3hrs.
if they told me it was 5 hrs of labor id watch them for 5 hrs and see what the hell is taking them so long.
The point about the steering wheel straightening out, he's just saying that you'll loose caster but that'll only make the steering more agile/sensitive at lower speeds and lose some of that high speed stability. I doubt this will do anything devastating to the car...if anything I wish I had less caster for around-town driving.
I think the norm thinks less roll = better handling but you will never know if the handling improved unless you hit a racetrack and see the laptimes and feel for youself how the car has changed to different driving inputs.
I really wouldn't worry about it if I were you...but warranty issues is another story....
in regards to the drop spindles, I have no clue whatsoever
The camber can be easily adjusted by replacing it with either the K-MAC (addtional toe adjustment) or speedybenz Camber arm.Call us if you need any further assistance.
Regards
Darwin W
Regards
Darwin W
