Stock C32 'clunk' when I back out each morning.
Anything I can look for that's obvious?
Thanks for any guidance!
Bif
How can I test this, what would be the fix?
If everything is stock then I would try some cheap fixes first...Disassemble & clean both sides of the rotor with 200 grit sandpaper to remove any and all traces of oils. Wash the rotors and pads with LOTS of soap and water to remove all residue.
After everything is dry, use a high-quality copper-based brake grease on all the moving non-friction parts. Make sure the reassembly is done exactly per the shop manual.
The problem could be coming from the rear of the car... did you adjust the parking brake? Verify functionality of the PB mechanism.
If the parts you used are not 100% stock then I would consider fitment and materials issues. It is possible that your new pads/rotors are not an exact replacement for your stock parts. Different metals in the pads & rotors cool/heat/oxidize at different rates. This could be as simple as your pads are rusting to the rotor at night or that your pads are not bedded yet and are still in the break-in period.
As a last resort make sure to check all your suspension components for looseness, leaking, and wear.
