need help...(power window)
i have a problem with my c32 2002.
the power window at the driverside(front) stopped working this morning...all the other power windows are working fine.
whats wrong?
i have checked the fuses and they are fine...
i can her the "klick/engine" sound when i push the button but notthing happens.
plz... help me guys... hope you can understand my bad eng.
/Fredrik
It worked for me.
If it doesn't work, take it to the dealer to get fixed.
"Found internal malfunction of LF door control module .... replaced door control module and version coded rechecked, Now found proper operation)."
Part # 203-820-15-85 Control Unit.
Also checked the switch and relay, which were both fine.
way to get service manul documentation. It is $24.95/year. There is info
on the window, window regulator, window motor, switches and electronics.
http://www.alldatadiy.com/index.html
If the window is up, the hardest thing to do, is remove the door panel, since this is normally done with the window, down. I don't know how they got it off, with the window up. Maybe they tilted it up and disconected the window regulator cable?
The website http://mbklasse.com/ probably has the most info
on DIY and door panel removal.
The most likey cause of malfunction are:
Fuse
Switch
Motor
My car had a failed motor, so your may have the same problem. The motors
are specific to specific chassis, so you may need the numbers off your motor to get a new one.
