do u have damaged thrust arm bushings??
Old Sep 20, 2006 | 07:29 AM
AWDman's Avatar
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
last visit to dealer my front thrust arm bushing were found to have deteriorated with the hydraulic fluid leaking out. will be replaced under warranty. curious if this prob is endemic. take a look, evidence of the leaking fluid should be easy to see. if not damp then look for brown stains.
Old Sep 20, 2006 | 08:24 AM
Bif powell's Avatar
2002 c32
I had this problem about 7k miles ago as well. Replaced under warranty.
Old Sep 20, 2006 | 08:55 AM
Fifth Ring's Avatar
C32 AMG
Just replaced under warranty at 39,000 miles. No symptoms, just something that they found.
Old Sep 20, 2006 | 09:50 AM
silver_metallic's Avatar
2016 C63S,2013 C63 AMG Coupe, 2002 C32 AMG (gone but not forgotten)
this is another common c32 problem. I have it too, just haven't fixed it yet.
Old Sep 20, 2006 | 10:35 AM
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
where is this on the front of the car? I need to inspect it any one have a picture
Old Sep 20, 2006 | 10:40 AM
Vomit's Avatar
2002 C32 Black/Charcoal
Hey AWDMan, you have a pretty eclectic mix of vehicles there. Never seen a Suzuki Swift and a 355 GTS in the same garage.
BTW, how does the 355 run against the C32? How bout a vid?
Old Sep 20, 2006 | 11:07 AM
CynCarvin32's Avatar
Mercedes Benz
This is a common flaw for all W203 cars. There is a new revised version of the bushing and often the dealerships replace the bushing when the part is not truely failed or totally leaked out. If you really had a bushing where the liquid had drained out in total, the car would have a very bad vibration at speed and a pronounced knocking sound over all bumps.
I have gone through dozens of front control arm bushings in the last few years on various W203's and you can have different states of broken bushings. Be happy that they found the issue and that they are fixing it for free!
A friend of mine just took her 2002 C32 in for an A service and while the car was in, they found the bushings were failed and replaced them while she waited. She told me the car was loud over bumps but I figured she was just hearing things. Now I need to give her more credit for she had a pretty good ear to hear the broken bushings! =)
Old Sep 20, 2006 | 11:21 AM
amgmark's Avatar
ML63
I had this done at about 88k miles.. I am sure that it was a problem way before that though.. The first dealer wouldn't fix because of my Brabus suspension. The second dealer knew this was a common problem and fixed it under warranty.
Old Sep 22, 2006 | 08:31 AM
AWDman's Avatar
hey vomit.
the swift gt is close in character to the ferrari. the way the power is delivered i mean. i've had 3 stiill have 2 truely a cult classic car. you have to drive one to appreciate.
the c32 is quiet power, slips through the air without drama. the f355 on the other hand, top off, is a screaming flat plane delight for the senses.
i'm glad to see others with the bushing prob. i thought it was the beating from the bumpy tracks i run on. i apparently get the inside front tire completly in the air on some turns d/t the g loading and bumps.
Old Sep 22, 2006 | 10:54 AM
alterego's Avatar
Black 2002 C32 AMG
Just replaced under warranty at 45,000 miles. No symptoms, just something that they found and fixed.
Old Sep 22, 2006 | 11:17 AM
Fifth Ring's Avatar
C32 AMG
Originally Posted by AWDman
hey vomit.
You, my friend, are the "canary in the coal mine" for the rest of us. If it doesn't break on your car, it ain't gonna break!
Akin to your Swift GT, one of my favorite cars was a Mitsubishi Cordia Turbo. For it's time, it was a great car, and great looking. Unfortunately, it never developed a cult status, unlike the Starion which was a Supra-killer. One thing that impresses me to this day is that the wheels had a "turbine" pattern, and the pattern was reverse left-to-right, so that the vanes each side were spinning the right way.
Old Sep 22, 2006 | 12:57 PM
AWDman's Avatar
canary in a coal mine- i just so happen to have zeneyatta mondatta in my cd changer!
my 1st gen 3000gts had the directional wheels as well. can't remember if the 2 talon tsi awds i owned had 'em as well.
Old Sep 22, 2006 | 01:11 PM
madblznguy's Avatar
C32 AMG
WARRANTY AT 88K?
Old Sep 22, 2006 | 01:24 PM
AWDman's Avatar
88k is within starmark.
Old Sep 22, 2006 | 02:15 PM
amgmark's Avatar
ML63
Originally Posted by madblznguy
WARRANTY AT 88K?
Yup.. Starmarked til 100k.. Only have 3k more miles left since I am now at 97k miles. The car seems to be running better than ever though.. I think just about everything that was an issue or would have been an issue has already been fixed.
I not only had the bushing replaced, but the arms too.. + a few other seals and bushings..
Old Sep 22, 2006 | 02:28 PM
AWDman's Avatar
mine seems to be at it's best on the drive home after a few hrs worth of track exercise! "thank you, master, for allowing me to stretch my legs" she whispers into my ear.
Old Sep 22, 2006 | 05:10 PM
benzmodz's Avatar
W203 slightly modified
These were mine after 40,000 miles.
I did the following to the front end.
- wheel bearings
- bushes
- sway bar bushes and clamps
Old Sep 22, 2006 | 05:17 PM
Vadim @ FD's Avatar
S600TT, R350
I had mine done at 23K and 78K. Now at 113K they are going out again. I have been trying to have them made, but so far no luck. I might have to go with stock ones again.
Old Sep 24, 2006 | 11:40 PM
Eurocharged Rick's Avatar
SPONSOR
i had mine done at 95,000
Old Sep 24, 2006 | 11:54 PM
pointman's Avatar
a car that can't do the throttle reset.
you guys drive your c32's alot.
Old Sep 25, 2006 | 02:48 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Would failing bushings cause a "clunk" all the way up through the steering wheel? Mine has been transmitting a definite thump or clunk up through the wheel as I am making slower speed turns, such as making a right turn onto a street from a signal. It has been doing this for about a week now and is starting to concern me.
Old Sep 25, 2006 | 03:49 PM
dchao's Avatar
C32 AMG Maserati Coupe GT
Mine was done at 35K
There was no noise (yet), found hydraulic leaking during a regular service visit, and replaced. (Don't forget SF and Bay Area have some of the worst streets and freeways in the country!!! )
Old Oct 1, 2006 | 12:09 PM
AWDman's Avatar
just came back from SF and yes pretty bad. almost like NYC...
last week my dealer replaced my bushings and also the front wheel bearings. i'll keep checking periodically see how long the new bushings last.
Old Oct 2, 2006 | 11:49 AM
Blake P's Avatar
'09 A4 S Line
Pretty sure the noise I've been hearing lately from the front driver side is damaged bushings.
Old Oct 4, 2006 | 01:54 PM
andy_cyp's Avatar
Obsidian E55
You must all be driving my car, because thats the noises and thumps ive recently aquired at 55k.
Its due for an A service on the 16th this month so ill guess ill have to tell what else to look for then.
thx guys
