C32 TSBs
Old Dec 28, 2006 | 06:46 AM
  #51
AWDman's Avatar
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
Originally Posted by AWDman
Bif can I get this?
P-88_50-24 010816 Body - Trunk Lid Will Not Open
Thanks.
Bif can you do this for me pl.
Old Dec 28, 2006 | 10:10 AM
  #52
Bif powell's Avatar
2002 c32
Hey, sorry for the delay guys - will post these up tonight when I get home.
Old Dec 28, 2006 | 02:31 PM
  #53
AWDman's Avatar
Thanks Bif.
Old May 27, 2007 | 10:43 AM
  #54
Bif powell's Avatar
2002 c32
This one's for: hkycoldrct - sorry it took so long.
Engine Controls - 'Engine Oil Level Above Max' Displayed
Date: July 16, 2002
Order No.: P-B-18.40/18a
Supersedes: P-B-18.40/18 dated June 28, 2002
Group: 18
Revision: Correction to Model Designation
SUBJECT:
Models W/S 203
Display in Instrument Cluster Indicates "Engine Oil Level Above Max." While Driving
If you encounter instances in Model WIS 203 vehicles up to VIN A292753 and up to VIN F222639 where the display in the instrument cluster indicates engine oil level above max." while driving, please refer to the following possible causes / remedies.
Cause 1: The oil level check indicates Reduce Oil Level"; also when checking with oil dipstick part no. 120 589 07 21 00, oil level is too high.
Remedy 1: Correct oil level.
Note :THE SPECIFIED OIL FILL CAPACITY, WITH OIL FILTER CHANGE, OF ALL US-VERSION
W1S203 (including higher serial nos.) IS REDUCED FROM 8.0 LITERS (8.5 QUARTS) TO 7.5 LITERS (7.9 QUARTS).
Cause 2: Incorrect oil data record. The oil level check indicates "Oil Level OK". Also oil level is OK when checking with oil dipstick and no oil sensor error is stored in the DTC memory of the engine control module.
Remedy 2: Load modified FSS data record. If code read out is set to Not Coded", select corresponding engine model and confirm.
Note :The modified data record is obtained as of DAS CD version 2/02.
Cause 3: The oil level is OK but with oil level error stored in the DTC memory of the engine control module.
Remedy 3: Replace oil sensor. For procedure, refer to WIS document no. AF18.40-P-2402A.
Old May 27, 2007 | 10:54 AM
  #55
Bif powell's Avatar
2002 c32
Bif can I get this?
Thanks.
Date: August 16, 2001
Order No.: P-B-88.50/24
Supersedes:
Group: 88
SUBJECT:
MODEL 203
TRUNK LID DOES NOT OPEN
If you encounter instances where the trunk lid on model 203 vehicles cannot be opened using the remote control key (A8/1), the interior trunk lid release button (S20/1s6) or the trunk lid outer handle (S88/8), please note the following. The trunk lid can only be opened mechanically, by turning and holding the mechanical key in the trunk lock 45 degrees to the left and then pulling the trunk handle.
This may be caused by a rotating part in the electric motors gearing becoming jammed, preventing the trunk lid from opening electrically. The trunk lid locking mechanism is opened by an electric motor with gears. It is actuated by a microswitch in the handle which signals the locking mechanism's motor. A cable is used only for mechanical emergency release of the trunk lid lock.
To resolve this complaint, install a new lower section of the lock with the cable indicated below. Do NOT replace the opening handle (upper section of lock), as it is not affected by this condition.
Service Engineering
DRdg
8-16-01
Parts: Lock with Cable
203 750 01 84
Old Jul 26, 2007 | 03:57 PM
  #56
m3_eater's Avatar
Could someone post this TSB for me? Thanks.
P-82_10-195C JUL 03 Lighting - Front Turn Signals Inoperative
Old Jul 27, 2007 | 04:40 PM
  #57
m3_eater's Avatar
EDIT: never mind. I took the TSB title/name to the Mercedes-Benz service tech and they found it. Service was performed today and worked like a charm! I love this website
Old Aug 27, 2007 | 11:34 AM
  #58
stef64's Avatar
1999 SLK230, 2002 AMG C32
SRS Light
Would you please post the details on the following?
P-91_60-53 020719 SRS System - SRS Lamp ON/DTC's B1058/B2DB0
and
P-91_60-65B 040722 SRS - Warning Lamp ON/DTC's B1035/B1037/B103B/B1039
I just found this thread, thanks for the great information.
Old Aug 28, 2007 | 10:36 AM
  #59
Bif powell's Avatar
2002 c32
and
Date: July 19, 2002
Order No.: P-B-91.60/53
Supersedes:
Group: 91
SUBJECT:
Model 203, Model Years 2001 and Later
SRS Light On, Code B1058 and B2DB0
If you encounter instances in the subject vehicles of the SRS malfunction indicator lamp on and code B1058 and B2DBO is stored, replace the SRS Control Unit. The new version entered production as follows:
203 as of A362054
203 as of F278597
The spare part is available approximately June 2002, the part number remains unchanged.
SRS Control Unit - 001 820 97 26
Old Aug 28, 2007 | 10:40 AM
  #60
Bif powell's Avatar
2002 c32
and
Date: July 22, 2004
Order No.: P-B-91.60/65b
Supersedes: P-B-91.60/65a dated January 9, 2004
Group: 91
Revision: Procedure Update - Return of connectors no longer necessary
SUBJECT:
Model 203
All Model Years
SRS Indicator Lamp On
If you receive customer reports in the above model vehicles that the SRS light is illuminated and diagnostic fault code(s) B1035, B1037, B1038 and/or B1039 are stored in the SRS ECU, the resistance in R12/11, R12/12, R12/20 or R12/21 ignition circuits for the sidebag squibs may be too high. This high resistance is caused by either of the following:
^ The left front door separation point connector X35/1,
^ The right front door separation point connector X35/2,
^ The left rear door separation point connector X35/3
^ The right rear door separation point connector X35/4.
To resolve, remove connectors from the wires for sidebags in the left and right front footwells and the left and right rear entryways and connect wires directly. Please follow the below procedure to repair.
Note :Always perform procedure on all 4 connectors.
1. Remove ignition key.
2. Remove A-pillar paneling in front foot well and door sill molding. Remove left front floor covering per WIS document AR68.20-P-2050P and right front floor covering per WIS document AR68.20-P-2070P.
3. Remove left and right rear door sill molding.
4. Expose wiring harness. Figure 1 shows connector for front doors X35/1 (left front door separation point) and X35/2 (right front door separation point). Wiring for rear door connectors X35/3 (left rear door separation point) and X35/4 (right rear door separation point) are similar. Wiring diagram of airbag control module with integrated E-call system can be found in WEB ETM document 91.60-U-2101FA.
5. Remove connectors and connect wires directly with solder connectors.
a. Cut line approx. 10 mm in front of and behind connector.
b. Remove about 20 mm of fabric tape on the control unit side.
c. Strip about 15 mm of insulation from the wire.
d. Slide solder connector onto wires.
e. Twist both wire ends together, observing the wire color assignment.
f. Position solder connector in the middle and shrink it on (solder) using a heat gun.
Utilize wiring harness repair set 220 589 02 99 00 and heat gun part no. 458-HL1802E via the MBUSA Standard Service Equipment Program.
g. Inspect solder connection.
h. Tape up both ends of the wires.
6. Delete fault memory with STAR DIAGNOSIS.
7. Install in the reverse order.
Old Aug 29, 2007 | 09:58 AM
  #61
stef64's Avatar
Thanks I appreciate your help.
Old Aug 20, 2008 | 02:26 AM
  #62
pointman's Avatar
a car that can't do the throttle reset.
I know this is an old thread, but any chance I can get more info on this one? Also, any place to score details on tsb's? Google didn't show nearly as much detail as this much thread.
P-32_20-17A 030729 Suspension - Front End Knock/Rumble on Rough Roads
Old Jun 17, 2009 | 03:55 PM
  #63
Wanda's Avatar
AMG C32
TSBs
Hi,
I would be interested in the following TSBs:
P-54_21-124 041230 Lighting - Headlamps/IP Lamps Flicker
P-82_10-376 040917 Lighting - Xenon/Bi-Xenon Headlamps Not Functioning
BR/Wanda
