just found out about my headlights
Old Oct 13, 2006 | 07:16 PM
c32used's Avatar
LET C32 2002
well i had bought back in 04 a new c230k with the bixenon option. well i got two months ago a 2002 c32 and since it had the same lights i thought they were bi xenon like the picture but recently found out they r halogen lights instead. i can't believe this car was going for almost 50k back then and no factory bi xenon installed. well i just got two 8000k carlab xenon bulbs and they dont fit cause my car doesn't have xenons.........anyways i need a cheap resolution to this.........i wanted to know if anyone modded there factory halogen to bi xenon and the website an cost please. i will also do a search. i feel like an idiot but i guess its called a lack of knowledge in the buying department.
P.S. SORRY CANT FIND A WAY TO PUT UP PICTURE HERE IS A LINK FOR MY POST A WHILE BACK WITH PICS
https://mbworld.org/forums/c32-amg-c55-amg-w203/157373-finally-got-c32.html
Old Oct 13, 2006 | 07:57 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
check your Halogen bulbs spec and buy a HID kit for that spec. Problem solved.
Old Oct 13, 2006 | 09:34 PM
c32used's Avatar
LET C32 2002
ok where can i get a kit? and if i follow that route i presume i should return my carlab 8000k xenon bulbs? I already talked to them and they told me to send bulbs back and they will return my money.
Old Oct 13, 2006 | 10:23 PM
ellery's Avatar
2003 C32 AMG BLACK
doesn't carlab sell HID kits as well? But in any case, I've bough several kits from xenondepot.com and they're very high quality. There's also a guy in the 3si.org forums selling hid kits for $200 shipped with a 1 year warranty.
http://www.3si.org/forum/showthread.php?t=343320
Good luck
Old Oct 13, 2006 | 11:54 PM
c32used's Avatar
LET C32 2002
Good luck
I DIDN'T CHECK BUT I THINK THEY DO.
Old Oct 14, 2006 | 12:57 AM
jgsx's Avatar
04 C32
Talk to car lab.
They sell HID kits. Return your xenon bulbs and buy a h7 hid conversion kit. problem solved.
Old Oct 14, 2006 | 01:34 AM
c32used's Avatar
LET C32 2002
Originally Posted by jgsx
Talk to car lab.
I WILL CALL THEM ON SATURDAY LATE MORNING OUR TIME AROUND 11AM SHOULD B 9AM THERE. THANKS GUYS I WAS IN ANGER OVER THIS AND U GUYS BROUGHT ME BACK TO A AND STATE OF MIND.
Old Oct 14, 2006 | 02:10 AM
raymond g-'s Avatar
99 E320
i dont think you should buy any HID rebased H7 kit until you see a wall shot
of the beam and the resultant cutoff. not all halogen lens and projectors are
made alike, yet the HID kit professes to fit all (in this case) H7s w/o modification
which is cow dung. Lenses are cut and spec-ed for a specific focal point and in
this case, what is being proposed is to substitute an HID bulb in place of a halo-
gen bulb. There are very few rebased kits which can be made with little loss of
quality...or that the rebased add-on doesn't result in some degree of uncontrolled
glare. that's why i'm suggesting that you try to see a beam photo first...based
on your headlight. the other option is to make the purchase contingent upon
proper performance. ie if glare is predominent, then buyer should be able to get
refund w/o incurring restocking fee.
sorry you had to go through this purchase and only now finding out that your
headlights were not as expected. good luck.
Old Oct 14, 2006 | 08:58 AM
c32used's Avatar
LET C32 2002
THANKS DUDE! I WILL SEE WHAT WORKS BEST.
Old Oct 14, 2006 | 12:46 PM
jgsx's Avatar
04 C32
bixenons weren't out yet
Old Oct 14, 2006 | 01:34 PM
raymond g-'s Avatar
99 E320
bix wasn't available for me either, but I lucked out: when examining the insides
of the Depo clear lens headlight shell, the mounting points for the projector were
amazingly close to E55...off by .25". so with advice from others who have done
this, I pulled out the halogen projector and dropped in the bix projector from the
E55. one of the easiest HID mods around of all autos.
natch, since it was an HID projector, the focal point was intact. I was able to
switch from fluted to clear lens and the look was given 10 yr upgraded in looks
alone. the improved lighting adds a kaa-kaa grin when night driving.
oh, this was for 99 and 00 E320, just for clarification. if you're similar lucky,
you can try same for your headlight. will require exam and measure of projector
dimensions. then go to HIDPLANET.COM and view their HID UNIVERSITY forum
for specification of many HID projectors. find one that come closest.
first mod took me 2+ weeks because I didn't know what I was doing. lots of
sketching and thinking between steps. the next retrofit took 24 hrs. i'm
in the middle of another one, fitting an RS6 bix for E320. should provide a
better color at the cutoff.
Old Oct 15, 2006 | 12:13 AM
Moviela's Avatar
Why get a kit when for a few more bux you can get real Bi-xenon from MbenzNL.com?
Old Oct 15, 2006 | 01:18 AM
c32used's Avatar
LET C32 2002
i been emailing him............waiting on his response on this matter and his suggestions
Old Oct 15, 2006 | 11:47 PM
c32used's Avatar
LET C32 2002
ok i know his pricing just waiting to hear from carlab on their hid kits. with the oem i have the option of using the auto leveler but need extra work for that since two sensors have to be placed. but when i emailed mbenxnl he told me that they dont usually install the sensors so the auto levelor wont be used. lets see what happens..........i will research best i can and thanks for all the info guys.
Old Oct 15, 2006 | 11:48 PM
c32used's Avatar
LET C32 2002
also going oem with mb or mbenznl its over 1k not including install.
Old Oct 16, 2006 | 02:43 PM
Eurocharged Rick's Avatar
SPONSOR
you might want to see if there is someone local to you that can help you out with the install...do you know of anyone with a Mercedes C-class that knows how to install the bi-xenons? might want to check in the C-class section as well if you don't, most of the guys on here are pretty good about helping each other out...
i am going to install mine myself, it is just a matter of removing the bumper...then for you, you would just need to have the xenon preset changed in the computer...
Old Oct 17, 2006 | 10:11 PM
c32used's Avatar
LET C32 2002
ok a kit is alot cheaper and installation sounds very easy.
Old Oct 17, 2006 | 10:18 PM
SPONSOR
sounds like you found your solution...
Old May 30, 2007 | 01:44 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Just received a call from FedEx requesting a completed HS-7 declaration to pacify Customs/NHTSA and allow for importation of my lights from Steve. What a buzz-kill!
Maybe the Feds will just look the other direction, or perhaps I can qualify for amnesty! Any of you have to jump through similar hoops to get your hands on the goods?
**EDIT**
Heard back from Steve/Wanda. Apparantly the HS-7 is SOP. It's been handled. Sunday morning in the garage begets Sunday afternoon cruise with a decent mod. Finally! Thanks MBenzNL.
Old May 30, 2007 | 02:29 PM
c32used's Avatar
LET C32 2002
Its definetly alot cheaper though I would have prefered OEM but all I had to do was order lights and install my Carlab HID 8K kit thats all. My car is in for repairs so all they have to do is install lights if MBenZL sold his products for 6 or 700 I would have bought them. I had to replace my Depo anyways cause both lights adjustment screws were broken. The Carlab 8K HID kit is already installed. The repair were sort of paid for so buying Depo housings with HID kit is a better way to go if one isn't looking to spend alot.
