Some CF engine pics!!!
What does your C55 feel like now compared to stock?
I'll probably start with the Quaife LSD and all SuperSprint headers when they become available.
The LSD is a great add on even if your car is stock. The car launches faster and you can definitely corner and pull sharp turns better with it.
Anyway, I thought you were a kleemann nut? You might cause a disturbance in the force
if you get a Renntech part.
Just curious which shop did you get your stuff done? Hoping to get my car back withing the next couple of weeks. Let me know if you wanna do some runs just for fun. Need to "break-in" the new mods.
$4500 for these "headers"....i'd have thought long and hard before buying them. They don't look much different from the stock exhaust manifold design. Two of the primary tubes join far from the leadout flange. And one of the primary tubes is extremely short. It doesn't look like those Renntech headers even have collectors. They just cut 1.5" tubing and joined them together to the leadout flange with no collector.Renntech V8 headers
$1500 for overlaying the airbox....no more comments. Although, you can't beat an almost free engine overlay in carbon/kevlar weave....
In comparison, these Kleeman V8 headers look alot better designwise. And they sell 'em for about $900 less than what you quoted for those Renntech headers. Each primary tube has it's own path to the 4-1 collector. Better design = more HP gain. They're not as good as long tube equal-length headers, but still better IMO than the Renntech design.
Kleeman V8 headers
BTW, Evosport V8 headers are also very nice.Last edited by pshek; Nov 8, 2006 at 02:16 AM. Reason: fixed link
Just want to apologize for crapping in RawAMGpower's thread. I have IBS and I forgot to take my Zelnorm this morning. j/k
Should I post a picture of the stock headers they look nothing alike. All RENNtech headers are hand built from mandrel-bent stainless steel seamless tubing and CNC machined stainless steel flanges. By utilizing computer aided design, these headers provide and average gain of 25 horsepower and 25 ft-lb of torque. Plus they are covered for the remainder of your cars warranty or for two years, which ever is longer. Also these are the only headers on the market that offer true bolt-on installation by mounting directly to the OE down pipes.
Your an idiot
if you think the box is an overlay its solid carbon fiber and larger then the stock box so it holds much more air volume.Kleeman V8 headers
You bought the Renntech headers over the Kleeman header because a small number of people had a crack in the Kleeman header? Rock's E55 had a crack in his Kleeman headers and they were replaced by Kleeman. FYI, any header can crack, even the heavy stock exhaust manifold can crack because of environmental circumstances. Nobody can guarantee that a SS header won't crack or fail at some point. If you think your Renntech headers are better then so be it, especially since Hartmut must know everything if he was the Ex Tech Director of AMG. You are correct, the Kleeman headers do require downpipe modification, but you do not need to install high flow cats to use the Kleeman headers.
My idiotic mistake on the airbox.
I had it confused with the front engine cover.I have no credentials in engine building or design. I only spent 4 months and about $15,000 building a new AMG motor. I just wanted people to know that header design can vary by a large degree, and nobody's opinion of them is always the same.
