View Poll Results: tire options; best performance?
Bridgestone SO3
6
13.33%
Michelin Pilot Sport2
19
42.22%
Yokohama Advan Neova AD07
9
20.00%
Pirelli P Zero
6
13.33%
Conti Sport Contact 2
5
11.11%
Voters: 45. You may not vote on this poll
tire choice: which one would you choose
Old Nov 21, 2006 | 05:28 AM
AMGV6K's Avatar
C32 AMG
moving on from the Yokohama AVS ES100 which is quite satisfying and has less than 20% tread life now
im buying new tires and the options are as above poll
what would you choose?
Old Nov 21, 2006 | 06:39 AM
Quicktwinturbo's Avatar
CLS, SLK, ETC
BFG G Force - KDW
Got mine yesterday.. Price is reasonable too... great traction
but then if u wanna go all out, get the bstone so3
Old Nov 21, 2006 | 06:46 AM
AMGV6K's Avatar
C32 AMG
yup going all out here...cost no object...if only the Advan A048 semi slicks were street legal
Old Nov 21, 2006 | 07:24 AM
AMG_55's Avatar
mymbonline
michelin pilot cup???
pirelli corsa???
Old Nov 21, 2006 | 07:43 AM
AWDman's Avatar
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
i run these tires for my track days. they will not work for street as they hum loudly above 20 mph also the soft compound is easily damaged by rocks etc gouging into the rubber. tire rack was not too entused about the a048 as well. i'm starting to feel the same.
best tires- advan ad07 or new bridgestone 01r. best bang for buck is s03 if on closeout. this tire has a stiff sidewall, i had them on my 3000gt vr4, worked great.
guy i know (c55 owner) ran all summer -street and track on pilot cups. only now corded fronts after 8 track events.
Old Nov 21, 2006 | 07:55 AM
AMG_55's Avatar
mymbonline
i ran a032r's on a daily driven e36 m3. lasted me about 2500mi, never tracked
drove w/ them in the rain too
Old Nov 21, 2006 | 08:13 AM
AWDman's Avatar
a048 may work for a 1950 lb exige but not for c32/55!!!
btw the elise runs on the yoke ad 07s.
Old Nov 21, 2006 | 05:22 PM
Al Bundy's Avatar
'10 GLK 350 Capri Blue/Black
The BFG G-force KDW's are junk, I had them on my S2000 - they will last you about 8,000 miles max on the back, even less if you drive in cold weather!!!
You're right about the Bridgestone S-series though. I had S-02's on the S2000 originally, and they were sticky as hell. Great tires, just don't try driving in any kind of slush or snow with them.
I was a lot happier with the Kumho ECSTA/ASX's I replaced the KDW's with. They lasted a lot longer and their performance was pretty comparable. About half the price too, perfect tires for winter.
I have Conti's on my C32, wasn't planning on changing for winter this year, I'm just going to take the CTA bus instead.
Old Nov 21, 2006 | 05:27 PM
CynCarvin32's Avatar
Mercedes Benz
pirelli corsa???
If you plan to track the car (an MB) do not use the corsa. After 1 session the tire totally fell apart. The interior cords ruptured, and the tire slowly lost pressure and was flat by the time we got back to LA from Palmdale. The side wall could not take the stress even though it was an XL rated tire. This is actually normal for this tire and unless set for that tire the car can easily kill the tire in under 20 miles of track use.
They ride well, look great, have wonder traction...BUT they fall apart when used on a car with little camber. They pretty much do not work unless the car has more than 2 degrees of negative camber.
Sport Cups do not have this issue but for a street car not the best idea.
I would go for a set of PS2's since its the best all around tire IMHO.
Old Nov 21, 2006 | 05:31 PM
Mercedes Benz
From what I have seen the 01R is not that impressive or at least it is not what I expected out of that tire. It is like a Falkin Azinis 615. Good for hard street use but as a track tire it gets over heated, starts slipping, and falls apart. Just tried a set of Falkins for track use due to its very cheap price and it was junk. No traction at all... 2-3 seconds slower than a set of Dunlop Super Sport Race tires that were molded in 2001 and past their prime age wise.
Old Nov 21, 2006 | 06:30 PM
ClayJ's Avatar
ON PROBATION
I agree, completely.
Old Nov 21, 2006 | 09:47 PM
CLS, SLK, ETC
http://www.tirerack.com/tires/tires....ce+T%2FA+KDW+2
Which KDWs did you have?? I was talking about KDW2..
I've been hearing only good things about these tires and this is what I have on right now..
I've tried S02.. Very sticky indeed and pricy.. It only lasted 8000ish miles on my rx7.
Kumho is afforable yet high quality tires.. lasted about 15000 on my Supra.
If money is no object, consider pilot sport competition rad.
Check out tirerack and compare them aroudn a lil
Tire ranking
http://www.tirerack.com/tires/surveyresults/index.jsp
http://www.tirerack.com/tires/survey...y.jsp?type=UHP
http://www.tirerack.com/tires/survey...ay.jsp?type=EP
good luck
Old Nov 21, 2006 | 10:32 PM
AMGV6K's Avatar
C32 AMG
grippier tyres tend to have shorter life doesn't it? it sucks
Old Nov 22, 2006 | 11:37 AM
Al Bundy's Avatar
I wasn't aware of the KDW2 - I'll bet that they made some substantial improvements over the originals that I had. Got mine back in '03.
I just can't see spending that much on tires when the Kumho's are only $98 each and they handle better than the KDW's in the snow too. Maybe they'd be closer to the BFG KDWS instead.
When I say 'handle better in the snow', I'm talking about installing them on the S2000 with no ESP & a 6-speed, obviously a much lighter car than the C32 as well. That car had horrible traction problems in anything other than perfect weather. I really hope the C32 is better, but it seems that my ESP is correcting me all the time.
Z-rated tires just wear out too fast for their price...
Old Nov 22, 2006 | 11:54 AM
AWDman's Avatar
i found the s02s to be a bit greasy on my s2000. looped the car a few times.
kdw =Dry Wet why use in snow? for the lightweight s2000 you need real winter tires. the torsen LSD will get you through; as i understand from posts on s2ki.com i didn't end up running mine in winter.
my c32s front ps2s are going strong. 20K+. one rear got damaged but the other is not yet down to wear bars.
i think it was reeves callaway that said "the car and driver are there to make the tires work". don't skimp. it's almost a life and death issue. one day you may need to get on it to avoid an accident and the big drilled rotors will be no help if you don't have high coefficient of friction between the you and the road.
Old Nov 22, 2006 | 02:09 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Originally Posted by Quicktwinturbo
BFG G Force - KDW
This is exactly the kind of post I can't stand. You got the tires yestarday, now you are an expert on them? You haven't even worn the tires in.
If people are going to comment on tires, it is far better to talk about what tires you have had in the past, and what you have now.
I have run three sets of performance tires on my Coupe. Coming from the stock Michellins I went to the Bridgestone RE750. The tires were quite loud on pavment, but had a good wear rating. However, I ran into two rear right flats. On the second flat, I had to go from the 1 lane to the 4 lane. In about an eigth of the mile the sidewall had just gotten destroyed. The tire shop would not warranty the tire. In both flats, I saw that there were bubbles on the sidewall of the tire. Don't know why, but happened twice.
I am now on my second set of Toyo T1R. On my first set, I did alot of spirited driving, and after a wear in period, I found my confidence increasing in hard cornering. I had my car buddies commenting on how far I could push the car into turns. This tire is a definite improvement over the Bridgestones I had before. Much better in the wet, and it has an aggressive tread pattern. My current set, I have not done any performance driving, and I think I can get about 20k miles out of them.
I hope my input is helpful. Guys, when you are getting tire advice, insure that the person you are getting it from has some credibility. There are two things you just don't compromise on. Brakes and Tires.
Old Nov 23, 2006 | 06:24 PM
Bobby Dazzler's Avatar
2003 C32 AMG, 2003 ML270 CDi
Been running Pirelli P-Zero Rosso Asymmetricos all round for about 5 months. Quite pleased with them. Had Continentals before. Not noticed an improvement in performance (as I drive like a daisy), but there is a subtle improvement in the quality of ride and compliance.
I hope this helps...
Old Nov 23, 2006 | 08:31 PM
CLS, SLK, ETC
LOL!!! What is your problem? Did I say anything about me being an expert on KDW?? I believe all I said was, i got it yesterday and tire provided great traction.
I'm sorry for not posting a great detail report on KDWs. I'll try harder to be more like you next time.... .
Please do read my other post.
On my first set, I did alot of spirited driving, and after a wear in period, I found my confidence increasing in hard cornering. I had my car buddies commenting on how far I could push the car into turns.......
... person you are getting it from has some credibility. There are two things you just don't compromise on. Brakes and Tires.
What makes you think you have more credibility than I? because you did many "sprinted driving"?
If you have any other personal remarks about my posts, feel free to PM me and I'll be more than happy to discuss it with you away from this thread.
Happy thanksgiving y'all!!
Old Nov 25, 2006 | 03:00 PM
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
Thumbs up
I think the Falken RT-615 is a great choice; esp. if you want to occasionally track your car...otherwise, you can't go wrong with the Goodyear Eagle F1 GS D3’s. Rated #1 overall by R&T.
.02
Old Nov 25, 2006 | 03:16 PM
spr's Avatar
spr
I had s03's on a prior car. They are nothing like the old s02's. The so2's were great although they wore quickly. s03's are garbage. They're extremely heavy and very greasy when you heat them up. They did work well in the rain though. The best tires I have had were bfg kd's. I cannot comment on the kdw's. The KD's are amazing but are terrible in the wet
I have ps2's on the 911. The sidewalls are too rubber for my taste, but that's how they're designed to work. You really have to load them slowly. They grip well though.
Old Nov 25, 2006 | 03:38 PM
Brunelleschi's Avatar
In the market
if you willing to spend the cash, i vote PS2\
IMHO
Old Nov 26, 2006 | 01:41 PM
blando's Avatar
E55, C32, ML320
GS D3s are great gripwise (especially in the wet), but seem to kick up more debris (chips) and wore relatively quick on me. I'm on PS2s now.
Old Nov 26, 2006 | 04:06 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
eagle F1 GS-D3
Old Nov 26, 2006 | 05:58 PM
R107SL's Avatar
ON PROBATION
1989 560sl and 1997 s500
I would say Pirelli's because they have good grip but they also have alot of road noise.
Old Nov 26, 2006 | 07:55 PM
AMGV6K's Avatar
C32 AMG
decision is made; Bridgestone RE55S street slicks...should grip like hell
