What the largest size tires I can run on a c32
The car is bone stock.
What are some of you running in the rears?
I want to run 235/40 18 f and 245/40 r
can a 255 tire fit the back?
I am running 18x7.5 225/40/18 up front and 18x8.5 255/35/18.
I don't think you can go any wider in the rear without modifications.
You can also go to 235's up front but wouldn't go any wider..
Good luck!
Can u put this size on an 18" wheel without modding the car at alll???? or will the car need mod's to make that size wheels fit the car.????
at the current time my C32 is running 225/40 R18 Front and 255/35 R18 rear.
so if u go to 235/40 R18 front and 265/35 R18 rear what mercedes wheel would fit that size. ???
I do have the Renntech springs, so the car is a little lower.
If you don't think it will rub, what tire size should I get?
Thanks,
Wow, don't try to use PS2s when there is a blizzard out. My car is stuck outside my garage. Looks like I'm calling today a snow day. Time to throw on the stock 17s I guess
I'm at home too.
I made it like 15 feet...
if you did then you can do 235 and 265, rear might rub a little but not enough to worry you.
to be on the safe side you can run 235 and 255
I went and test fitted a set Firehawk Indy 500 in 255/40/17 in the Front installed on the Rear wheels of my C32 (17x8.5 ET34). I put in the FRONT... and...drum roll.....They Fit with No rubbing and without touching anything on the inside, and they sit Flush on the outside. I will only need to have the fender rolled. That's it !!!
I turned lock to lock while going forward and backward and nothing rubbed!
I have stock suspension and plan on having a max of 2 people in the car so I should be fine.
So it's decided my setup is gonna be 255/40/17 in the front of my C32 and a choice of 255/40, 265/40 ( If I can find some) or even 275/40 in the back (i'll test fitting for the rear shortly).
Here are a few pictures!
