03+ C32 IC pump turns on only when supercharger enganges?
Old Dec 14, 2006 | 09:21 AM
AMGV6K's Avatar
C32 AMG
Question 03+ C32 IC pump turns on only when supercharger enganges?
anyone with technical knowlegde please chime in! i searched for this fact but can't find any definite answer
can this help with the IC pump longevity?
Old Dec 14, 2006 | 09:42 AM
jwanee84's Avatar
2002 C32 AMG
It doesnt necessarily engage ONLY when the supercharger is engaged. Listen carefully when you turn off your car or even after you just floored your car. You will hear a kind of whining noise coming from the front passenger side where your IC pump is. It is your ic pump spinning. It only comes on for a short period of time, maybe a min or so? I'm not as technical as some people may be on here but yea i typically notice it after the supercharger or even while its engaged. If you have ever seen your IC Pump it looks like a tiny turbo, its actually kind of cute haha...
Old Dec 14, 2006 | 09:47 AM
sales@eurocharged.com's Avatar
SPONSOR
C63S
I was under the impression that it runs all the time.
Old Dec 14, 2006 | 09:52 AM
AMGV6K's Avatar
C32 AMG
before 03, the IC pump runs all (the time?) the car engine is on
after 03, IC pump only runs when (supercharger enganges?)
any definite answer?
Old Dec 14, 2006 | 09:53 AM
jwanee84's Avatar
2002 C32 AMG
Maybe it runs at different speeds??? but my understanding is that the IC pump is only engaged as needed. You can hear the whine from it, its basically a small fan that spins while circulating your coolant i believe. Listen for it the next time you run your car hard. you come to a red light you will still here a whine, its obviously not your supercharger since its not engaged, or even when you turn off your car you will here your IC Pump continue to spin for about a min.
I have an 02' and mine does not run all the time! I personally replaced my pump so I have an idea of how it is setup and what it does as well.
Old Dec 14, 2006 | 09:56 AM
SPONSOR
C63S
That would explain why my runs all the time. My car seems to cool quicker than others too. You can watch the temps drop in between Dyno runs and while sitting at a stop light.
Old Dec 14, 2006 | 10:02 AM
AMGV6K's Avatar
C32 AMG
so it seems that some cars runs all the time, while some doesn't?
but having it runs only when the s/c enganges might help it to survive longer though.
off topic, but has anyone tried a larger front mount heat exchanger? it may reduces IAT less heat soak and increase power?
Old Dec 14, 2006 | 10:03 AM
jwanee84's Avatar
2002 C32 AMG
here are some pics of the IC pump setup from another users post...
see it looks like a small turbo
Old Dec 14, 2006 | 10:05 AM
jwanee84's Avatar
2002 C32 AMG
yes, there is a guy with a c32 who upgraded his heat exchanger as well as a buddy of mine with a Kleeman CLK 55. They do drastically help with heat soak, it is a great mod but it will be custom! There are also people who use larger IC Pumps as well.
Old Dec 14, 2006 | 10:12 AM
AMGV6K's Avatar
C32 AMG
larger ic pump with more litres/per hour flow?
i thought that might circulate the coolant faster = less chance to cool down?
i was thinking of a larger custom heat xchanger, but fitting it under the bumper might be a pain the neck
Old Dec 14, 2006 | 10:15 AM
jwanee84's Avatar
2002 C32 AMG
That is my theory as well as many others but some people have done it. The fitment of the heat exchanger will not be easy but it can be done. like i said... its CUSTOM. It will make a huge difference in the time it takes for your s/c to cool down though. My buddy with the kleeman can go to the tracks make a run and by the time he gets back in line, he can place his hand on his s/c and not burn. Where as myself... I dont even want to be anywhere near my car after a run haha...
Old Dec 14, 2006 | 10:22 AM
SPONSOR
C63S
My Evo phenolic spacer kit helped a bunch too. Good mod for $150.00 and it is a DYI.
AMGV6K's Avatar
C32 AMG
thanks for the reply everyone... just added my sig...any comments welcome!
Old Dec 14, 2006 | 02:15 PM
itsmeek's Avatar
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
if you open the hood of the car up and you turn the key to the position (i believe it's position 2) right before cranking and leave it there. go outside the car and listen to the engine up top near the firewall. you will hear it engaging. it will squeak and sound like a constant beep- like a low pitched fire alarm almost.
Old Dec 14, 2006 | 02:25 PM
Vadim @ FD's Avatar
S600TT, R350
On 2002s pump runs when car is running.
In 2003 and up it only runs when kompressor clutch is engaged. My guess, AMG new about pumps going out, so the shortened the time it stays on.
Now, the question is - Is constantly running pump cools better than a pump that runs only under boost?
The answer is yes. When I first ran into this on 03s, I have noticed that their AITs were higher before the boost and thus resulted in AITs under boost being 20-30F higher than 02s.
To fix this, one can simply run a wire with a relay from any fuses that are hot, when key is in position 2, to the pump. Than you can also cool the car at the drags by simply turning the key on and having the pump push cooler fluid through the intercooler.
This is how I have Johnson pump hooked up on my C32.
Old Dec 14, 2006 | 03:12 PM
SPONSOR
C63S
For once I'm glad I have an 02.
Old Dec 14, 2006 | 04:49 PM
jgsx's Avatar
04 C32
Ugh . . . I'd add a relay to keep mine on all the time, but the thing is I KNOW it is going to fail eventually, and the dealer will blame the failure on that.
Old Dec 14, 2006 | 07:58 PM
AMGV6K's Avatar
C32 AMG
top notch response...now we all know it's a trade off between pump longevity vs IAT
Old Dec 14, 2006 | 09:02 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Performance rules! If I had wanted to have a car that lasted forever I'd have bought a slow car.
Old Dec 14, 2006 | 10:39 PM
Eurocharged Rick's Avatar
SPONSOR
Well said my friend, well said...
Old Dec 15, 2006 | 04:12 AM
bnz616's Avatar
2012 GL550
Is this 20-30F increase in AIT noticeable in day to day driving?
Also, what is the AIT temp range for a 2002 supposed to be? (I'm not sure how it is compared or measured...in relation to outside temp?)
I have a 2002, and I also hear a pump go off for a few seconds when I'm stopped at the stoplight. Is that the IC pump going off?...sounds like a deep whine. From what you guys are saying, it sounds like it should be constant and not just a few seconds of whining. I do hear it sometimes when I shut off the car. The IC pump crapped out awhile back and I replaced it with the lightning one.
Old Dec 15, 2006 | 09:05 AM
Fifth Ring's Avatar
C32 AMG
I think we could be confusing ourselves. There are at least 3 sources of on-and-off whining (excluding spouse noises). The IC pump is just one. There is also the auxiliary air pump, which is an emissions component. Last, there's the A/C compressor that cycles on and off. The only way to be certain is to get up close and personal with the IC pump.
Old Dec 15, 2006 | 05:27 PM
AMGV6K's Avatar
C32 AMG
is the longevity acquired by the pump on 03+ C32 really worth the increased IAT? 20-30 F does seem like quite a lot, question is how detrimental is 20-30 F increase to power/performance. if it turns out to be okay, i may look into how make the pump run like 03+ C32
Old Dec 15, 2006 | 06:25 PM
Vadim @ FD's Avatar
S600TT, R350
Additional 20-30F of AIT are detrimental in terms of consistency. The colder the initial AIT, the longer it will take for it to reach a point where it does become noticeably detrimental.
