How hard is it to work on C32's?
I've done a few searchs to try find out common issues and I haven't really seen anything that really scares me away yet.
I do live in the Boston area and we do get hit with storms in the winter (not this year yet though!) but I've read that these cars do ok with a good set of winter's so I have no concern really there.
I'm also curious what some of you get for your average MPG? I know the epa is 17mpg city/21mpg hwy, are these numbers accurate?
Thanks!
Jay
Thanks!
Jay
The EPA numbers are correct.
As to working on the cars, it's fairly easy -- to a point. Unlike some brands, Benz seems to pay some attention to maintaining serviceability. They engineer stuff so it is accessible. My prior car (Audi) had a LOT of inaccessible items that made it very hard to do even basic maintenance. On the C32, filters and fluids are easy to check and change. You can change your oil with an oil extraction pump and change the filter up top, and never crawl under the car!
The only other stuff I've done is brakes (pads and rotors). That was a breeze.
The one area where Benz is difficult is any service requiring computer diagnostics. There is no way for a consumer to access and interpret computer codes. In contrast, you can find Audi/VW diagnostic software that loads on a laptop and can diagnose and change many things.
flip
I think I'm pretty comfortable with working on cars, the most I've done is a manual swap...converted a Volvo 850 Turbo Auto to Manual.
How much do you guys spend on average per year maintenace wise? I know mods can get up there
Anyway, I like what I'm hearing so far. Just going to be a matter of finding the right car with low miles and hopefully some kind of extended warranty.
oil and filter
fuel filter
transmission fluid and filter
differential fluid
new air filters (always K&N or equivilent, Green filters on this car)
radiator flush and replace fluid with Water Wetter
New plugs and wires
etc...
there are other things that i do as i go along, such as i am upgrading the brakes to bigger Stoptechs in the front, therefore i am going to flush all of the brake fluid and replace it with new fluid...you get the idea
oil and filter
fuel filter
differential fluid
New plugs and wires
etc...
Very good advice. Would these all make sense regardless of the mileage, say what if the car was at 40k miles when purchased (which is my case)?
The other question I have is what would you recommend to be done by a dealer? I can definitely drop new filters, plugs/wires, but radiator flush or dif. fluid flush may be best done in the shop...
Thanks!
Jay
i never let the dealer do anything that i can, and that isn't much...
radiator flush is easy on a low mileage car...drain the radiator, fill back up with water, run for a couple of days, drain the radiator again, fill back up with the fluid of your choice (in my case i use water and Water Wetter)...
Differential fluid is the same...just drain it and fill it with whatever is recommended for the vehicle
