S65 AMG wheels on C32?
Old Mar 27, 2007 | 07:44 AM
overboosted's Avatar
2012 E63, 2016 1299
Highly doubtful, but what are the chances they'd fit?
Size: Front: 20" x 8.5 43mm offset
Rear: 20" x 9.5 43mm offset
Bolt Pattern: 5 x 112
Tire Size: Front: 255 / 35 / 20
Rear: 275 / 35 / 20
Old Mar 27, 2007 | 10:00 AM
rlee02135's Avatar
2004 C32 ///AMG
i have replica 18s
Old Mar 27, 2007 | 10:17 AM
2012 E63, 2016 1299
Originally Posted by rlee02135
i have replica 18s
silver or anthracite?
pics?
Old Mar 27, 2007 | 03:17 PM
Fifth Ring's Avatar
C32 AMG
Next best thing.
I did the cheap-man's version of those wheels. I polished the lip of my C32 wheels and painted the centers.
There is no published paint color for those wheel centers, so you need to improvise. I used a color called "Gunmetal Blue" offered by Jaguar.
Old Mar 27, 2007 | 03:38 PM
2012 E63, 2016 1299
NEAT!
Any pics of them on your car?
Old Mar 27, 2007 | 03:50 PM
Fifth Ring's Avatar
C32 AMG
The individual wheel photo is from an OEM front wheel (7-1/2" wide, no lip). The below picture has four OEM rear wheels (8-1/2" wide) on all four corners. Same paint finish.
Old Mar 27, 2007 | 04:04 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Man, I always love it when you post pics of your car on the track! I am envious every time.
Love the look and love the tracking.
Old Mar 27, 2007 | 04:54 PM
Fifth Ring's Avatar
C32 AMG
I'm envious of the guy in the picture too. He's at the track, and like you, I am not! I guess that is what pictures are for! I only get out to the track 2 or 3 times a year. I wish it were more frequent.
Old Mar 27, 2007 | 05:00 PM
TJ_Andrews's Avatar
2002 C32 ///AMG
Wait, you did that yourself??
Old Mar 27, 2007 | 05:04 PM
matt55's Avatar
09 c63 10 c300 Nissan truck
Rear: 275 / 35 / 20
the bolt hole diameter may be larger with s class wheel . best check before buying
Old Mar 27, 2007 | 05:14 PM
Rareamg's Avatar
E55 AMG Black on Carlsson 1/6 EVO
looks good!!
Old Mar 27, 2007 | 05:32 PM
Fifth Ring's Avatar
C32 AMG
The rattle-can special!
The painting was easy. The hard part was stripping and polishing the lip. If I could do it over again, I would just keep the lip painted silver.
Old Mar 28, 2007 | 03:58 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
fifth ring has the best oem 17s. lol
any rubbing on the front struts when you run the 245s for the track?
Old Mar 28, 2007 | 04:13 AM
MB_Forever's Avatar
E63 P30, CL500 Sport
S65 rims on C32 AMG
I was able to use SL65 rims on the C32 with minor modifications. So YES, it can be done, but the dealership will have to adjust the offset a little, but once done, the car drives flawlessly.
Old Mar 28, 2007 | 04:14 AM
vraa's Avatar
Adjust offset, meaning they grinded or used spacers?
Old Mar 28, 2007 | 10:27 AM
Fifth Ring's Avatar
C32 AMG
No rubbing at all. Apparently the rear wheel offset (less than fronts) works very well. I've tried two different 245s. What really matters is the true section width, which often exceeds the reported section profile. In some high performance or R-compound tires, I would probably go with a 235 profile.
Old Mar 28, 2007 | 06:36 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
cool. I've seen people run the stock rear on the front with no problem. was just wondering if there were rubbing issue on the struts with the 245 tires.
I may be going with 245 all around with my next setup on 18".
Old Mar 31, 2007 | 11:20 AM
turbo16lbs's Avatar
1991 Toyota MR2, 2002 C32 AMG
How about some pictures?!
<3
