Porting, Polishing, and Cams project
Old 08-14-2007, 08:05 PM
  #426
SPONSOR
Eurocharged Rick's Avatar
i am home, it was a blast being up there and getting to wrench on Jerry's car! it was also a lot of fun to just hang out and meet some other people from the forum...
Jerry, thanks for letting me crash at your place, it was a fun weekend and i am definitely glad i came...we will have to do it again, but you are coming to houston this time...
to the rest of you guys that i met, it was great meeting you and i will look forward to seeing you again...
the car is running great and i can't wait to see what kind of numbers that it puts down on the dyno...
i do have one question though Jerry, where are the pics?
Old 08-14-2007, 08:24 PM
  #427
MBworld Guru
FrankW's Avatar
white and whiter
waiting for final numbers
Old 08-14-2007, 08:29 PM
  #428
neihouma's Avatar
02 C32 AMG sold!
Transmission flush, how many quarts did you manage to get out?
And what method was used?
Rey
Old 08-14-2007, 09:41 PM
  #429
SPONSOR
Rey
we drained the pan and changed the filter...we were only able to get out 3 quarts...but once you change the filter, it is easy to drain and then refill that amount...just make sure you measure what you are taking out so that you know how much to put back in...then, make sure you
you need the pan gasket, filter, tranny fluid and tranny dip stick from the dealer...the rest can be done in your driveway...
Old 08-14-2007, 09:55 PM
  #430
neihouma's Avatar
02 C32 AMG sold!
i did the same method & managed to get out 4.25ish quarts
out. damn diptstick was more than the oil pan gasket and
filter, $80ish!
Old 08-14-2007, 09:56 PM
  #431
neihouma's Avatar
02 C32 AMG sold!
On a side note, it's very promising for us C32 owners
Old 08-14-2007, 10:59 PM
  #432
SPONSOR
sales@eurocharged.com's Avatar
C63S
Here are the pictures...
http://www.renntechc32.com/variousprojects/
Old 08-14-2007, 11:46 PM
  #433
rlee02135's Avatar
2004 C32 ///AMG
Originally Posted by AMG-Jerry
nice work Jerry, Erick and the rest of you guys!
Old 08-15-2007, 09:50 AM
  #434
///AMG4EVER's Avatar
CLS55 Designo 030
Good stuff...
What's next!?
Old 08-15-2007, 09:53 AM
  #435
jgsx's Avatar
04 C32
Wow looks like I missed out on the weekend. Good work guys
Old 08-15-2007, 11:50 AM
  #436
msheredy's Avatar
MB
What's that catch can for? Where is it hooked up to? Good photo documentary!
Edit" Nevermind what it is for, I just read what it is for. Do you have a shot of it hooked up to the valve covers?
Old 08-15-2007, 11:58 AM
  #437
MRAMG1's Avatar
S600, GL450, Audi A5 Cab
Hey AMG-Jerry:
GLAD to hear she is back together
Whoa! with the fantastic back up you had, I can't wait to see what she runs in the 1/4. Best wishs on her return to the strip, and the FUN you will have on the street with MANY unsuspecting drivers
It truely is great to see people helping out on such an amazing project
See yeah
OH yeah, GREAT PICS!!!
Old 08-16-2007, 09:12 AM
  #438
SPONSOR
C63S
I'll take one for you tonight.
It is an awesome mod, and it really cuts down on the oil build up.
Old 08-16-2007, 09:45 AM
  #439
SPONSOR
C63S
Originally Posted by ///AMG4EVER
Good stuff...
What's next!?
This is the hardest question to answer.
As most of you have figured out from the pictures, the "super secret" mod is a larger 3 piece dampened crank pulley. It is good for 20Lbs of boost. After Erick, Perry, and I installed it, the car now has its power back. It has been a few days and the idle is still perfect! Erick can confirm, the car feels way different. When he first drove the car, he noticed right away that the power wasn't there. After all the work was done, Wifey sent Erick and I to get more propane for the grill...and of course we took the AMG for the quick 3 minute drive to the store. We hung a right at the first stop sign down the road from my house and Erick something like "Dude, this is a different car". He is right!
Now the bad news...
I lost tons of boost porting my heads. Normally, this wouldn't be an issue because you could always up the boost. Well, this isn't the case with our car. The crank pulley that I have installed is the largest pulley that you can safely run. I'm willing to bet that the WHP on the car is where it was before and there is nothing that I can think of that will increase it. The S/C is <2000 RPM away from red line. Spin it faster and efficiency becomes an issue.
The only positive note, and Erick can confirm, is that the TRQ curve is perfect.
So, depending on the numbers that Erick puts down once he gets his larger pulley installed will determin if I buy new heads or not. I really have no other options if I want to make some serious power....I wish the E55 S/C would fit!
If you have a craving for serious power, contact Erick about this pulley. It is a 3 piece internal dampened pulley that weighs 4 ozs more than the stock pulley, and is good for 20 PSI. This is the most well designed pulley I have ever seen....and no, Erick nor I designed it. He will provide Dyno numbers once he installs it. Due to my heads, I won't be a good candidate for WHP figures.
Here are pics... http://www.renntechc32.com/largerpulley/
Ideas? Thoughts?
Old 08-16-2007, 09:53 AM
  #440
rlee02135's Avatar
2004 C32 ///AMG
the pulley looks nice. was it designed to work with all the other pulleys stock or will an Evo ODPS work?
Old 08-16-2007, 10:02 AM
  #441
SPONSOR
C63S
It comes with a smaller water pump pulley. I went from the Renntech pulley to the Leading Edge Motorsports pulley just by swapping the water pump pulley.
You will be able to do the same.
Edit - The Renntech kit uses another smaller pulley like the Evosport kit.
  #442
neihouma's Avatar
02 C32 AMG sold!
Jerry opening your exhaust will open up your compression in the
combustion chamber will cause you to loose boost, porting and
honing the head will just delay the amount of time filling the
intake manifold making you think you're loosing boost, but
infact it's just really a delay if filling up the intake manifold
with kompressed air from the supercharger. Then again, this
is what I've gathered from Vortech / Powerdyned superchargers.
So don't crucify me if I'm wrong
Have you had a chance to datalog the intake manifold pressure
before and after the pulleys w/the honed/ported heads?
Old 08-16-2007, 10:09 AM
  #443
SPONSOR
C63S
Yes, Erick and I did a quick run to the store with the data logger running. According to my software, I am now at 17.3 PSI. Before the install, I was at 14.4 PSI. This explains why my car has been putting out stock numbers.
Of course, this is with a data logger that only samples every 5 seconds, so the max numbers for before and after could be off. If the DL took a sample at 30 PSI, it wouldn't sample again for another 5 seconds....which means that I have shifted gears and lowered the boost. So, the numbers above were the max that I could capture....I need a boost gauge.
Old 08-16-2007, 10:30 AM
  #444
neihouma's Avatar
02 C32 AMG sold!
Is that even possible? With my ASP pulley I'm running 18.1psi.
I really need to get my boost gauge installed ASAP
Old 08-16-2007, 11:28 AM
  #445
SPONSOR
C63S
How do you know you are at 18.1 PSI?
Old 08-16-2007, 12:09 PM
  #446
neihouma's Avatar
02 C32 AMG sold!
https://mbworld.org/forums/c32-amg-c55-amg-w203/205437-carchip-users-come-here.html
Old 08-16-2007, 12:24 PM
  #447
CLS55 Designo 030
I would like to see some numbers with the Leading Edge Motorsports pulley.
Old 08-16-2007, 12:56 PM
  #448
pshek's Avatar
2003 C-Class Sportcoupe
That pulley looks way better than the ASP pulley. I was a little mad when I saw the welds on the ASP pulley. Anybody know the specs on the ASP pulley vs Evosport vs Leading Edge. I thought the ASP pulley was slightly larger than the Evosport pulley.
Problem with a larger pulley is cooling. ACT will rise with higher boost, so cooling upgrades are necessary.
Old 08-16-2007, 01:40 PM
  #449
SPONSOR
ASP, Evosport and Renntech are all the same size... 178mm
Leading Edge is 185mm...you should see the difference first hand, the Leading Edge Pulley is huge compared to the others...
i agree, cooling upgrades are necessary to see the full gain from this setup...
if anyone is interested in some cooling upgrades, shoot me a PM...
Old 08-16-2007, 03:35 PM
  #450
430
430's Avatar
SLK32
I remember there was talk of running a 192mm pulley. Not sure how much boost that translates into.
What size Pulley was Vadim running when he started to see the SC clutch slip?
I am very interested in this pulley. I have upgraded my cooling with a much larger secondary heat exchanger adding ~1 gallon of coolant to the system. Additionally I have added a CM90 pump. That pump is a very tight fit on the SLK32.
I am currently running the ASP pulley's and was considering going back to ASP to build me a larger Crank pulley to up the boost.
This looks like a better option. Do we have any pricing?
Very interested in the before and after numbers on Erics install.
Quick Reply: Porting, Polishing, and Cams project
