Porting, Polishing, and Cams project
Old 08-19-2007, 09:55 PM
  #476
cosmos's Avatar
What I find
Been following this thread for sometime now.
Jerry,
What if anything would you have done differently from the start of this project?
Great job and fantastic read. Thanks for the info.
Old 08-20-2007, 08:39 AM
  #477
SPONSOR
sales@eurocharged.com's Avatar
C63S
Originally Posted by cosmos
Jerry,
Thanks!
I have to say that I wouldn't have bothered porting the heads. AMG did a fantastic job on them and there isn't much room for improvement.
However, the 3 angle valve job is something that I would have done again. I think that porting the exhaust side of the heads would also help.
My issue is that there is no feasible way for me to up the boost anymore. My S/C is almost spinning at redline.... so to be safe, I need to leave things alone.
I have a dyno appt on Friday where I should be able to get some Dynapak numbers to compare with my first graph. I expect the numbers to be the same as before the port job.
I consider this project over.....and a failure.
The only positive thing is the Trq curve and improved MPG. We will be able to compare the two graphs this weekend.
Old 08-20-2007, 11:32 AM
  #478
Zeppelin's Avatar
C32
Originally Posted by code3smith
Its very feasible. I have an extra one we used for r&d. Like I mentioned briefly, I took a different approach to creating power. I will have more news soon.
I hope you don't plan on removing the clutch, also with a smaller SC pulley there is a good chance the belt will slip. Let us know how it turns out.
Old 08-20-2007, 11:50 AM
  #479
msheredy's Avatar
MB
I've been reading a post on the E55 forum where there're in talks about installing turbochargers. Some want to keep the factory supercharger while others want to nix the blower all together.
I have been thinking about this since I first bought my car. When I spoke to a rep at STS he sounded totally excited about my inquiry. He was thinking a modest horspower level per pound of boost would be in the neighborhood of 20HP per lbs of boost. The C32 without boost was dynoed at 135WHP. I see the math looking something like this, 135 + 17% (drive train loss) = 158 Flywheel HP(Base). The boost on the M112 engine is 14.5 so 20 x 14.5 = 290HP + 158(Base) = 448 horsepower, that is a 100HP increase @ the same boost! A pullied blower is good for approx 4-5 more pounds of boost so 18.5 x 20 = 370 + 158(Base) = 530 Flywheel HP!
So far I believe the most challenging part of the build would be the electronics side. And what I mean by that is where the ECU controls the supercharger clutch. I figure there has got to be a way to have that talk to an electronic boost controller to open and close the wastegate in a similar fashion to the supercharger clutch.
Old 08-20-2007, 02:45 PM
  #480
SPONSOR
C63S
Don't forget that the base number will go up once the S/C is removed and there are no air restrictions. With the S/C not spinning, air has a hard time getting through.
I doubt I will spend any more money on mods for this car. My goal now is to find out why the car is pulling timing. It starts at 4800 RPM and continues to red line. I think that I'm losing about 50HP and I have no clue why!
I recently replaced my O2 sensors, but I've tripped the P0130 code twice now.
Old 08-20-2007, 02:57 PM
  #481
neihouma's Avatar
02 C32 AMG sold!
Damn I've been meaning to do that since this weekend, too
many officers patrolling the area that I try my car out on.
Which Carchip version do you have? I have CarChip Pro 08226
Old 08-20-2007, 03:09 PM
  #482
SPONSOR
C63S
Carchip E/X 08221 I just got it, but their website shows it as being discontinued.
Old 08-20-2007, 03:10 PM
  #483
SPONSOR
C63S
I want to see some Dynojet graphs....
If you have one and it is for the C32, please post it.
Old 08-20-2007, 03:12 PM
  #484
c32used's Avatar
LET C32 2002
Jerry in my opinion just find out what could be restricting you...ask questions to other performance people also until you find one that has an answer to your issue. Adding more Mods can add to your current issue thus making it more frustating. Wait and see what kind of numbers 1fastc32 makes with his setup and from there you will have a base idea what you are loosing and maybe find out better where to locate your issue.....I know its frusterating but as long as the car is running relax and keep asking around til you find your restrictions. I say look at the point where your car made the most numbers and list everything you did since and maybe you will find an answer there.
Old 08-20-2007, 03:55 PM
  #485
SPONSOR
Eurocharged Rick's Avatar
i am going to dyno my car tomorrow afternoon so that i have a good baseline before the next round of mods...
Old 08-20-2007, 07:11 PM
  #486
430
430's Avatar
SLK32
Can't wait to see the numbers.
Old 08-21-2007, 02:26 PM
  #487
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
ASP, Evosport and Renntech are all the same size... 178mm
Leading Edge is 185mm...you should see the difference first hand, the Leading Edge Pulley is huge compared to the others...
i agree, cooling upgrades are necessary to see the full gain from this setup...
if anyone is interested in some cooling upgrades, shoot me a PM...
A google search of Leading Edge Motorsports comes back with a few companies... from my best guess, the most likely one to be correct is http://www.leadingedgemotorsport.com...port/index.cfm but I'm obviously not 100% on this - can't find any mention of them fab'ing pullies of any type.
The question's come up a few times regarding pricing and availability - Erick or Jerry, any info or updates on this?
TIA!
Old 08-21-2007, 06:33 PM
  #488
msheredy's Avatar
MB
Originally Posted by c32AMG-DTM
A google search of Leading Edge Motorsports comes back with a few companies... from my best guess, the most likely one to be correct is http://www.leadingedgemotorsport.com...port/index.cfm...
Here is the correct link.
Old 08-21-2007, 07:21 PM
  #489
pshek's Avatar
2003 C-Class Sportcoupe
ASP Pulleys...
I just ordered the LET C32 Pulley. Keep us posted on the progress. I'm probably going to do a baseline dyno, then put on the ASP pulley, then the LET pulley. Now I can use my boost gauge and do some actual tuning....
Supercharged cars are so much more difficult to change boost, gotta change pullies, unlike turbos.
Old 08-21-2007, 07:30 PM
  #490
c32AMG-DTM's Avatar
Thanks!!
Old 08-22-2007, 12:42 AM
  #491
SPONSOR
dyno'd the car today, it put down 322 whp with its current configuration.
i am in the process right now of putting the LET Motorsports Pulley on the car...
i have another dyno scheduled for friday afternoon, so i should have some numbers then...i will keep you posted
Old 08-22-2007, 01:04 AM
  #492
Code3 Performance's Avatar
C32, Cobra, 700hp Vespa
I was hoping the new pulley setup would be cheaper.
Old 08-22-2007, 04:07 AM
  #493
rlee02135's Avatar
2004 C32 ///AMG
what engine mods put you at 322 RWHP?
Old 08-22-2007, 04:24 AM
  #494
MBworld Guru
FrankW's Avatar
white and whiter
they're listed in his signature Rob...
Old 08-22-2007, 04:45 AM
  #495
rlee02135's Avatar
2004 C32 ///AMG
thanks...didn't see that
-RENNtech Stage 1 (Pulley & ECU)
-Full SL55 Intake w/Green Filters
-Magnecor 8.5mm Plug Wires + Iridium IK22 Plugs
-Lightning Intercooler Pump, Cobra Dual-Pass Heat Exchanger, Canton Intercooler Reservoir, Custom Intercooler
-Evosport Phenolic Intake Spacers
-Sprintbooster
322 @ the rear wheels seems low. hope the LET Pulley makes over 360...
Old 08-22-2007, 09:04 AM
  #496
c32AMG-DTM's Avatar
+1
From what I've read on other posts, driveline losses for this car are approx. 15-17%.
322 / .85 = 378
322 / .83 = 388
Renntech Stage I alone is claimed to make a hair under 400 hp... so either that's an inflated figure, or they experienced those gains by starting with a particularly strong stock C32, who knows.
Anyway, I think 360 rwhp (ballpark 425 - 435 crank hp) is optimistic for just the LET pulley swap, although I'd be happy to be wrong almost 40 rwhp from a slightly larger (i.e. higher boosting) pulley seems unlikely to me though.
Maybe with the LET pulley AND upgraded headers, we'll see 350+ rwhp out of 1Fast's car!!
Old 08-22-2007, 09:55 AM
  #497
SPONSOR
+1
322 / .85 = 378
322 / .83 = 388
the number is down a little from last time i was at the dyno with the same mods, last time i put down 131whp, so 9whp down from last time, but it was blazing hot yesterday! gotta love houston!
anyways, i got the new pulley on last night, but i haven't had a chance to drive the car yet...i will let you know how it drives and especially what kind of power it puts down on friday...
Old 08-22-2007, 10:16 AM
  #498
neihouma's Avatar
02 C32 AMG sold!
let this be a word of wise to you boys and girls, before putting
box of parts in your C32, go and DYNO your car while it's stock,
get a baseline reading. I regret not doing this.
I'm a nerve away of putting my car back to stock to dyno it or
just strip it and sell it.
Old 08-22-2007, 10:17 AM
  #499
neihouma's Avatar
02 C32 AMG sold!
-Sprintbooster
Actually on a conservative (underrating it) calculation 322rwhp
comes up to 389BHP
Old 08-22-2007, 10:22 AM
  #500
///AMG4EVER's Avatar
CLS55 Designo 030
Keep us posted!
Quick Reply: Porting, Polishing, and Cams project
