Sprintbooster specifically for AMGs .....
Old Apr 24, 2007 | 06:53 PM
Eurowow's Avatar
Amg C32
err
A2 is the right model, So i was told by eric.
Old Apr 24, 2007 | 09:20 PM
Rudoubles's Avatar
03 C32
I just got back my SB because one of the 5 pins broke off causing the throttle response to malfunction. Other than that i've had no problems.
Anyways i have the BDD 451A1 version, can anyone who's had the A1 version and switched to the new A2 "AMG" version tell the difference between them? Thanks.
Old Apr 24, 2007 | 09:43 PM
jgsx's Avatar
04 C32
I'll let you know as soon as I get my car back. It is only "AMG specific" in the sense that it is less mild. It was tamed down to address the limp mode issue. If you haven't experienced it, I wouldn't switch. I am looking foward to trying it out. The throttle response is obviously poor without the booster, but I wish it was a little softer than with the 4141A version. Hopefully the A2 is just right
Old Apr 24, 2007 | 10:58 PM
steve_bris's Avatar
C32
I just installed the A2.... it makes the throttle more responsive, and the initial lag between flooring the pedal and anything happeneing is greatly reduced, there is still a little bit of a pause.
It is not a severe a change as I was expecting, but an definite improvement none the less.
Old Apr 25, 2007 | 03:19 AM
9krpm's Avatar
2004 C32
My god you are quick with the mods!!! I still have not installed the asp pulley yet lol
Should I get one steve? Is it worth the expenses?
BTW my stock c32 pulled 195rwkw on the dyno that many pple claim it reads 10% lower than the usual.
Old Apr 25, 2007 | 03:28 AM
steve_bris's Avatar
C32
Yeh I think it is for sure ... its not a rediculous difference, the main thing you notice is that it seems to have a lot more mid range nip to it.
Hey also 9krpm I got my resonator cut out last week, thats definatly worth it. The guy wanted to charge me over $100 for the 2.75" stainless pipe, but I found it on ebay, the seller is from sunnybank, QLD, and sells the pipe for $25........ if you are going to get your resonator done, buy the pipe from him, and then its only $40 to get it installed.....much more reasonable
http://cgi.ebay.com.au/2-75-POLISHED...QQcmdZViewItem
Old Apr 25, 2007 | 05:02 AM
  #32
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by Eurowow
Sprint Booster BDD451A2 for AMG
Automatic Transmission i just order mine !!! AMG auto is this the right one
Here is the link http://www.partsexporter.com/mbworld 250 SHipped 12 left!!!
at the dot com name... part sex porter....and yes I know it's parts exporter.
Old Apr 25, 2007 | 12:46 PM
  #33
Eurowow's Avatar
Amg C32
lol ! i want my part.
Old Apr 25, 2007 | 04:18 PM
  #34
flush's Avatar
2003 C32
To recap:
the A2 model is for AMGs with at least some minor engine mods (e.g. pulleys)? or even stock AMGs?
Anyone with the original A1 and new A2 care to chip in with their feedback?
Old Apr 25, 2007 | 04:46 PM
  #35
jgsx's Avatar
04 C32
Originally Posted by flush
To recap:
I had the A and it would throw me into limp. I now have the A2 sitting on my coffee table. I'll let you know as soon as I check it out.
Old Apr 26, 2007 | 12:27 AM
  #36
Eurowow's Avatar
Amg C32
i'm getting A2 and the only engine mod so far is Full exhaust.
Old Apr 27, 2007 | 11:01 AM
  #37
9krpm's Avatar
2004 C32
Thanks steve. Sunnybank is not too far away too
I will probably leave the exhaust alone. I never like noisy car unless there is some power gain to compensate for the noise.
BTW I tried to get Three Star to install my pullies last service. They claimed that the belt for the ASP (which doesn't come with one) is missing and stated on the service invoice that Chrysler would not endorse this fitment as it has resulted in failures in the past They did not even bother to wash my car either. Guess I know where to avoid for service next time.
Old May 6, 2007 | 10:22 PM
  #38
jgsx's Avatar
04 C32
I installed the A2 (the "AMG" booster version). I think it is just right. It isn't as jumpy as the A ("automatic") version, but is still enough to make the car easily kick down gears.
I'm not sure if it solved the limp mode issue. I would only see it when it was cold outside. It was warm this weekend.
Old May 13, 2007 | 03:15 PM
  #39
Eurowow's Avatar
Amg C32
just got mine, love it. GAS milage SUckkkkkkkkks.
