Help Needed to Change Air Filter
C32 2002
I tried to change my air filter on the C32 today, but did not know how to get the hose clamps to open, is there a special tool needed ? I stopped midway not knowing and also how do u put the hose clamp back together so it is snug ?
Help me please.
Help me please.
you don't even need to take those off...
just unscrew the torx bolts holding the top of the air filter box on and it will lift up so that you can exchange the air filters...
2003 c32 AMG
C32 2002
Help
I tried to change the Air Filter as suggested without removing the hose clamps, but was unable to do it, the box will not lift up at all to reach the filter.
I again tried to open the hose clamp, but I have no idea how to. Also the screws that are on the boxes, what type are they ? I found out that one was missing and need to buiy them any idea?
1 Post
2003 C32
you probably did not unscrew the bolts holding the air box lid on enough...
if you lift up and it will only lift up a very slight amount, then unscrew them some more...
03 C32 AMG
JC, you did realize this post was 2 1/2 years ago?
But to answer your question, yes, you'll need two air filters for the C32. I suggest using K&N drop in filters for the C32 since they are much much better than the OEM ones.
Cheers![Cheers](https://mbworld.org/forums/images/smilies/cheers.gif)
Cheers
if you look under the hood, you will notice that there are two intake hoses sucking in air and directing them two to boxes. each of those boxes (air boxes) contains one intake filter, so there are indeed 2 filters, one per side.
2003 porsche 996 turbo
c32amgc whats the chances of seeing you in steele al on the 23? love to represent the benzs with a bunch of top shelf cars on drag nite!!
