IC pump going out (again) after only 22000km / 13000miles
Subscribe
Apr 13, 2007 | 04:24 AM
i had my IC pump replaced at 60000kms, and now i have reached 82000km and it seems like my ic pump is going out again!
is it possible to have a such a short-lived ic pump? it should last 3 times longer (50000kms)
symptoms are as follows
the car lost power and it feels ashmatic on monday and tuesday
i drove out wedneday and thrusday and the car is strong for the entire day
today (friday) the car lost power again.
Reply 0
Apr 13, 2007 | 06:50 AM
Apparently, the Ford Lightning uses the same IC pump for substantially less. Although, I don't know if you guys have the Ford Lightning down in Melbourne, where you live at. I'm sure some Ford product in your market shares this pump. Apparently the number is same, except the suffix - SEE BELOW. Good luck!
POST 1 - https://mbworld.org/forums/showthrea...tercooler+pump
POST 2 -
Reply 0
Apr 13, 2007 | 09:21 AM
Remember, the I/C pump failure is most noticed when ambient temps are high or engine temps are up, due to harder driving. Where either a possible cause of the loss of power on the bad days? The car would perform mostly normally if the outside or engine temps were cool.
If things were cool, you might have another problem. 13,000 miles does seem like a short life, even for the hated I/C pump.
Reply 0
Apr 14, 2007 | 11:49 PM
The ford lightning pump is available in Australia. They are a little more expensive then in the states but still 1/5th the price of genuine.
PM me if you have trouble finding one
Reply 0
Apr 15, 2007 | 01:45 AM
wonder if it's because you are in Australia...LOL...jk
Reply 0
Apr 15, 2007 | 01:55 PM
After replacing the pump, make sure the IC circuit is bleed of air. If you have an air pocket, the pump may not do it's job and may run dry, causing it to fail sooner. The orientation of the inlet helps to prime the pump.
Reply 0
Apr 16, 2007 | 01:44 PM
i managed to source a 23lph pump as opposed to 15lph (mercedes spec) with 19mm inlet/outlet (again mercedes spec) how would this higher flow affect anything?
Reply 0
Apr 16, 2007 | 04:50 PM
would be interested in finding out about the new pump if it works out for you
Reply 0
Explore
Apr 17, 2007 | 11:41 AM
Here is a slightly larger pump:
http://autoperformanceengineering.com/
$125.00
Johnson CM30P7-1
Highlights
* 20 mm hose connections (3/4")
* Pumps water up to 100° C (212° F)
* Magnetic drive means a sealed pump chamber
* Rated for continuous duty (motor life 5000 hours)
* Weight 0.60 kg (1.32 lbs)
* 1 year manufacturer's warranty
* 12 and 24 Volt versions available
Pressure
bar Flow gal/min 12V
0.10 6.9 2.2A
0.20 5.2 2.0A
0.30 2.4 1.7A
Also, here is the link for the specs of all three of this pump series including the larger CM90, look at page 19:
http://www.johnson-pump.com/JPMarine..._2007GB_v1.pdf
http://www.johnson-pump.com/jpmarine...tion/cmco.html
Reply 0
Apr 20, 2007 | 12:18 AM
let the bosch vs jonhson pump debate begin
bosch pump
-direct fit and mounting/only require wire splicing
-less life hours compared to johnson
johnson pump
-require custom mounting/wiring
-longer life hours
anyone please feel welcome to add to this
Reply 0
Apr 21, 2007 | 05:15 AM
I don't know much about IC pumps..but it seems the johnson is the way to go. Although it may be a pain to install, once u have it installed you hopefully wont have to worry about replacing it in the near future.
Reply 0
Subscribe
Currently Active Users (1)
