Did AMG ever offer an ECU upgrade?
The GM of the workshop was there and told me AMG offer an ECU and gearbox reprogram, that together with a dyno tune, would raise power from 240kw (326hp) to 320kw (435hp) and drastically reduce acceleration times.
The install is from AMG Germany as the dealer officially reports to AMG on all matters, not Merc. I say 240kw because he is of the firm opinion that euro spec C32's werent exactly optimised from a kw perspective when leaving the factory. He reckons he has never met a stock 32 putting out more than 240kw, despite advertised claims. His work doesnt touch boost, rather makes more use of the engine (he said they made it so ithe engine works to 65ish% power output in order to get more mileage out of the block)
So, i need to sort out the wheat from the chaff. Does anybody know of an AMG ECU reprogram? Does such a thing exist?
If such thing exists, then this AMG ECU upgrade combined with Evo Stage 2 + heads and cams = 500+ hp C32 easily...
Does anybody have any information about this alleged AMG upgrade ???
https://mbworld.org/forums/cl55-amg-cl65-amg-cl63-amg-c215-c216/188547-fastest-cl600-country.html
My understanding is that that pressured air from the supercharger goes into the engine without any governor or blow-off or by-pass system, meaning that the only way to increase boost would be to increase compressor speeds - and you cannot do that with an ECU only.
So, I'm highly skeptical.
At speeds below 30 I couldn't go wide open throttle without slamming ESP on and slowing me down.
I couldn't give anything more than a feather to the throttle while making a 90 degree turn from a complete stop without one tire spinning and going nowhere.
These cars should have came with LSDs from the factory, or at least offered it as an option.
Basically, what i needed to know. I aint doing anything until either i can get a full description of what they "do" in the upgrade, or find corroboration elsewhere.
Thanks fella's.
I knew that...no really, I did...honest!lol Maybe it was part of "are not" too? Either way ain't, ain't a word.Anyway, so how bout that magical 100hp ECU tune. Pfffft...
my car was in for a service and there was a demo they were testing...it had a reworked SC, ECU upgrade and G/box re-program
I was present when they removed the SC as they were doing more testing on it.
at that time carlos told me they were gaining close on 100kw and 70 Nm..but the diff was not handling it
price for the upgrade once they sorted the reliabilty would be around ZAR 22000-00 ( about USD 3000)
they are currently moving premises and i will be seeing them around month end to discuss the final gains
Thanks fella's.
Cant wait to get some more feedback , at the end of the month when you get some more details.
