Report on H&R Sport Springs
Appearance: It is an absolute MUST to install the rear springs with the MB #4 (tallest) rear spring shims in order to achieve a relatively even ride height drop front-to-back. With the tallest spacers, the front fender gap (tire to lip) is still a bit more than the rear, and in a perfect world, I would want it evened up. (I wish there was a #5 shim!). As I thought, the lowered car looks longer and sleeker. (Pics soon.)
Ride: The ride is noticeably firmer, but by no means harsh. Sharp bumps are soaked up gently, and longer humps and dips are handled more swiftly with a lot less float and reaction time. The ride is simply more "serious" and less luxurious. I used the stock shocks and I don't regret it.
Handling: The real test will be next week at the track, but so far, it's pretty clear that turn-in is sharper, and the car stays flatter. I feel that it is a good compromise -- any better for the track would degrade street use. I'm not expecting any change in the relentless understeer, but that's impossible to tell on the street on cold tires. We'll see what kind of speed I can hold through the uphill "S" turns at VIR!
TireRack did a comparison of H&R Sports, Eibach and OEM springs, and the H&R and Eibach were very, very similar. I have to confess that I was influenced by price (H&Rs were cheap), but I have no regrets.
Certainly, a rather substantial improvement in overall vehicle feel. An excellent modification for the investment. Don’t know how many hours your technicians billed, (none of my business) but I’m pleased you are satisfied with the results. Did my install in the garage, therefore the ~$240 for springs was easy to rationalize. For me, it’s good therapy.
Prudent of you to source and specify the #4 pads prior to the installation. Because I had previously shared with the forum a heads up about the potential lack of rear suspension jounce travel with the #52732 H&Rs, I don’t want you to think I’m a nattering nabob of negativity. I merely installed the #52792-2 (W203 wagon) rear springs to retain sufficient ride height while carrying a load. IIRC, you have a MDX as the family car. My C32 is her daily driver, as I drive a GMC for business. When we are on a road trip, it’s in the AMG. The Mrs. is okay with it, though. She has shared on occasion; “...it holds the road like a magnet...!”
That our cars now appear a bit more significant and purposeful is merely a pleasant side effect.
. Does anyone know what problems can occur after lowering? The last thing I want to do is pay money to lower my car so that I can pay more money to fix something because i lowered it. Thanks guys.
(PS: Two more days on the springs and I love them more every day. I feel much more connected to what the tires are doing. Anyone thinking about switching -- to ANY aftermarket spring -- do it. The lowered look is an added bonus.)
I think a C32 on oem shocks and lowered springs is not ideal with new shocks let alone 100k mile old shocks but thats me! So clearly we all have different ideas on what is ok as far as shock valving.
i will eventually upgrade to something stiffer, probably some C55 shocks...
, but I can't seem to find specific info on what exactly is needed to install springs on the front. I'll be installing H&R springs (thanks ultraman
From the attached pdfs I made, can you guys confirm that there are several nuts that will have to be replaced?
Also, the DVD docs say that chassis alignment is not necessary unless in the case of accident repairs. Have all of you who lowered with springs got alignment done to be safe? I just want to make sure whatever shop who does them is going to do it right.
Thanks guys!
The MacPherson strut front spring exchange is indeed a bit of a challenge without the correct tools. Okay, it’s impossible! The #203-589-00-07-00 strut nut tool is essential, unless you make your own. The requisite spring compressor is available at most rental yards.
Yes, the specified fasteners should be replaced. They are critical pieces. If you don’t replace them, then it is imperative that they be inspected, cleaned, and a thread-locking compound is applied. Many technicians don’t feel the need to do so. Being the ****-retentive idiot that I am, I purchased new fasteners. They are not expensive, but the peace of mind when getting after it is easily justified with the accounting department.
Had the alignment checked before and after my DIY installation. Because the front (and rear) of the W203 is not readily adjustable for castor and camber, those specifications were, not surprisingly, within specification. Gained more than a degree of negative camber in the rear which, while contributing to inner tread wear, improves adhesion at the limit. The front remained essentially unchanged, with only a slight decrease in toe. In addition, you will find the reduction in front toe aids turn-in and helps to reduce understeer. You may notice the chassis to be less stable during highway jaunts, and under heavy braking.
As with any recipe, one must adjust to taste. Do let us know how it goes, and please post some pics!
John
I had five people in the car for the first time yesterday. I pulled out of my parking spot and heard an awful metal grinding noise. The car was so low with five people that it was rubbing at all times. We had to take a different car.
Renntech springs are on order . . .
I've had three adults + 2 kids (equivalent to 4 adults) and no rubbing.
Regardless, I want the slightly taller Renntech springs. I was never happy with how the rear looks lower than the front with the H&Rs. I don't want to buy a coilover system either.
