Please Help!!!!
Old May 9, 2007 | 11:22 AM
  #51
C32AMG_FL.'s Avatar
2005 E55
Update!!!!!!!
Took the car to a local mb shop and had them run complete star diag scan on the car, they came up with a code that read LOAD LIMIT IS ACTIVE! Has anyone else ran into this problem?
Old May 9, 2007 | 05:20 PM
  #52
MB_Forever's Avatar
E63 P30, CL500 Sport
C32 Torque/Load Limiter
If your car got the "controversial" secondary air pump flash, some believe that Mercedes installed a torque/load limiter hidden in the ECU. Again, I'm not an expert, so that could be it and could be not...
Did you get the PM with my contact info?
Old Jun 7, 2007 | 12:46 PM
  #53
C32AMG_FL.'s Avatar
2005 E55
Update!!!!!
Well I sent the ecu back to powerchip for the third time Monday. They called me back on Wednesday an said we sill don't have a fix for it, we will eventually but don't know when! I told them to return the ecu to stock and return it to me. I have contacted Kleeman and they said they can fix my problem (load limit) I will be sending it out to Kleeman on Monday.
Old Jun 7, 2007 | 12:48 PM
  #54
Eurocharged Rick's Avatar
SPONSOR
WOW! sorry you are having to deal with all of this...hopefully Kleemann can fix it for you...
Old Jun 7, 2007 | 02:01 PM
  #55
sales@eurocharged.com's Avatar
SPONSOR
C63S
If the ECU flash does not fix it, I would be willing to bet that you have a bad engine harness.
Old Jun 7, 2007 | 03:32 PM
  #56
C32AMG_FL.'s Avatar
2005 E55
Any info you can give will be much appreciated!
Old Jun 7, 2007 | 04:12 PM
  #57
dkflipse's Avatar
C32 AMG
Maybe just drive it over to Renntech - have them reflash the ECU and Dyno? They're in West Palm.
Old Jun 7, 2007 | 04:18 PM
  #58
C32AMG_FL.'s Avatar
2005 E55
Tried that, they don't want to work on it b/c the car has Evosport StageII, not Renntech kit.
