Blackstone lab report(trans)
Old May 14, 2007 | 05:30 PM
jimmyp's Avatar
Just got my report back from blackstone labs for my transmission fluid, no coolant was found on my 2002 38,000mi C32. Just wanted to tell everyone that it is cheaper then the dealer, but I will install a new radiator anyway just to be safe. No problems so far but everyone should do it!
Old May 14, 2007 | 08:02 PM
camel 2's Avatar
2016 C63S Coupe
Hi jimmyp,
I did exactly the same thing last week and also got a negative coolant result. I am also playing it safe and have ordered a new radiator to be installed at the next service, that way i wont ever have to worry about it again...
Old May 14, 2007 | 08:06 PM
dkflipse's Avatar
C32 AMG
I'm a new member (had my car a whopping 3 weeks). So I assume the factory radiators tend to go? Mine has 60K miles. So if you did it with 30 - I feel like mine's a ticking time-bomb!!!
Old May 14, 2007 | 09:02 PM
jimmyp's Avatar
Yes I would do it! They also recommened the fluid be changed,so much for the 100,000 fluid. I will have mine flushed after I install the radiator.
Old May 14, 2007 | 10:25 PM
Eurocharged Rick's Avatar
SPONSOR
not necessarily, my radiator has 108,000miles on it with no leaks...if you are paranoid about it, then change the radiator...if you maintain your car and check your fluids regularly, then this should never become a problem...
