The New brakes are here !
Old Jun 26, 2007 | 04:27 PM
  #101
Tump43's Avatar
2014 E350 4Matic
AMG 030 Floating Front Rotor Question
Will the AMG 030 floating front rotors from a 2003 and up SLK55 or CLK55 fit on my C55 with the stock calipers? or, do I have to get the six piston front 030 AMG calipers to make this work?
I now want the front rotors to match the rear rotors (i.e. drilled and slotted) and I want the lower weight of the 030 front rotors but, I do not think that I particulary need the six piston front calipers.
Thanks,
Old Jun 26, 2007 | 05:09 PM
  #102
SUPR C's Avatar
02 C32, G60 Corrado
Just beautiful man. Can't wait to see them on the car...
Old Jun 26, 2007 | 05:18 PM
  #103
Harry Madan's Avatar
03' E39 M5, 10' CLS63 AMG
Thanks,
i think they will fit, but the full surface of the rotor will not be used, so it will look bad, ur have this shiny portion that the calipers are using and then the other non used portion that will either show rust or the silver paint.
  #104
ya me too, i just got my car back last weekend and i will be putting the brakes on this weekend. (if everything goes well)
Old Jun 26, 2007 | 06:55 PM
  #105
jerryxu's Avatar
slk32 Renntech
2 thumps up
Will they fit my car too?
Old Jun 26, 2007 | 07:11 PM
  #106
Originally Posted by jerryxu
2 thumps up
ya the will fit ur car too, u need a min of an 18" AMG wheel to clear the new calipers
Old Jun 26, 2007 | 09:44 PM
  #107
Quick1's Avatar
AMG
So how long you have now before you get them installed?
I truly can't wait to see them on your car cause thats one of the first mods i will do, So there should be no problems clearing the Twin Spoke AMG wheel for sure right?
Old Jun 27, 2007 | 01:41 AM
  #108
i will hopefully install them this weekend, if i dont have to go out of town. ya they will have no problems clearing the Twin spoke AMG wheels as long as they are 18" minimum.
Old Jun 27, 2007 | 08:27 AM
  #109
mertd93's Avatar
04 E55 B07, 11 CL63, 17 GLE63S
Thanks,
The 030 floating rotors won't fit because they are 14"(part #209 421 01 12), but the -030(stock slk55/clk55 2005/2006) floating rotors will fit because they measure 13.6 (part # 171 421 01 12)just like your stock disc, the only difference is this rotor is 1.25" thick as opposed to 1" thick on your stock rotor(203 421 09 12). And they will stop so much better since they are composite.
Old Jun 27, 2007 | 12:11 PM
  #110
Tump43's Avatar
2014 E350 4Matic
Mertd93 --
Thanks, I will shop around for a set of "-30"? (stock slk55/clk55 2005/2006) floating rotors (part # 171 421 01 12).
And have them installed. Any leads on good places to buy?
Harry --
Thanks for saving me from getting a missmatched rotor. Your brakes do look fantastic!!
Old Jun 27, 2007 | 03:16 PM
  #111
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
How do you plan on handling the backing plates?
Old Jun 27, 2007 | 04:30 PM
  #112
mertd93's Avatar
Mertd93 --
Harry --
Best place is oempartsdirect.com
Old Jun 27, 2007 | 05:10 PM
  #113
the only one that i need to adjust is the rear, i may cut it or just order new plates ones off the CLK63 or SLK55 (030)
Old Jun 27, 2007 | 05:16 PM
  #114
some bad news, my car may be going back in the shop this weekend, so i wont get a chance to put the brakes in the car this weekend. the car's hood is getting re-painted and some other adjustments are being made. so i will install the brakes as soon as i get my car back again. sorry i know it really sucks i'm dying to put the brakes on the car.
Old Jun 27, 2007 | 09:56 PM
  #115
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Those brakes are sweet - I concur, can't wait to see 'em installed.
I'm due for a brake job w/ my C32 but price is likely going to keep me from upgrading to a BBK (unless anyone has a used set they're looking to get rid of!) - I've read positive reviews of EBC Redstuff pads, so I'm pretty much sold on those F&R, but I'm having trouble sorting out rotors. My question is, when looking on websites like brembo.com (part # 25766) or the rotors on performance products, are these OEM rotors cross-drilled like the stock rotors? If not, is there a good supplier to get the stock, cross-drilled front rotors from?
Thanks for the help!
Old Jun 27, 2007 | 10:08 PM
  #116
BLACKROOF C55's Avatar
C55 AMG
thats sexy, what car was that originally for?? is that an up grade for the 32? is that a dealer item?
Old Jun 27, 2007 | 10:34 PM
  #117
Brembo makes the brakes for mercedes, so if that is the part # they have give u for the rotors that will fit ur car, i'm sure that they will be the same as the stock C32 rotors, if u have any questions u can call them and they will ans ur questions for u
they are OEM benz part off of the CLK63 or the SLK55 (black series with (030 package)) this is a big upgrade from the original C32 brakes. and yes it is an OEM dealer Item
Old Jun 28, 2007 | 02:00 AM
  #118
C55 AMG
how much did this set of brakes run you if you dint mind me askin.
Old Jun 28, 2007 | 02:07 AM
  #119
$4500 us
Old Jun 28, 2007 | 03:10 PM
  #120
Quick1's Avatar
AMG
Thanks for the info Harry, Good luck Hope everything goes well
Old Jul 2, 2007 | 09:57 AM
  #121
movarz's Avatar
My car is a c-coupe C30 CDI AMG.
Last week the brake upgrade came true.
Finally my sportcoupe has new big AMG brakes.
Thanks to everybody for the information obtained from this great forum, especially Rubensans, Harry Madan and Steve MBenzNL.
This model had the same brakes as a c32 at the from but only a 300mm not ventilated disc at rear (as a normaly c-coupe).
Now is time to enjoy!!!
Thanks a lot!!!
Attached Thumbnails The New brakes are here !-c30.jpg   The New brakes are here !-c30-2.jpg   The New brakes are here !-c30-3.jpg
Old Jul 2, 2007 | 10:46 AM
  #122
rubensans's Avatar
Brabus K3
Thanks a lot!!!
It look very sweet !!!
Congratulations.
Best Regards.
Old Jul 2, 2007 | 11:19 AM
  #123
c32used's Avatar
LET C32 2002
VERY NICE! POSTS PICS WHEN YOU CAN. WHAT WAS THE COST? PM ME IF PRIVATE. ALSO YOUR CAR HAS BEEN COMING OUT PRETTY NICE SINCE YOU STARTED. ALL YOU NEED NEXT ARE CLK GRILLE AND FLAT HOOD EMBLEM FOR NOW. I THINK I REMEMBER SOMEONE SAYING IN A THREAD THAT OWNERSHIP IS ONE COST BUT THE MODDING IS ANOTHER COST(SOMETHING LIKE THAT)...LOL
SWEET!!!!!!!!!!
