Anyone Running on Regular Gas?
a car that can't do the throttle reset.
If are gonna be cheap about buying premium gas, you shouldn't have bought a Mercedes, let alone an AMG. Its unfortunate that used C32's are going for so cheap now.
Lotsa posturing here and not much factual guidance. My daily driver was a supercharged pontiac. It had a knock sensor that retarded the timing when it heard first indications of detonation. This allowed use of lower octane fuel but at a penalty in performance. The knock sensor worked well and effectively prevented any long term engine damage, even if you were routinely running dung gas. The Pontiac community got pretty good at diagnosing the amount of KR (knock retard) that different mods could create, because some combinations of breathing restrictions coupled with a smaller supercharger pulley could actually make the car run slower.
Does the C32 have a knock sensor? Does it retard timing? Do we know how much?
It doesn't matter if the C32 has a knock sensor or not. The fact is that running "regular unleaded" in a car the REQUIRES premium is a dumb thing to do. Yeah sure the computer will retard timing (that should answer your knock sensor question) but what happens when you run on retarded timing???? Motor runs hotter and is less efficient.
Why did one buy an AMG if they cannot afford the extra $0.20/gallon? What factual guidance do you want ????
Ran regular on a 2003 ML350 for 3 years: no problems whatsoever.
Ran regular on a 2003 S430 for about a year: same deal.
Both these cars require premium, yet ran fine with regular. Why, because they're relatively simple naturally aspirated motors with moderate displacement. On more complex motors, stick with premium. Since the SL has a great deal more components to the motor, I run only premium in it. Since your motor is supercharged, you should only run premium in it.
You say there is no long term damage. I say, I’ve rebuilt plenty of engines and know that to be incorrect. Want to blow a head gasket in half the time it would normally take? Looking forward to replacing a set of valve guides? Just run regular gas. Why? Aside from lousy fuel economy and no power, engines with retarded timing have dramatically higher combustion chamber temperatures. Anyone whose ever looked at an EGT gauge or looked at a cylinder head temperature gauge (this is where the thermometer screws into the head and checks the temperature of the aluminum not the coolant) can immediately tell that the combustion chamber is much hotter. And a blown head gasket is the least of the problems. I’ve seen holed pistons from pinging. Will it happen on the first tank? Nope. The second? Probably not, but when the headgasket blows, the engine starts sucking oil past those worn guides, or the engine limps into the shop on 5 cylinders, you'll realize that the Mercedes-Benz powertrain engineer with the PhD in Mechanical Engineering who designed the engine just might be right - it does require premium fuel.
Now, assuming someone saves a whole $3 per tank using substandard fuel (15 gallons at 20 cents per gallon savings), how many tanks will it take to break even on a valve job?
#32
buick lesabre
Still mostly speculation and opinions here. I guess nobody has tried the experiment in question so no facts are available. I'm not surprised given the mindset of folks who tend to buy these cars. There seems to be a fair amount of pride in driving a car which requires premium fuel!
Thanks anyhow.
Thanks anyhow.
#33
Speculation and opinions??
You go ahead and experiment because the answer to your question is common sense. If your car is under warranty the FIRST thing the dealer will do is check to see if you are in fact running the correct gas. If you're not, bye bye warranty. That is a FACT.
What MarcusF replied with is FACT. Do you think manufacturers require PREMIUM gas on high performance forced induction and high compression motors for fun?????
Please go do some research regarding combustion engines and why higher octane gasoline is REQUIRED (not recommended) before you mouth off about what is/isn't fact.
#34
True confessions: I almost always ran premium. Sometimes stepped down to mid grade when the prices were screaming up. Never had the courage to run regular because I just wasn't sure. And I didn't have any FACTS on which to base that decision. And FACTS is what we're looking for here.
"the FIRST thing the dealer will do is check to see if you are in fact running the correct gas. If you're not, bye bye warranty. That is a FACT."
Can't resist stirring the pot. How many dealers really have fuel testing equipment and knowledge to test the octane of your gasoline?
#35
Super Moderator Alumni
Thanks anyhow.
Thanks anyhow.
It appears that the only "speculation" is your level of expertise, compared to guys with years of tuning, driving and racing the C32 and C55. My "opinion" is that you should go ahead with your "regular gas" experiment and report back to us in a year or so.
Bah-bye.
#36
Sure let's stir the pot.
There are other methods other than an octane tester to determine the problem at hand. They don't need to be fuel experts to know what happens to a motor when it is damaged due to excessive detonation and the result of running fuel that is not within the recommendations of the manfuacturer.
So let's keep stirring.....
What else causes a motor to excessively detonate when the car has not been at all modified to increase the pressure inside the cylinder walls?
If we're talking about a complete motor replacement because it was destroyed from detonation, you can probably bet someone other than your everyday tech will look into the issue.
Now, since we're all "posturing", who is willing to test the theory out. Run your car on Regular as hard as one would with Premium and report back in a year or two. Since you all want FACTS, someone should go do it and provide us with some.
I can tell you from experience, that even WITH PREMIUM, my car will ping in high load, low RPM situations. I wouldn't even bother with Regular gas.
#37
Here are some facts for you my friend drives a clk 320 and was running 87 in it for app. 6-8 months, we both drive our cars very hard. He was complaning ygat his car was running like ****! I told him he neefs to change to 91, in the time he ran 87 I think 3 sensors went bad. After switching to 91 car is running much better and stronger!
#38
buick lesabre
I poked around on the internet and did find some information. The suggestions that the engine runs hotter, performance may be degraded and that supercharged engines are the least adaptable to lower octanes are supported. Notions about engine damage and warranty problems are not supported.
You all might appreciate this news article, which features comments from MB-USA and from some Chevron fuel engineers:
http://www.toyota-4runner.org/showth...p?threadid=683
Thanks!
Thanks!
#39
2003 C32
Thanks!
Thanks!
Great link!
This begs the question. Is anyone going to quibble over $171 per year? If you do, then you have more pressing issues than owning a car (any car).
#40
Thanks!
Thanks!
#41
1 Post
'08 M5, '10 Land Cruiser
I don't think diesel power will get you off the line quick mainly because most diesel revs slow even tho they produce a lot of torque. to a comparable gasoline engine the one using gas will still be quicker with less torque. Top Gear did that 550i vs 550d test a while back.
One of the major benefits with diesels is that they have a far greater range than their petrol equivalent. 500 miles between fill ups makes everyones life easier.
To the OP- 20 cents difference. Come on now
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
#42
What about higher octane
Sorry guys I drive an old S class but am enjoying this thread. I also have a question. Out by the raceway they sell 101+ octain that I've seen. Also at Lake Havasue they sell it for boats. I have toyed with the Idea of running a tank through to see what it would do both proformance wise & cleaning out the engine. So good idea or bad to run that fuel?
#43
Higher octane means more resistance to pre-detonation or pinging, and it allows you to run higher compression. But since compression is what it is, at some point the higher octane does not help. In a computerized engine, higher octane might eliminate pinging under extreme loads, which will stop the computer from retarding ignition, so you can increase performance. But at some point, the octane is high enough to eliminate all pinging, and more octane will do nothing.
#44
1 Post
![Post](https://mbworld.org/forums/images/icons/icon1.gif)
https://mbworld.org/forums/w211-amg/197529-new-e63-w-030-perf-pkg-w-pics.html
This thread is ongoing in the W211 AMG forum and relevant to what we're talking about here.
#46
1 Post
My father back in Europe has a new 535d Sport Touring (engine is a 3literTT, despite the misleading badging). 284bhp, 429lb/ft and still delivers a real world 33mpg. 0-60 in 5.8, ltd to 155 and a dog cage in the back.
He traded from his 2004 17mpg Range Rover so needless to say he's pretty pleased as that thing cost $160 bucks each fill up.
Great looking C32, btw. I've always have a soft spot for that car ever since my aforementioned father bought one in 2003. They still have it and continue to blow the doors off any uninformed 330i's.
#47
MBworld Guru
white and whiter
I never actually saw the episode in question. I just know there was a 740d but never a 550d or 750d.
btw, if your dad wants a set of 22x9.5 custom forged wheels let me know
#48
1 Post
I'll try and find the episode, sounds interesting.
#49
MBworld Guru
white and whiter
I'm sure they're great but it's the mother's DD so she likes the stock 17s and the car is briliant silver so wouldn't suit the rims like obsidian. He wants to get an E63 for her but she is as in love with the C32 as the day she got it so is so far resisiting.
#50
School bus
Thanks anyhow.
Thanks anyhow.
