Supercharger not engaging
I took some time to log my last trip and it happen to do it, so I have a record of it. See the 1-table.pdf below and take a look at lines 496-510. You will notice there is little or no boost.
I suspect that it is either the S/C clutch, RPM sensor, or IC pump. I replaced my IC pump about 12k ago, but I'm not ready to rule it out.
I also attached the plotted version of the data.
Yes, I was hauling some @$$ during these runs. I wanted to see if I could get an accurate reading of boost. I guess boost and intake manifold pressure are not the same.
What kind of hardware are you using to collect and report this information? Looks pretty cool.
Try logging airflow from MAF function. I know we do not have MAF, but this option still should be on your menu to choose from.
And try doing couple more runs logging RPM vs. MAF vs. Intake Manifold Pressure.
I have joined GMGRacing (www.gmgracing.com) as sales/service manager.
I will posting more information about my move very shortly.
You can still stop by, address is on the website.
Thanks,
Yesterday 05:30 PM
My car does it once in awhile. I have not had a chance to look into it yet.
