Finally it happens to me!!
Is this the classic supercharger pump problem? I have CP warrenty, should I just take it in and have them replace stuff or wait for it to happen again? Does the supercharge sometime just not engage and this is not necessarly a problem?
Expert opinions are greatly appreciated.
Anyway, you will need to get it replaced. Print out some of the threads here, as explanation for the SA. Otherwise, they won't know what you're talking about.
Good luck!
I replaced my battery a couple of days after mine was replaced and the car didn't run right at all,... not as much punch and the trans seemed to take longer to upshift under normal acceleration. I called to speak to my SA and he got the head mechanic on the line with me. Took him all of three questions to zero in on things. His forth questions was had I replaced or disconnected the battery. When I confessed that I had had a new batter installed, he chuckled and scheduled me to return and he erased the old program and I guess re-write a new on top. Something about the systems going hay-wire or reverting when amps go below a certain level,... including your sunroof.
Apparently, replacing an I/C pump in the early C32's involves more than just the pump itself and requires a re-write of some sort. Some of the more knowledgable guys could prolly explain it better, and prolly with less words.
But just a heads up. My only question is will I have to take it in to the dealer everytime I forget and leave a light on? Guess it's cheaper than replacing a ROM chip or something like that.
Good luck!
I'll know for sure when I take it back Saturday. Like I said, the Shop Forman said over the phone that the change of battery caused just enough power interruption to cause this, although he didn't go into any Detail.
This is exactly how it is written on my Service Report:
Customer sates he is having issues with his Super Charger after 30+ minutes of drive time. He has communicated with MBUSA. (reply from e-mail survey after 1st visit and no resolution) Have Shop Forman get involved and get persmission from Client to drive his vehicle with client present. Electircal fault with Charge Air Cooler Circulation Pump. Verified complaint. SDS check, Code P2027-001 in ME Control Unit. Perf Diag Test of Pump Relay and Fuse in rear SAM. Checked Ok. Perf component Actuation via SDS and Current Consumption. Failed both test. R&R and Engine Lower compartment panel. Remove and refill coolant. Replaced Pump. Erased code. Road Test. Passed Test.
Looks like the part # for the pump is 000-500-03-86 (warranty). Job#2 is 99MBZ (have no idea what that is).
I'll find out as much as I can Saturday and let you guys know if it's a big a deal as I'm thinking it is!
