Looking for cheapest ODBII datalogging usb device..
Coming from the suby world, had an 04 WRX, Stage 4 w/Meth Injection, I had a ODBII usb datalogging cable, and used a program called ecuexplorer from tactrix. Just picked up an 02 AMG, and looking to do the same thing for some baselines before I mod. Looking for a cheap cable that does "the works" and what the best program is to use for the c32. I know the suby program was specific, so I'm sure its the same for the c32. I'd love to hear about any different types of programs if they exist.
Also looking into a dvd unit that can display gauges based on odbii info. I've never been down this route before, but if I can get that displayed on a dvd headunit, that would be awesome as well.
Appreciate any info, or anything for me to run on and google up. Thanks guys.
Tom
Watch for massive knock retard and high IATs when you first get it connected.
Welcome to the forum!
If you have not already installed TopGun32’s pulleys, would you kindly share applicable before & after figures with us?
I would be most appreciative.
I have many goodies going on the car soon
I have been waiting for this setup so I could do some good before and after testing.
I plan to do the following tests and post the results.... if anyone thinks I should be logging any other data, or doing other tests ......please comment
Stock
Log data with OBD2 scanner - Intake Air Temp/Timing/RPM/Oxygen Sensor or Boost
OBD2 scanner - 5 * 0-60 with same time between runs
OBD2 scanner - calculate HP
+Green filters + SL55 splitter + Phenolic spacers + new spark plugs
Log data with OBD2 scanner - IAT/T/RPM/OS or B
+Evosport Intercooler reservoir
+ASP Pulley
Dyno with A/F Ratio
OBD2 scanner - calculate HP while on dyno to get a correction factor for software HP
+stage 2/3 fuel change to ECU depending on previous A/F result
Dyno with A/F Ratio
All Mods
I will be installing the software at work so I can start testing tonight. Very excited.
The dashhawk is cool. I had the Scangauge 2. Same idea. But neither of those offer the kind of features I was looking for. Plus, I dont want something plugged in all the time. I bought the package for specific testing, not for day to day monitoring.
