19x 9.5 wheels fitment.
Amg C32
Got a quick question, got a offer for a set of HRE, offset is et 40 what size spacers do i need for it to fit ? its 19X9.5 all around. Or this wont work ?
You will have to pass.
08 M5, 06 X3, 05 C55
maybe if you want to stretch the tires out (225/30/19)... just maybe. It'll look like you're driving a go kart with wheels sticking out the sides
a 225 tire will not go around a 9.5 inch wheel and if it did its highly likely it wont drive very well and it will look terrible. THe min size that work well on a 9.5 inch wheel would be a 255.
you should see what some of the VW guys do... and yes i absolutely agree with you, it will look like ***. but some people like the stretched look.
http://forums.vwvortex.com/zerothread?id=2234638
a quarter mile at a time
Amg C32
hahhaa
hahahaah i guess its a NO GO. But in any case, if i can get a hold of a pair of 19.8.5 ET40 front and 19.9.5 ET40 rear, what size spacer am i looking in to ? I just dont want to jump in to this deal and get Stuck with it lol![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
So its a ET 40 and its 9.5inches wide.
Now a 8.5 wheel with and ET of 32 fits fine on the car with a few mm clearance between the wheel and the strut tube -- no fender rubbing with 225 tires. Now lets take that wheel and ad .5 inches left and right of center line and then move the wheel 8 mm closer to the strut tube. Given that before you had maybe 3-5 mm of strut tube clearance with the 8.5 inch wheel the 9,5 inch wheel likely will not even bolt onto the car.
To make it fit you will need to move the wheel 10-15 mm out towards the fender. Now with that happening the wheel likely is sticking out past the lip and the wheel and tire will just tear the body work to bits.
I went down this road with wheels and tires (on SMG's car) and all the wheel testing showed that the ET40 on a 9.5 wheel simply wont fit the car regardless of tire size and spacer.
Its not worth buying these wheels on many levels. A deal can be had on wheels that fit and you will enjoy them much more.
![poke](https://mbworld.org/forums/images/smilies/stickpoke.gif)
I am going to have to disagree on this one
The numbers just do not support that idea. Maybe with stock C32 spings (3 inches of fender clearance) and a very slow driver (no cornering or suspension compression) it will work.
But if you plan to drive and turn that car... it wont work any which way.
MBworld Guru
white and whiter
regarding to running the spacer could totally depends on the lip size on these custom wheels.
my advise: spend a little more and buy something that fits.
my friend's selling his DCR that's made for the C32 offset in the classified.
oops
