gearbox & differential fluid change
Old Jul 11, 2007 | 03:02 PM
neihouma's Avatar
02 C32 AMG sold!
hey guys I figured out how to do a differential fluid change on
slkfans page, but fumbled at the transmission part.
From what I can gather I see two possible ways to drain out
the atf fluids, one on the bottom on the oil pan, and the other
on top by the supercharger with a machine that sucks out the
fluid, but the question is how the hell do I fill up the 8.5quarts
of fluid? Please don't tell me I just fill it from there. I'm really
gonna kick myself in the *** if that is the way to do it.
Gonna use Redline ATF and 75W90 gear oil fyi who are curious.
Old Jul 11, 2007 | 03:41 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
No need to kick yourself! Have a look at these two links -
https://mbworld.org/forums/c32-amg-c55-amg-w203/157026-transmission-service.html
and
http://mercedesshop.com/Wikka/Trans7226Fluid
Trust they will prove to be at least somewhat useful. Let us know how it goes.
Old Jul 11, 2007 | 06:05 PM
Eurocharged Rick's Avatar
SPONSOR
yes, that is where you fill it, but why not pull the pan and change the filter at the same time?
also, just fyi, i was instructed by numerous reliable sources not to use the Amsoil fluid in the tranny and to go with the factory replacement fluid...that is what i did...
so if you use the Amsoil fluid, i will be interested in the results, please report back either way...
also, make sure you get the tranny measuring tool/stick from the dealer so that you can make sure you can measure the fluid...
Old Jul 22, 2007 | 10:22 PM
splinter's Avatar
Super Moderator
Originally Posted by neihouma
...From what I can gather...
So, how did you accomplish your ATF fluid and filter replacement?
Old Jul 22, 2007 | 10:35 PM
Fifth Ring's Avatar
C32 AMG
He's using Redline, not Amsoil. Still, I'd use the MB fluid.
Old Jul 22, 2007 | 10:43 PM
SPONSOR
yup, same difference...and i agree, i would stick with the MB fluid...i will be interested to see the results from this though...
Old Jul 23, 2007 | 12:38 AM
neihouma's Avatar
02 C32 AMG sold!
Sorry for not updating the thread. Did the ATF coolant flush, but only managed
to get 4.5 quarts of ATF out, changed the filter (140-277-00-95), trans oil pan
gasket (140-271-00-80) and the transmission dipstick (140-589-15-21-00).
Just pretty much what I said to you in PM Erick, gonna do the 03 Trans ECU
flash update soon. Gotta call the stealership to set up a apointment.
Old Jul 23, 2007 | 12:45 AM
SPONSOR
keep us updated...i want to know what happens with this!
Old Apr 10, 2008 | 11:07 AM
TopGun32's Avatar
completed this last afternoon with my local mechanic.
Very simple straight forward.
I was able to get about 4 +quarts of fluid (after leaving the pan off for a few minutes)
I only added 4 quarts for now. (easier to add then to remove)
Car is running smooth and shifts are better. I feel less vibration during a stop.
I paid $36 for the gasket and filter at the dealer.
bought the fluid at $5 per quart from a member on this board ($20)
paid my mechanic $40 for the job. ( I kinda helped too)
over all under $100 bucks.
But next time.. I really would like to do the Torque converter. I was not very comfortable doing now.
Hopefully somebody else can post some pictures how to best approach this task.
Old Apr 10, 2008 | 11:52 AM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
I read somewhere about disconnecting the transmission cooler line into the radiator and flushing the TC. After dropping the pan and replacing the filter you refill the transmission, start the engine, run around 2 liters of ATF into a container, stop the engine and refill, repeating the process until the fluid coming out changes color.
Old Apr 10, 2008 | 12:07 PM
c32used's Avatar
LET C32 2002
splinter's Avatar
Super Moderator
Originally Posted by TopGun32
...But next time.. I really would like to do the Torque converter...
Some good DIY information here...https://mbworld.org/forums/c-class-w203/237604-c230-sport-coup-s-all-things-transmission-related.html
Old Apr 11, 2008 | 01:40 PM
TopGun32's Avatar
I was thinking of doing this too. But you would wasted the fluid right?
I had only 6 quarts of fluid so I was not sure if I would be short.
I'm assuming my ATF fluid is not a mixed color.. since I was only able to replace 4 qts.
The car behaves better.. but probably will have the fluid completely flush in the next 6 months.
I had my TC replaced 2 years ago from the dealer.. so I know my fluid was replaced at least 40k miles ago.
Old Apr 18, 2008 | 12:49 PM
TopGun32's Avatar
I rmoved 2 liters of ATF and added 2 more last night.
I ran out of ATF so.. maybe next time I'll do the whole process.
Old Apr 18, 2008 | 12:56 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
neihouma, so did you ever use redline oil?
Old Apr 20, 2008 | 03:14 AM
neihouma's Avatar
02 C32 AMG sold!
Yes I did got 4.5L of gearbox fluids out & put back 5 quarts, measured it and
looks fine. Got the transmission jerk to go away for quite some time now.
Can't manage to simulate the jerk when before I got whenever I wanted it to.
After reading the link of how to do it, I think I'm gonna go ahead and buy 5
more quarts of ATF fluids and pay the stealership to do it. I still have 2 quarts
of diff oil I can't figure out how to pour it into, I know how to flush it but
can't find how to fill it in!
Old Feb 6, 2009 | 09:23 PM
splinter's Avatar
Super Moderator
Yes I did got 4.5L of gearbox fluids out & put back 5 quarts, measured it and looks fine. Got the transmission jerk to go away for quite some time now. Can't manage to simulate the jerk when before I got whenever I wanted it to....
Did you use Red Line’s C+ ATF?
www.redlineoil.com/pdf/3.pdf
Old Feb 7, 2009 | 10:38 PM
neihouma's Avatar
02 C32 AMG sold!
Hey Jon, sorry for not replying earlier.
I used the High Temp ATF fluid
http://www.redlineoil.com/products_g...8&categoryID=8
Old Feb 8, 2009 | 09:20 PM
splinter's Avatar
Super Moderator
Thank you, Rey. It’ll be going in on the next renewal.
Old Feb 9, 2009 | 05:36 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Interesting, Rey - thanks for sharing your experience. The one right above it (Synthetic ATF) is listed as an MB approved fluid, FWIW...
Old Feb 9, 2009 | 05:41 PM
neihouma's Avatar
02 C32 AMG sold!
Right on John! Anytime my friend!
Indeed it does Brett, I shoud've gone with that one, but many friends
(some owning their own performance shops) told me to go with the
High Temp ATF instead, can't go wrong with that.
Also FWIW I've tried simulating the jerk and I can't get it to act up again
Old Sep 4, 2009 | 12:44 PM
Dingleberry's Avatar
Marsaydees
bump, so which fluid is MB approved? The high temp or C+? Is this better than MB fluid?
Old Sep 4, 2009 | 02:11 PM
320 dreamer's Avatar
2003 porsche 996 turbo
go to advance auto and look in the oil row. by the rear end gear oils theres a small hand pump which screws onto the gear oil bottle. cost approx 6$ jack the rear of the car remove the top plug FIRST then the bottom plug and drain. should be a 14 mm male socket. you do this becuse if for some reason you cant get the top plug out you dont have a rear with no oil!
now attach the pump to the bottle. lay on the ground and stick the tube into the top hole and pump away! takes approx 2 qts. i use mobil 1 gear oil
as for the tranny flush if you did the pan theres a hard line connecting to a rubber line along the side of the engine. break loose. put rubber line in a container. start the car foot on the brake and shift the gears manually for a second or two each then shut off. should have approox 4 qts in the container. this only takes a few seconds. refill and your done!
Old Sep 4, 2009 | 05:44 PM
lomita's Avatar
C63AMG
Redline Oil
After speaking with the Redline Tech's, recommended Redline D4 ATF for our C32, and D6 ATF for our C63 AMG.
Old Sep 4, 2009 | 08:06 PM
Marsaydees
That's interesting. Why D4 for the C32? On their site they recommend D6 for MB in general.
