Other reasons for S/C to shut off...
I was driving on the highway doing a few consequent kick downs to check that when I depressed the gas pedal all the way down and press the switch, car would always down-shift. I did this a few times and noticed that if I am above 4000rpms and then press, the trany would sometimes decide not to downshift, even with pedal pushed all the way down. Perhaps that is normal
Now here is the thing: As I did that a few times, I noticed that the S/C shut down on two occasions as I pressed the pedal to accelerate. I know exactly how it feels as I had the I/C pump replaced 6 months ago and I know when S/C is not working.
Unlike with the classic faulty I/C pump behavior, the S/C came back on line quickly. At the end of my runs it was always on.
Is it normal for the S/C to shut down under certain conditions - likely too high AIT, despite of the working I/C pump ?
It wasn't that hot out 80-90 and was only driving for like 15 minutes or so. I was going around 80 and floored it and the engine roared but went no where. This is the first time the SC shut down since I have owned it. It was working again within a minute and hasn't given me a problem for the past 2-3 days. I went ahead and ordered a new IC pump anyway because it was replaced quite a while ago. Guess I will just replace it anyway since I am selling the car and don't want it to fail right after I sell it.. LOL..
I've never had it happen at other speed/shift/rev bands, so if you're getting it going from 2nd to 3rd, or independent of shifts it might not apply.
I've seen several others report the power-dump I describe above.
Sorry if that just clouds this issue, but it's known effect.
Mine only does it from a stop...about 1 out of every 10 stops it won't engage. To get it working, I take my foot off the gas and re-apply pressure.
I've replaced the S/C and most of the sensors, but it still does it.
I'm guessing it is the sprint booster or TP sensor.
I had a problem with one of my Magnacor wires not making good contact and it was shutting down my kompressor.
I ran like that for about 2 months thinking it was my kompressor clutch.
The aftermarket wires are nice, but stock are better.
* I had the whole S/C clutch replaced under warranty because of the bearing
, so the harness may not have been connected well* the throttle sensor was replaced a few months back and after that I changed the pedals with the nice aluminum set. I was careful with the harness, but who knows.
* I/C pump replaced a few months back, as I mentioned already
* no SB installed
Now that I think of what happened again, when the S/C did not work on accelleration, it seemed that it was back on as soon as I let off the gas pedal and keep cruising for a little while (can also tell by the sound). Though when I pushed the pedal again, I could feel the S/C going off - like something tripping the car and then the slow acceleration. All this at about 60 mph.
I really hope it was only the series of pedal flooring and rpm revs that caused all that.
