intake resonator removed and new wheel center caps
Old 08-20-2007, 01:29 AM
MBworld Guru
FrankW's Avatar
white and whiter
so last friday Jose and I took a saw to the intake resonator and chop them off. the result is great with a nice and throaty intake suction noise. my foot tells me the throttle response better up top. 5th gear passing from 80-95 without drama.
also did the caps
too see more go here http://www.flickr.com/photos/hippofr...7601526546444/
Old 08-20-2007, 02:18 AM
Code3 Performance's Avatar
C32, Cobra, 700hp Vespa
I removed the intake resonators a few months ago. I agree with your assessment, they definitely give a throatier intake sound, and perhaps a little better throttle response. It definitely didn't hurt anything
Old 08-20-2007, 08:50 AM
rlee02135's Avatar
2004 C32 ///AMG
where is the intake resonator?
Old 08-20-2007, 10:51 AM
neihouma's Avatar
02 C32 AMG sold!
You mean intake baffles right?
Old 08-20-2007, 02:51 PM
amgstyle's Avatar
2002 SLK 32 AMG
can you guys show me where the intake baffels are? and what you sawed off. i want to try this mod out. thanks
Old 08-20-2007, 05:11 PM
MBworld Guru
FrankW's Avatar
white and whiter
take apart the part where the square green filter label is and it's pretty self explainatory
Old 08-20-2007, 07:02 PM
rlee02135's Avatar
2004 C32 ///AMG
Hey Frank,
which part do you cut out?
Old 08-20-2007, 07:58 PM
MBworld Guru
FrankW's Avatar
white and whiter
you need to first remove the airbox from the car and pop open the resonator box careful not to break the tabs on either side. I broke one of them and had to ziptie the resonator box to hold it together), take the chambered inner tube out, cut and leave the ends (you'll need the ends to put the resonator box back onto the airbox.
Old 08-20-2007, 08:11 PM
rlee02135's Avatar
2004 C32 ///AMG
thanks
do you mind sharing what kind of paint you used for the engine cover?
Old 08-20-2007, 08:15 PM
MBworld Guru
FrankW's Avatar
white and whiter
Originally Posted by rlee02135
thanks
dupli-color Candy Apple Red.
Old 08-20-2007, 08:35 PM
rlee02135's Avatar
2004 C32 ///AMG
thanks Frank
I won't copy your engine cover
Old 08-20-2007, 09:14 PM
MBworld Guru
FrankW's Avatar
white and whiter
thanks Frank
just make sure you sand and use a higher heat resistance primer before you spray the color.
Old 08-20-2007, 11:02 PM
WaveyKat's Avatar
Something Slow
i like candy Apple yummy!
Old 08-20-2007, 11:55 PM
SiLvaC32's Avatar
C32
haha, nice frank!! you going nuts with ur mods!
Old 08-21-2007, 12:18 AM
MBworld Guru
FrankW's Avatar
white and whiter
waveykat, thx mike
silvac32, thanks jerry, i'm finally somewhat catching up to you
how it looks when sun hits the candy apple red.
Old 08-21-2007, 12:21 AM
rlee02135's Avatar
2004 C32 ///AMG
waveykat, thx mike
do I hear plans for a Carlsson RS Widebody?
Old 08-21-2007, 04:18 AM
c32used's Avatar
LET C32 2002
Hey Frank I noticed what appears to be a carbon fiber hood on one car is it? If so where can I get it? Also where you get the paint for the engine-cover? What grade sand-paper and what primer and color? Was it stripped down to bare or scuff the original paint only.
Old 08-21-2007, 04:24 AM
jturkel's Avatar
02 C32 AMG
FrankW
did you wrap your intake with foil for heat resistance for the intake temps?
Old 08-21-2007, 04:46 AM
MBworld Guru
FrankW's Avatar
white and whiter
robert, that's a no...lol
c32used, it is a VIS CF hood on Jose's car. you can search VIS's website for thier dealers for one. they run about 5-600.
I think it was the 150 grit to strip the original paint and 600 to somewhat smooth it out. forgot what primer, but the color is candy apple red by duplic color as mentioned in above post.
jturkel, no it's not foil. it's Thermo-tech heat insulation cloth. i was going to cover it with some stockings, but didn't get around to do that.
Old 08-21-2007, 12:21 PM
Moderator Alumni
TruTaing's Avatar
w203 m112
++ do it frank.
Old 08-22-2007, 04:03 AM
c32used's Avatar
LET C32 2002
Hey Frank I never heard of VIS so please write the website and thanks for other info.
Old 08-22-2007, 04:20 AM
MBworld Guru
FrankW's Avatar
white and whiter
visracing.com
Old 08-23-2007, 02:03 AM
c32used's Avatar
LET C32 2002
visracing.com
I went to link but when I put info into search boxes like make, model, etc and carbon hood it shows nothing. Am I doing something wrong? By the way where you get the Duplic paint at?
Old 08-23-2007, 02:36 AM
jturkel's Avatar
02 C32 AMG
i think this may be it:
http://www.visracing.com/newcatalog/...duct_info.html
Old 03-04-2008, 11:18 PM
l3iGD's Avatar
AMG
A step by step tutorial to do this intake mod would be really cool for slow people like me!! I am about to install some phenolic spacers so I figured I could do it at the same time. Thanks in advance
Quick Reply: intake resonator removed and new wheel center caps
