Boost Controllers???
He mentioned something that he thinks its about 10-15hp gain by increasing the boost up by one. If our cars set boost is 14psi....that means an increase possibly by
60-90 hp gain by a simple device manager
The key to building a boost controller for an SC car vs. a turbo is that the boost controller can only bleed boost. You will still need to run a larger pulley if you want to get more HP out of the car.
So if we had this SC boost controller and you were running a custom pulley designed to hit 26psi. Well you could set the controller to bleed boost at anything past 20psi. This would let you hit your 20psi sooner than if you were running say the LET pulley. Of course you might not have a good day if the boost controller failed.
Nor do we want one
A waste gate is simply a device to PREVENT over boosting.
Blowers and turbos are differnt animals. Blowers build boost by compressor size, ie volume, and rpm. This is why you run a bigger pulley, more rpms, on the same size volume, ie more boost pressure.
Turbos rely on exhaust pressure, again using the internal turbo voulume, buch with a greater rpm variant. More rpm impeller speed, more boost, hence a waste gate. This is why a turbo NEEDS/REQUIRES a waste gate, because of the EXTREME variant in impeller rpm, 60,000-well over 100,000.
Oh well, I could write pages here
See yeah
Me bad
I ment Larger crank pulley, and yes that means, EVERYTHING spins faster, as we can't change to a smaller blower pulley due to the clutch
Changing all the other pullies simply keeps thing at or near stock speed, ie larger crank, larger water pump, and or allows use of the same belt, Larger crank, smaller idler,etc, etc. Differnt companies take differnt approaches as to how MANY of the accesories get changed.
You get the point my friend
See yeah
