Sprint Booster Help/mass air burned up
Hi guys I got the sprint booster for my C55 and I installed it...Well the car drove nice for a few mins then my check engine light came on and I started to have Idle speed fluctuation next thing, the car is turning off. I took off the sprint booster and reset the ecu...I'm now still getting the check engine light.So, I go to the dealer...my friend who is a tech tells me the mass air has gone bad on the car...I email the vendor and he explains that these cars have a tendency to do this. He also explains that when you replace the mass air the car will be fine and to put the sprint booster on again. I like the way the car drove but i dont want to break down again or burn the mass air up.
Keep in mind this car has had 0 issues with electrical or mechanical problems ever. The seller is ver fair he is willing to refund my money if I want "very good thing" but I want to know if this has happen to anyone else.
please chime in..I would hate to send it back honestly the car drives like it has 50 more hp 100% snappier
it was code# P2004-008 and the p0101 found that the air mass singnal wire was faulty. singanl voltage was check with HFM-SFI voltage was found that out of specs 1.051 volts
techs notes by the way..
What exactly is your question? It sounds like you already made up you mind on what the problem is.
On the other hand, why anyone would pay good money for a "device" like this that simply depresses the throttle pedal further is beyond reason... on most other boards the sprint booster has been blown apart for a rip off since you get the same effect just by pressing the gas pedal farther, and without it you actually have greater ability to modulate the throttle during cornering or when the wheels are spinning. It makes the car no faster... this used to be a trick used by auto makers (fast ramp throttle cam) to fool drivers of slow cars into thinking they were faster than they actually were.
. I know the car is making more power but I like a faster throttle response...The MB throttle in my humble opinion is way way too laggy. Are MB mass air's on these cars "AMG 55's" this crappy?
. I know the car is making more power but I like a faster throttle response...The MB throttle in my humble opinion is way way too laggy. Are MB mass air's on these cars "AMG 55's" this crappy?#1 There is NO mass air flow sensor on a C32
#2 K/N's DO NOT HURT MAF"S, I have run them on every car I have EVER owned with NO problems. Check their website and they GUARENTEE this fact.
Keep in mind that it usually is JOHN DOE, that thinks if a little oil is good, A LOT IS BETTER that causes this issue. However K/N shows a video of SPRAYING oil on a MAF and IT STILL WORKS!
http://www.knfilters.com/MAF/massair.htm
Oh well, just wanted to strighten this up a little
See yeah
PS: I do not work or have stock in K/N's by the way
in that case I'll take apple OS for my MB
Seriously Whats up with this update?
Does anyone have a sprintbooster on an C55
Input will be welcomed
See yeah
However, my C230 did have a MAS and I don't care if you have had K&N's in all your cars or not, worked for K&N or are just endorsing them as you mention. They DID in fact affect my MAS sensor (proven by performance shop and Mercedes dealer). I won't waste time debating you on this, after about $800.00 in testing at both shops, I firmly know what the problem was. Your experience vs mine, nothing will change that. Check the website? It's called marketing!
