ZEX or NOS?
Old Oct 11, 2007 | 10:52 PM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
ZEX or NOS?
I can't make up my mind on which is the better brand for our cars.
Any recommendations?
Old Oct 11, 2007 | 10:58 PM
c55asleep?'s Avatar
Bicycle
i think as long as it is a wet system it does not matter but personal choice on my car is nos.
Old Oct 11, 2007 | 11:20 PM
AMGSC's Avatar
I found a site that sells a Nitrous Kit specifically for SC'd or TB'd cars. It's called Cold Power made by Cold Fusion. Anybody heard or used it? So far the leading brands seems to be NOS, ZEX, NX, and Cold Fusion. I sure need some guidance on which is mos suited for MBs.
Old Oct 11, 2007 | 11:45 PM
SiLvaC32's Avatar
C32
i am using ZEX on my car. I believe AMGJERRY is using the same.
Old Oct 12, 2007 | 12:17 AM
AMGSC's Avatar
Would you happen to have the model number? The most expensive one seems to be the multi=stage kit that sprays at WOT and then again by using a switch on the dash? Is ZEX the most advanced in terms of technology?
Old Oct 12, 2007 | 11:41 AM
sales@eurocharged.com's Avatar
SPONSOR
C63S
The ZEX kit has the solenoids built in to the control unit. This means that you only have to mount one box, vs with the NOS setup you have to mount the control unit and 2 solenoids. Either kit will be fine and the outcome will be the same. However, I prefer the nozzle on the Zex kit.
You will want this one.
See how small the control unit is? Very easy to hide.
Old Oct 12, 2007 | 02:04 PM
SiLvaC32's Avatar
C32
yes, that is the unit that i got.
Old Oct 12, 2007 | 02:28 PM
AMGSC's Avatar
I'M going to pull the trigger but am still a bit afraid based on some FAQs on the NitrousDirect.com website.
For instance, detonation, hydro-lock, etc... What are some of the real risks?
Old Oct 12, 2007 | 03:00 PM
SPONSOR
C63S
Start off small and spend about 3 hours on the dyno tuning the kit.
With a 35 shot, I picked up 40HP and 60+Trq at the wheels.
Old Oct 12, 2007 | 04:25 PM
spr's Avatar
spr
I am surprised no one has made a module that interfaces with the computer to retard timing.
Old Oct 12, 2007 | 06:39 PM
billtc55's Avatar
Porsche Cayenne Turbo
I will be selling my full setup (no longer have car)
2 bottles, Drive-by-wire switch (WOT and On-Off window based on rpm's) Purge, MB MAF taped for the nozzle, presure controlled bottle heater, all wires hoses, relays and switches, full arangement of jets. scmatics on how to connect to your ecu
Will be listing on ebay some time next week some photos can be seen here
https://mbworld.org/forums/slk55-r171/213837-slk-r171-parts-sale.html
dyno at 413/499 at the wheels in a 06 slk55 and times slips in the 11.50 range with MT drag radials will also have a set of them for sale on C32 rear rims with 5 passes on them (no big burnouts)
can post track and dyno video links.
Dyno Pull
