Can a modded NA C55 match the C63 in acceleration?
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
I know quite a few SC C55's actually, but again, who cares how many; that was not even at issue. I also know a guy who had AMG custom make him a car on the w203 c55 07 chassis TT'd and built by AMG with SLR components pushing 8-900hp! Again who cares!
C32 owners are rather rediculous. I'm not sayiing your car isn't cool or is inferior or anthing else. I am just saying who cares when it's irrelevant to the conversation- butt out about c32 stuff. Not everything on this board has to involve a c32! I'm not intersted in being a moderator.
look you have a cool car......and so do i....errr..well mine may be a bit cooler no?
anyway......lighten up dude.....it's JUST CARS!
lol MIR has no magic and if u read it was 92+ outside and that the DA at 2500+, i can guarantee those times can be equaled on street tires in better weather, DR's are going to help the ET and hurt the MPH, its a "mid 12 low one teen car" in better weather on street tires. The last thing I am going to do is speculate about how a C63 will run since we dont have the hard data yet, I listed Craigs data as a fast NA C55 for comparison.
![Thumbs down](https://mbworld.org/forums/images/icons/icon13.gif)
wow your old c32 is cooler than my c55 which you know absolutely nothing about? It's comments like that, that just show your inferiority complex. I don't even go there, nor do I need to. I will yet again waste my time no further with another c32 owner.
2006 Mercedes C55 AMG
However the topic is C55 vs. C63. Not the C32 so the quips about the C32 makes this thread a long, useless post with no value because it's full of off topic items.
SPR is having one of his "mean" days. :-(
Sorry that the thread has been hijacked. But when SPR goes off the deep end, it's like watching a train wreck. Messy but entertaining. Only regret that it's late Friday and we'll all be moving on to better things soon.
#32
so who do you waste time with anyway? the guy who had AMG custom make him a car on the w203 c55 07 chassis TT'd and built by AMG with SLR components pushing 8-900hp???
#34
so...this was fun. didn't mean to get you riled up spr. well, maybe a little...
fifth. think you're right. i'm off to the gym. then go check progress on the c32larger heat exchanger install. get cleaned up then pull out the ferrari for drive. (it rained for 3 days but today was beautiful) ....the wife and kid have plans so i'm gonna go enjoy my lamb chops at my fave restaurant just me and a copy of f1 racing mag. that should be awesome.
this was the most i posted in one day wow!
have a good weekend.
lyou can get back to "c55 vs c63" now boys......
#35
CLS, SLK, ETC
AS for the comparasion, who really cares.. C32 / C55 has its own Pros / Cons.. Don't need to argue which one is better or worse...
#37
#40
Heres the mod list you would need:
- High flow header
- high flow cats
- ev*sport accessory pulley system
- AMS Crank pulley
- Performance intake system (one that actually makes power, not a fancy stock looking CF one)
- mechanical fan delete (replace w/ Spal fan)
- performance software
- 150lbs removed will really help out.
That should get you very close, you should be able to hang, whether it would be a dead tie (or even slightly faster) who knows but it would sure be a damn good race.
- High flow header
- high flow cats
- AMS Crank pulley
#42
2006 C55 AMG, 2.8L Quattro, Softail Nostalgia 1550 (Stage III), Sporster (slammed)
Here's another data point, C63 is expected to run 12.8 1/4 mile. New E92 M3 is running 12.8 to 12.9 so maybe that's about right, these cars seem evenly matched. I've heard of several C55s running 12.5 - 12.6 with bolt-ons and no FI. Maybe the bigger motor and mega-torque will put the new w204 AMG in the 12.6 or 12.7 range but if so, then it's still conceivable.
#43
- High flow header
- high flow cats
- AMS Crank pulley
- High flow header
- high flow cats
- AMS Crank pulley
#44
Some models have the electric fan, others don't. My 2001 ML55 has the electrical fan and my 2002 CLK55 has the mechanical fan. I haven't tried to retrofit one, but I am betting that you could. It wouldn't be cheap though as the fan assembly alone is pricey.
#48
If a C55 with just headers, ecu, airbox, resonator delete, and under-drive pullies can do a 12.5 @ 112 on DOT tires in over 90 degree weather then that seems to prove a non-FI C55 with basic bolt-ons CAN run with a stock C63 even if it is under-rated--all gearing advantages included. I will be very surprised if the stock C63s run any better than 12.6 or 12.7 @ 110 to 112 (which is quick-as-schit by the way). I guess we'll have to wait and see when they hit the street what they do in the 1/4. Either way, I am sure they both will trap out much higher than the new E92 M3 MBW.
#49
The mechanical fan delete is very popular amongst the bmw crowd and has been done for MANY years. In addition to this you can run a 5-8 degree cooler thermostat and a lower auxilary fan swithc (also about 5-10 degrees cooler). Infact on the E36 M3s many will delete it and run no replacement fan of any kind, the lower aux fan switch & thermostat will more than compensate. The results aren't huge on the dyno but the overall engine feel is drastically different, alot more rev happy, almost like a mini-lightweight flywheel type mod.
#50
How much more does the C63 engine weigh than the C55 engine (engines + accessory drives only, not considering other chassis differences)? Has the forward weight bias worsened considerably from W203 to W204?
